Old 01-01-2016, 09:22 PM   #26
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: The nicest shortbox I've ever seen...
That color could make me reconsider my plan for deluxe Ochre and White (4 -tone). Not sure on the cab arms, but I'm pondering the same two-tone, only Custom Deluxe. Possibly the top moldings as well.
HDFF, is yours dropped the same? What is your drop?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-02-2016, 12:07 AM   #27
hdff
hdff's Avatar
The paint code now is 572 which is for a dark blue metallic body with a white cab. Mine came from the factory with 542 medium blue with a white top like the paint code you show here. When the PO repainted it he did it in dark blue, in my opinion the dark blue looks much better. The paint code is 5200 with 2 letters before the 52 but I can't remember what they are off hand.
My SPID said mine came with the upper belt molding, it don't have it now and I wish it did.
I have a 2/4 drop on springs. Also changed the shock relocation, shorter shocks and a ece super track bar
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 01-02-2016, 12:43 AM   #28
71CHEVYSHORTBED402
A set of top moldings just sold on Ebay for under $600. Here's a truck from this website. Not a White top, but between yours and his provides a clearer picture. http://67-72chevytrucks.com/vboard/a...5&d=1327497030
I think I like the two tone blue better than the four. Upper and lower moldings too. Not that I've ruled out three tone (white/blue/white), but not quite right for a 71.
Tony
Old 01-02-2016, 12:44 AM   #29
hdff
hdff's Avatar
One more of the color, sometimes to me it looks lighter that it really is. Why it is upside down I don't know
"Wanda"
Old 01-02-2016, 12:54 AM   #30
71CHEVYSHORTBED402
Here, I couldn't hang any longer........ BTW, where did you play football, ha!
Tony
Old 01-02-2016, 12:55 AM   #31
hdff
hdff's Avatar
I think I like the two tone better than the four. Upper and lower moldings too. Not that I've ruled out three tone (white/blue/white), but not quite right for a 71.
That truck is medium blue, how mine was originally.. And I think that truck is lower than mine, maybe 4/6, I've thought about that also. One project at a time and I got the ac/heater out if it now.
I have thought about adding the belt molding but one screw up and you've screwed up......
"Wanda"
Old 01-02-2016, 01:01 AM   #32
hdff
hdff's Avatar
So how did you rotate it? In my file it is correct
"Wanda"
Old 01-02-2016, 01:24 AM   #33
71CHEVYSHORTBED402
Unfortunately, I don't have a single screw hole for moldings and bezels.... Worse yet, we probably won't drill until after paint. I may be wrong, but I don't believe it's a good idea to drill for the moldings until after the bushings have been replaced. So if we drill before paint, that means we're assembling the body twice.....................That said, that may not be a horrible idea for lining everything up, including fenders.......Sort of a rehearsal.
I pasted it on paint, flipped it over and save. Re-read my last post, I'm thinking OL.
Tony
Old 01-02-2016, 06:52 PM   #34
hdff
hdff's Avatar
I would be paranoid that I wouldn't get it on perfectly straight. And would REALLY be paranoid to do it after paint cause I would scratch something before it was all said and done. Also doesn't the clip on the rear of the fender have to be put on cause the nut is behind the door hinge.
No football after 8th grade, played BB till 10th grade then I found pu$$y and pot, so much for sports.... Lol
"Wanda"
Old 01-02-2016, 07:10 PM   #35
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Those colors look real good on 67/68's too.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-06-2016, 02:21 PM   #36
71CHEVYSHORTBED402
Boy howdy they do already gone. Only thing I'd have done differently is a white bottom.
Tony
Old 01-07-2016, 01:01 AM   #37
71CHEVYSHORTBED402
I do like "pu$$y and pot"................Not sure on that clip you mentioned. I know that Zep drilled after paint with good results. Are you referring to upper or lower?
There's a nice video for installing the moldings onto a truck that never had them. The truck is assembled, but hasn't been painted. Quit honestly, I wouldn't mind assembling the body twice, once after new mounts and bushings, again after paint. Doesn't seem like an awful idea for lining EVERYTHING up. Of course I'm anal that way, have never done it, and I'd have to convince three others. The only difficult one might be the painter, but he might be up for it. We'll likely be handling the cab without a hoist (4 dudes). It's only about 400 pounds I hear.......stripped.
Speak of the cab, I'm half tempted to purchase a flat bed trailer for it. I can buy an 8x15 right now for $1200, and it's super clean. Sure it's overkill, but a few minor additions I can mount it, tip the cab onto the firewall, drive it to the body guy's house....drive it to paint, bring it home.........Then I can sell the trailer for what I paid for it. Call me crazy, but it seems to be an ideal cab cart, especially for a cab that's going to be moved so often.
Tony
Old 01-07-2016, 01:09 PM   #38
davepl
davepl's Avatar
It'd be nice to see the two blues parked next to each other; here's my 70 Dark Blue, which is a different color, in "faded lacquer" and "new clear". In person it looks more like the old picture, not sure if the green trees or sky skewed the color in the new pic.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 01-07-2016, 02:14 PM   #39
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by sameyrasmea72 View Post
Pretty much already listed above but wrong console and should not have hounds tooth. Looks like most of the changes were done on purpose though.
Not necessarily the wrong console, just using a cupholder insert instead of the seat belt holder insert. I am doing the same thing in my 72. Two screws and it back to original.
WIDESIDE72 is offline   Reply With Quote
Old 01-07-2016, 02:16 PM   #40
WIDESIDE72
WIDESIDE72's Avatar
Such a nice truck!
I'm not trying to pick on this truck,... But for the Cheyenne Super experts,... What all is incorrect about this truck?
Trying to improve my Cheyenne Super knowledge.
Should it have the upper side mouldings?
Windshield and back glass trim?
What else?
NICE TRUCK!!!
Hard to be sure, but looks like its missing the chrome (for 71) stainless tailgate handle cover (for 72).
Old 01-07-2016, 04:45 PM   #41
davepl
davepl's Avatar
I didn't want to randomize this thread too much so I started a new one - could you explain how you changed it over to cupholders? Ideally in the top level thread, not here, but I'll take info wherever I can get it...
Old 01-07-2016, 06:22 PM   #42
hdff
hdff's Avatar
That is a sweet lookin blue!!
"Wanda"
Old 01-07-2016, 06:57 PM   #43
Already Gone
Wideside72, Yes please show us how to change to cupholders
