Old 02-03-2016, 10:30 AM   #26
aboesec10
aboesec10's Avatar
Re: l83 gen v in a 68 c10
strange that it would do it on a stock engine? Im going to do the cam swap and gears in march, then take it to the tuners. Hopefully the few miles i put on it before then won't damage it
aboesec10 is offline   Reply With Quote
Old 02-03-2016, 11:41 AM   #27
Hart_Rod
Hart_Rod's Avatar
Deselect "DOD" and see if that fixes it.
Hart_Rod is offline   Reply With Quote
Old 02-03-2016, 09:12 PM   #28
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Can you discern where the noise is actually coming from? Overdriving the pump can happen on a stock truck, but it would have to be a modified tune.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 02-06-2016, 10:46 AM   #29
aboesec10
aboesec10's Avatar
Ok, well the plan is to take it to lonestar throw down at the end of february, after that its getting a cam swap and gear change, then it goes to the tuner for a good tune. Ill have him kill the dod and adjust the pump if we discern thats what it is. Ill keep you guy posted. Planning on taking her on her maiden voyage today, minus driving in the culdesac.
Old 02-08-2016, 09:37 AM   #30
aboesec10
aboesec10's Avatar
Ive already purchased the cam and spring kit. However I've been reading that the cam swap on these motors isn't necessarily the best bang for the buck>>I guess due to vvt and the fuel pump being driven off of it that there not very aggressive? What are your opinions? If performance gains are minimal is it really worth the $900 or would that be better spent elsewhere?
Old 02-08-2016, 09:41 AM   #31
aboesec10
aboesec10's Avatar
couple of progress pictures for good measure
Old 02-08-2016, 09:42 AM   #32
aboesec10
aboesec10's Avatar
Old 02-11-2016, 11:30 PM   #33
aboesec10
aboesec10's Avatar
well, sent the cam and spring kit back. gonna hold off on those, Hoping to get it tuned next week. Did take her for a drive this evening and to say i am pleased would be an understatement! The dod has to go... My guy who helped with the wiring has hp tuners as well and we purchased credits for this ecm to see if the fan being switched from pwm to discrete to see if they will power the relay for the fans. However after accepting the credits with beta 2.5,( 3.0 was showing a vin/os error) it keeps failing at the boot loader stage. gets to 57% then says failed? any suggestions?
Old 02-11-2016, 11:52 PM   #34
ls1nova71
ls1nova71's Avatar
Just curious, but why do you want to take the PWM fan control out?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-11-2016, 11:56 PM   #35
aboesec10
aboesec10's Avatar
wanting to change it to on/off at temp if possible, my fans are not pwm.
Old 02-12-2016, 12:13 AM   #36
ls1nova71
ls1nova71's Avatar
The fans don't care what controls them. The PWM controller will turn them on and off at temp too, just smoother, a little nicer way of running them.
In case you are interested, here's a little thread on how to make them work with cheaper parts. http://ls1tech.com/forums/conversion...connector.html
Old 02-12-2016, 01:33 AM   #37
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wait, 3.0 was showing an error? Which one.
2.5 beta was IMO an evil b!tch. Too many software crashes and resets to make me comfortable.
If it was running before, what version was it licensed on? Config files/readouts aren't backwards compatible. 3.0 overwrites the PC-side install files (this should all be on the VCM editor, not volatile to the tune afaik).
Just please tell me that the old tune wasn't pass locked when you tried to flash with a newer version of HPT.
Old 02-12-2016, 10:20 AM   #38
aboesec10
aboesec10's Avatar
3.0 was showing the vin/os error. The ecm was flashed with 2.5 from the tuners to eliminate the vats. Its not locked. Im not gonna mess with it anymore ecm wise until the tuner gets ahold of it. Thats not my forte obviously..lol. It makes me nervous when we plug into it. He emailed hp tuners about it and they think its a connection issue (wiring), yet the scanner tool will pull codes and read the vin from the ecm with no issues. Also the signal is obviously there as my dakota digital gauges all run from the obd signal. Also read on the forums that a battery issue will cause the boot loader failure. Its got a brand new yellow top optima in it so i don't think its low voltage there.
Old 02-17-2016, 10:20 PM   #39
Cash3481
Loves all GMC trucks
Cash3481's Avatar
I'm following along. I'm installing a 2015 5.3 and 8 speed in my 72. Finding the harness I need has been difficult due to no one making the harness... YET!
Keep up the good work and good luck at the show!
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 02-18-2016, 01:22 AM   #40
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The 8spd is very finnicky about shift points, and you can't effectively lock it in gear. If your leaving the motor fairly stock it shouldn't be too bad to just leave alone, but if you make large changes, be prepared to do a few hours on the trans tables. It is kinda fun knowing your in 7th gear though.
Old 02-19-2016, 08:59 PM   #41
aboesec10
aboesec10's Avatar
got her all tuned up today! she was lean on bank one, gonna double check tomorrow but I'm pretty sure that was the funky noise
Old 02-20-2016, 11:04 PM   #42
aboesec10
aboesec10's Avatar
also for further reference, the dakota digital gauges which are run from the can-bus is what was throwing the errors on hp tuners. unplugged them and bam, worked like a champ! After the tune, just plug them back in
Old 02-20-2016, 11:14 PM   #43
aboesec10
aboesec10's Avatar
got the ac charged up but the compressor im not building pressure. Really dumb question but I've got the clutch wired up to the binary switch. Do i need to put power to the solenoid set of wires on the compressor as well?
Old 02-21-2016, 02:20 AM   #44
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Makes sense. The HPt probably thinks that there is another device "intercepting" the data, which is a no-no. I'm sure they have reasons, but my assumption is that potentially could allow you parallel the connection and somehow copy a file.
Old 04-14-2016, 08:24 PM   #45
aboesec10
aboesec10's Avatar
got about 800 miles on it now. Did a gear change to 4:10 with posi, she'll roast em for sure! I have run into a random issue thats happened 3 times. Its acting as if the fuel pedal goes dead. No response at all, just idles. I shut off power to the ecm and reset it and its back to normal. Its done it at low speeds all 3 times but at random throttle positions. My code history doesn't show anything at all but I may be deleting them when i reset the ecm. Don't know if they stay in history or not. Any ideas? I think if it was a loose connection that reseting the ecm wouldn't fix it.....
c10clubtexas
Old 04-14-2016, 08:25 PM   #46
aboesec10
aboesec10's Avatar
gonna keep a hand held scanner with me to see if it throws a code next time.
c10clubtexas
Old 04-14-2016, 08:42 PM   #47
Hart_Rod
Hart_Rod's Avatar
Check your pedal connection wires.
Old 04-14-2016, 11:47 PM   #48
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If your shutting it down right away, it might be clearing them as *pending* codes. If its a T, or B code, then you might not see it on normal handheld scanners.
It sounds like the DBW was being interrupted. I ran into an issue involving magnetic interference, but thats beeeyyyyooonnnddd rare. Check the connections as Hart said. Look at the purple and yellow wires on the TB, make sure all connectors are fully seated. Check that the DBW isn't sharing and grounds with another system.
Old 04-15-2016, 08:28 AM   #49
aboesec10
aboesec10's Avatar
cool, thanks guys. Ill double check the wires this evening and see if i can find an issue. Ill keep you posted
c10clubtexas
Old 06-13-2016, 12:58 AM   #50
cornerstone
cornerstone's Avatar
LOVE your ride man...Any updates to share? I scored a low mile 14' 5.3/6l80e for an awesome price for my 72 chevy lwb and I'm watching your progress. Honestly I still dont know if im going to stay with this motor setup. I like the novelty and the cool factor of it but simplicity is a beautiful thing also, and that would be a 6.0/4l80e to me. I guess I can work my way through it with these kinds of boards out there. I did an ls1/ 6 speed swap into a 65 replica cobra in 1999 or so and it was relatively new at the time so I just need to muster the courage.
cornerstone is offline   Reply With Quote
