View Poll Results: Does your original, factory air conditioning work? | |||
Yes, it works and blows cold air on hot days |
47 | 40.52% |
No, it does not work right now |
44 | 37.93% |
No, because I removed it |
4 | 3.45% |
No, because this was not a factory air truck or has been updated to modern stuff |
21 | 18.10% |
Voters: 116. You may not vote on this poll |
#26 |
Re: Does your Air Conditioning Work
I've restored quite a few of these factory ac/heater parts. Haven't had any complaints yet, knock on wood. Went through pretty much everything on this 70 and it left the shop blowing 38° on 134a. But I'd like to mention that to get them working great with 134a a few things should be done including getting a nice size parallel flow condenser and a Poa valve that's calibrated for 134a.
#27 |
Cruzzzn' Vet
Nice!
#28 |
![]() Join Date: Feb 2009
I need to reinstall it. At least a new condenser is in order. It's been off quite a while. At this point I'm unsure what should be done with the install. Nice looking heater box up there.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#29 |
Thanks guys
#30 |
If you need some help on what should be done with the install, you can pm me if you'd like.
#31 | |
So you restore this stuff huh? Do you do anything for the Air/Defroster Selector Duct flapper? The rubber is a bit worn on the end, which is probably common. Few scratches on the finish of the box. Might be worth refinishing.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 01-14-2016 at 06:18 PM. |
#32 |
I restore those also. Couldn't find any pics on my phone. I think they're on my pc
#33 |
I'd like to see that. Maybe a restore is in order.
#34 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#35 |
Thanks, I appreciate it.
#36 |
I thought has another pic showing the door, rod and gasket before I installed them into the duct, but I can't seem to find it. The door and rod were replated though.
#37 |
Nice. The boxes were brown I believe (I'm colored blind). Have you tried duplicating the color?
#38 |
Its a little hard to tell but they are a darker grey. Don't think I have ever seen one that was brown. I will be getting a darker grey to match tem better. Now the distribution duct, I have seen in brown and black
#39 |
Got a Harley for the summer, and a Burb for winter
The factory A/C is getting torn out this summer
Happy as a pig in mud |
#40 |
I think you're right, gray-brown-green (ha).....Here's an original. Little dirty. I haven't cleaned the interior in decades.
#41 |
Yea that's the look of the majority of the parts I have on the shelf
#42 |
I live in the high desert. 6500 feet. Very little to no humidity. Who needs an air conditioner?
![]() Ok, there is like 14 days in the summer that it would be nice to have A/C after being parked in the sun all day. But other than that the heater is more important.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
#43 |
How can you find a leak once the freon is gone? I can -detect- a leak by vacuuming it down and seeing that it can't hold vacuum, but how do you (or I) sort out where that's coming from?
You could pressurize it and use soapy water, but compressed air might be too "wet" for the system, I'd hate to find that out the hard way. Just FYI, mine was a brown-grey and this was a reasonable facsimile to it:
#44 |
you pressurize it with nitrogen. Happened to me on the 70 that I recently restored the ac system. Vacuum wouldn't hold and everything had been gone through. pressurized it with nitrogen and the problem was I had bad orings on the couplers to the machine.
#45 |
How do you do that? Go to a welding shop, would they have tanks of it? Then you need adapaters and hoses I imagine to connect the tank, but you'd want a regulator of some kind because I'm sure the system wouldn't tolerate tank pressure, would it?
#46 |
Yea just need a regulator on the cylinder and hose the proper fittings. I do a lot of pressure checking with nitrogen on my welds so I already have all these things. not sure about welding shops but I would imagine a shop that deals primarily with ac(not just a regular automotive repair shop) has these tools also. I would look for one of them.
#47 |
Mine doesn't because the PO ripped it all out and even welded the vents closed in the dash. Had no idea it was an AC cab until I stripped all the paint and found the vent holes under 1/2" of bondo. I went ahead and ground out the bondo and tack welds and installed new vents after I painted my truck. One day I'll put the rest of the AC system back in. Can't understand why someone would rip it all out even if it didn't work! It's always been in Ca and it gets hot here!
http://smg.photobucket.com/albums/v655/aaronhero/ |
#48 |
![]() ![]() Join Date: Sep 2008
Don't forget to change the break in oil in the engine.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#49 |
My factory original AC still works
#50 |
We're at 40-38 for a "works-doesn't" split, just about a perfect 50/50.
