01-13-2016, 04:53 PM | #26 |
Re: best year nonvortec 350?
What kind of fuel pressure are we talking?
Stock AirCooled F.I. Pump is about 60psi regulated down to 28-32 Carb elec fuel pumps range 2-4 and 5-7. Dual 44 Webbers take about that and that's a good bit of carburation |
01-13-2016, 10:52 PM | #27 | |
*** That's interesting ***
As for the coolant bypass, this has been discussed to death. I am using a Weiand aluminum intake. I just used my heater hoses in stock setup for a 67-72 non-AC truck... one from the intake manifold to the core, the other from the core straight to the water pump nipple. There isn't supposed to be a flow control valve on the old trucks (stock setup uses an air diverter). So it works perfectly as a bypass. No need for anything else. If you have a newer truck or car that needs a coolant valve at the core, just get a 3-way bypass type. Problem solved.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-14-2016, 01:43 AM | #28 | ||||
60-66 Nut
If you want to run a Q-jet on a Vortec engine you simply need an Edelbrock Performer Vortec intake #2116
My investigation shows that the blocks are drilled for the bypass but the Vortec heads are not. Quote:
http://www.summitracing.com/parts/hly-12-427/overview/ Quote:
01-14-2016, 10:22 AM | #29 | |
Senior Car Nut
"Great engine but I can't stand the electric fuel pump. It's expensive, loud, needs a regulator and is a pain in the ass to set up." I don't like the Carter electric pump I have for the same reasons. someone else also suggested the Holley Mitey Mite in a previous thread about L31s. I'm going to give it a try I certainly recommend you explore the range of crate engines available and do your homework on rebuild pricing
Larry |
01-14-2016, 10:54 AM | #30 |
Some blocks are not completely finished through to the deck.The hole is present at the front of the block,but,does not go all the way thru to the deck.This would be in the #880 block,96/up.The #638 blocks should all be completely through as the TBI heads were drilled. Some early #880 blocks were indeed open throughout & were machined for a mechanical fuel pump.Generally,if the block has a blockoff plate at the fuel pump opening,it is machined.If not,it's not machined.
01-18-2016, 03:10 PM | #31 |
Come to find out there is an engine in the yard that is a vortec and 4l60e trans
Aluminum heads iron block.. 4.8? 5.3? Heads are 706-99+ Chevy.. Believe it cable out of a 2000 or so? Trying to nail down what year! I'm looking for 96-02 350.. Want to brake to put carb on out for now Will it fit with my 3 speed? What year can I Not just put carb and hei on?? |
01-18-2016, 07:25 PM | #32 |
That is an LS motor.You can put a carb on it, but, there is no distributor. You would have to use an aftermarket controller to run the CNP ignition.Spacing is also different between torque convertor to flywheel.
The L31 Vortec/350 was only available in trucks from 96/99 & in vans & some SUVs until 2001.If your goal is to use a carb & hei distributor, that would be the best option. |
01-18-2016, 09:03 PM | #33 |
Cool thanx
That's really what I wanted to know I'm looking for one I can carb and put on my 3speed |
01-18-2016, 10:31 PM | #34 |
Are there numbers on the L31s so I can tell that's what it is?
And do they come in the 2500s? I just noticed they were 6 lug and it'll be cool to get the discs in 6 lug |
01-19-2016, 01:05 AM | #35 |
My dad owns an '86 K20 and '97 C1500 Suburban, both with 350's. The '86 saw 361,000 miles (some pretty hard ones) on the original bottom end before he quit using it because of fuel system troubles, and the '97 rolled over 400,000 on the untouched bottom end this fall and still runs like a pocket watch with good "vital signs" all the way around. Not that the smaller SBC's have to take a back seat to the 350, but Chevy did right when they perfected the 350 and stuck with it. IMHO the Vortec 5700 is one of the finest domestic powerplants, period. The older flat-tappet engines are better than most, too, but the refinement of the induction system and roller cam on the Vortec bring the rest of the design to its full potential for refinement.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
01-19-2016, 06:47 AM | #36 | |
The L31/350 will have block casting #880. The head casting # will either be 906, or, 062. They came in 1500,2500,&3500 series trucks. |
