01-06-2016, 10:58 PM | #26 |
Re: How are the repop bedsides?
These are the same cardboard boxes that my bedsides came In from lmc. Just received them a couple weeks ago. Very happy with condition
01-07-2016, 12:12 AM | #27 |
Shifting back to the original question, if the original bed for $2,000 is in good shape, that's a damn good price. I would love to have an original short bed. I would trade my Tri-plus/ OER bed in a heart beat for a factory bed in half decent shape. This is a steel floor, sides, and head board. All fit ok, needed holes opened up and some grinder work. Now I'm fighting with my tail lights not fitting right and the whole bed is out of square. Not sure how to go back to fix yet....
'68 C10 SWB '85 K30 Blazer |
01-07-2016, 02:13 AM | #28 |
I couldn't have been much happier with this bed. I bolted everything together loosely, and it checked out square. Installed the tailgate, and tightened everything up. All in one evening. Had to adjust the tailgate trunions a little to fit the tailgate, and had 2 holes to open up slightly to install the RH wheel house. Very pleased with the fit of everything. |
01-07-2016, 02:25 AM | #29 |
Hi, I don't know how to use this app but want to find out how to adjust doors. First I have to slam it and when it's shut if you push hard enuf it still goes in and out. Why going over bumps sounds like not shut all way. Have questions about door and window rubber seals. Air flows thru bad
01-07-2016, 06:32 AM | #30 |
How much for the complete bed put together and painted white ?
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
01-07-2016, 08:23 AM | #31 |
Dean at the Chevy truck farm in Kodak ,Tn still has short wide factory beds for sale.
http://techethic.wix.com/truckfarm He has around 70 trucks and buildings full of original parts way more than whats in his picture .Tell him Grumpy sent you. |
01-07-2016, 11:39 AM | #32 | |
This is the one on my local craigslist, although the poster isn't very local http://pittsburgh.craigslist.org/pts/5291357381.html I could see paying the $2000 if it only needed minor work, but it all likely hood, it would probably need media blasted and by the time it's ready for paint, would be about $3000, and there's no telling what condition the insides of the panels are. I know on my current bed, the insides look worse than the outside. Personally I've never had any major problems with repop panels and would rather spend $1900 for a brand new bed than $2000 for a used one that most certainly will need work EDIT: by inner panel, i was talking about the part not visible, the gap between the outside bedpanel and the inside bed panel. Does that make sense? I saw how bad mine were when I went to replace part of the wheel opening arch
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS Last edited by FlameOut; 01-07-2016 at 12:02 PM. |
01-07-2016, 01:55 PM | #33 |
Steel floor or wood?
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
01-07-2016, 07:25 PM | #34 |
01-07-2016, 07:29 PM | #35 | |
01-08-2016, 08:22 PM | #36 |
01-08-2016, 10:24 PM | #37 |
With all the talk about short beds , i have a question,
how do the bolts on the front bed panel go? into the bed , or towards the cab?, During assembly i am wondering if the bolts will rub the back of the cab when all done, any pics. would be helpfull |
01-11-2016, 03:36 PM | #38 |
When I took mine apart, they were phillips head bolts. They were a real pain to remove. I had to tack weld a nut to the phillips head and remove them using a socket. I'll see if I can did up some pics
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
01-11-2016, 03:43 PM | #39 |
If I were to get my bedsides without the stake pocket holes, do I also have to go with no side marker light openings? I like the idea of the no stake pocket openings, but I need the side markers. I can't see anyone selling the sides with no stake pocket holes but with the side markers. It also seems like I'm better off ordering a complete kit, even though I don't need a tailgate, tailgate hardware, or wheel housings. Those are like $500 +/- for the group, but deleting them only takes a few hundred off of the entire kit. I just wonder how easy it would be to resell those items. I did find an entire bed kit for $2185 with shipping in the $300 range
01-11-2016, 04:22 PM | #40 |
I purchased a complete bed assembly from Southern Kentucky Classics. It was a little over 2K. Everything fit very well and was very pleased with the end result. You can dig through my build link below and see the results as it was assembled.
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
01-12-2016, 01:19 PM | #41 |
The heads are on the side toward the cab. Some had Phillips head screws and some had hex head bolts. Mine had Phillips head screws on one side and hex head bolts on the otherside. I know the factory did it as they were painted body color and the truck has always been in my family.
01-12-2016, 06:43 PM | #42 |
thanks for the info , new member working on a frame off , and its going well,
but the help is great. |
01-14-2016, 03:00 PM | #43 |
To anyone that has previously purchased the entire short bed kit, would I be able to fit it all in the bed of a Silverado (shortbed)? Seems like the floor might be the biggest problem. The packaging is probably longer than the Silverado bed
01-14-2016, 04:55 PM | #44 |
Don't think you would be able to close the tail gate. I have a small 8 foot trailer to get my stuff home. You will have the floor, both bedsides, front panel and tailgate, not to mention wheel tubs, splash guards and misc. hardware. Borrow a small trailer if possible.
01-14-2016, 05:30 PM | #45 | |
01-14-2016, 08:25 PM | #46 |
I brought mine home 200 miles in the back of my F150 RCSB no problems whatsoever.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
01-19-2016, 07:06 PM | #47 |
I got mine from Insane Hotrodz. Havent put it together yet but they look great, Insane was great to deal with, AND they sent me a Christmas card this year! You won't get that from LMC!
Sleep safe in your beds because rough men stand ready in the night to visit violence on those who would do you harm 72 K5 Blazer 72 K10 SWB (in pieces under slow construction!) 72 K20 |
07-28-2017, 10:42 AM | #48 |
What color is the blue on your truck? I would like to go with a similar color on my '70 with a white top. The bed looks killer!
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-28-2017, 06:05 PM | #49 |
Thanks 70Stovebolt, the blue is a custom color.
BASF Glasurit MB765.50 The white is the correct white for a 1970 truck.
07-29-2017, 08:04 AM | #50 |
I'm questioning this as well I need rockers and cab corners and a few other items . I was told Southern Kentucky Classics makes a lot of these parts as well.
