Old 01-01-2016, 11:22 AM   #1
73kay
C10 Frame on a 48 Body (I know I know)
Ok, I googled for hours last night and besides the wheel sticking out a bit that's all I have heard that is bad. Here is what I got:
I have a 76 c10 stepside with a i6 250 3 speed saginaw in good shape
I have a 48 gmc 1/2 ton cab and a frame with 235 that I am trying to see if it still has any life left.
If that motor is junk I might just see why I can't take the front clip and cab off the 76 c10 and put the 48 cab there. Then in theory use the pedal/steering assembly and modify that into the 48 cab as well as use the wiring, steering column and anything else out of the 76. The wheelbase is 116 for a 48 and the c10 is 117.5 I think.
The cool thing (if all the stars align) that I wouldn't have to touch my motor, trans, driveshaft, rear bed and just build it forward. If this works, I plan to long term take off the 76 outer bed fenders and get the appropriate style ones.
I have done some rough measurements and I believe both cabs are approx 5 ft long with the 48 having a 6-8in narrower width. Both have a 3.5 in insert for the motors. With that small saginaw I might get away with not having to touch too much of the floor and I don't want to drop the truck so that gives me some more flexibility.
All in all, I need some more honest information so I can know what to expect. I have a welder and am just finishing up another 76 c10 restore, so I'm not afraid to get involved.
If my 235 cranks up then I could just swap the 76 bed, but I want to run this option first and see what you guys think.
Sorry it's so long, thanks!
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
