01-14-2016, 12:00 PM | #26 |
Re: LSx bang for your buck. Whats the best value?
People seem to get caught up in achieving a HP number. You don't need 450hp to achieve what you want. I have a bone stock 5.3L and it does smooth cruising, tows 6k+ easily, and gets decent mileage. This met all of my project goals for my truck.
01-14-2016, 12:05 PM | #27 |
Always a work in progress
Just like everyone has stated, the more cubes you start with the easier it will be to meet your HP goals.
If you want to keep the costs down, build your own harness. It's really not that hard it just takes time and patience. Wasted Income hit the nail on the head, unless you start with a LS7, I think you will be hard pressed to get to the 450hp goal without a cam swap. 6.2/6.0 with a cam swap and stock heads should be doable, it would take some modifications to the heads and a cam swap to get to that goal with a 4.8/5.3. I swapped to stock 243 heads milled .025" and a small cam and I'm probably around 375-400hp(at the crank) at most. I plan to get a better tune and cam to see what it will do so I will keep you posted. I might have $3000 in my swap to include the 4l80e I just bought. I haven't done anything to the 4l80e yet so that number will go up as it always does. I got the 5.3 for $400 and the 4l80e for $500, I used stock manifolds and the th350 that was in the truck. The 243s and the cam cost me $500.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
01-14-2016, 12:05 PM | #28 |
01-14-2016, 12:35 PM | #29 |
Boosted Member
Lol. Yes.
I was able to hook 500 rwhp easily in my C10 LWB. 650 rwhp was also easy to hook in my blazer...800+ is proving to be a little more challenging. Dead hook on an 18" wheel with a 305 Mickey drag radial....leaving at 6 psi....650 rwhp.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! Last edited by Wasted Income; 01-14-2016 at 12:43 PM. |
01-14-2016, 12:58 PM | #30 |
Caltracs, good tires, and rearend built to handle the shock of hooking.
01-14-2016, 12:59 PM | #31 | |
Gasket set $??? Cam, springs, pushrods, and lifters IIRC about $800 Yank Pro Truck 3600 stall $950 So a little north of $2000
'83 Silverado Step Side '85 GMC short bed. '86 Chevy Step Side Custom Deluxe LQ9/4L80 swap (SOLD) |
01-14-2016, 01:02 PM | #32 | |
Boosted Member
My rear suspension geometry is stock, with tubular truck arms, and single adjustable coilovers. The rear axle is stock too, with the exception of an Auburn limited slip
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
01-14-2016, 01:59 PM | #33 |
What gear ratio, and was all of these mods added into the "engine upgrades"
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-14-2016, 02:19 PM | #34 |
My buddy buys gto total cars. Sells fully dressed motor and auto trans for $4600. Typical miles are 60-80k. Then parts out the rest for profit. $4k for an engine that needs acessory drive brackets and alternator, ps pump, trans, harness ecu, etc is not as good of a deal. Shop around and getting a complete package can be affordable.
Current project 1959 Willys = GEZR TRUK Geezer is a Latin compound word made up of two roots. Gee meaning Urine Stain and Zer meaning your pants are open! FMCDH GBU and GBA http://www.youtube.com/user/aknovaman/videos |
01-14-2016, 03:24 PM | #35 | |
Gears will depend on tire size, what trans your using, and rpm range of your engine. I haven't spent any money on those pieces yet other than the used 4l80e I bought. Gear and locker/posi swap about $550-600 Cal-Tracs $375 Good converter(4l80e in my case) $500-1100
01-14-2016, 07:30 PM | #36 |
This is a VERY true statement. I wish I would have done a basic swap and not worried about the HP. Had I done that, I probably would not have sold the truck. The next one will just be a nice reliable cruiser.
01-14-2016, 08:11 PM | #37 |
I'll part a low mileage F-body a year or so if/when I have time.
Under 100k, push for under 80. I sell the pullouts with ease in the $3500 range. But that's complete with harness, ace's, etc etc... Prices are up but not unreasonable. If you watch you can snag rectangle port pullouts in the $4k range. OP - Start with a rectangle port motor, 6.2 is better but a 6.0 is fine. 500 crank is attainable but will be a stretch without a cam swap, especially if you start with anything less than a 6.2. FWIW, my LQ4 with milled 243's, custom cam, FAST, headers, 90mm TB - basically max effort...made 420 through a locked 80e.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
01-14-2016, 08:22 PM | #38 |
meowMEOWmeowMEOW
I'm not comparing the price apples to oranges, I'm illustrating the point that if some people are paying $1800 for high mileage motors from junk resellers, your better off buying new. LSX longlock packages at my cost aren't even that much crazier in price once you start looking what guys are paying for high mileage LS3's...then doing h/c/i anyway. Its all relative.
01-14-2016, 08:37 PM | #39 | |||
Happy to be here
Thats really what I hope to achieve. I dont plan to build a truck to run at the track, or be a street racing terror. I'm not stuck on achieving any magic HP number either. I used the 450hp as a description rather than a goal.
01-15-2016, 06:22 PM | #40 |
Junior Member
What hp do you thing you could get with headers and a tune on this one?
You are looking at a 2013 aluminum headed and cast iron block lmg.. 5.3 vortec engine and computer and wiring complete liftout...with the 2wd 6l80e six speed auto trans........ The 5.3 is the lsx truck engine, it has 315 horsepower and 335 ft lbs of torque. This is the ls1, lsx, design engine, also known as the generation 4 small block chevy. It has the cast iron block and aluminum heads and hydraulic roller camshaft. The casting # on the cylinder heads are # 799 they are the same heads as a ls6 corvette..... ...... .the 6l80e transmission is the heavy duty 6 speed automatic transmission... This was just pulled last week from a wrecked low mileage new body style 2013 chevrolet tahoe 2wd. . This combo .has 35,700 miles on it.. .. The tahoe was impacted, not doing any damage to the drive train. It ran absolutely perfect. And the crankshaft is the 58x reluctor. And does have the dod in it.... It does have vvt.... This is a complete lift out assembly comes with engine,transmission, computer, wiring harness. ( wiring harness not guaranteed to fit your application). Starter, alternator, power steering pump, a c compressor, all brackets and pulleys. This is a drive by wire engine. The electric gas pedal and wire plug cut from the vehicle is included, as well as, mass air flow sensor. No catalytic convertors are included in the auction.... ... We are professional dismantlers. No wires were cut in the removal of this combo. Consult dealer for interchange before bidding this should fit 2010-2013 chevy and gmc trucks, yukons, suburbans, ... We are located in paragould arkansas.... We ship to the lower 48 states....... We charge a $100.00 crating charge and actual shipping charges....... 30 day standard warranty.. Price is $4500.00 plus shipping......
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
01-16-2016, 11:00 PM | #41 |
Truck and auto performance nut
My brand new never installed '09 LY6 was $2700 IIRC on ebay...but without harness and ecm.
I'd guess a 6.0 LQ4 w/headers and a tune is all the power you'd really need (roughly 400hp/tq?) or just get an LS2. My 6.0 with high lift cam, the LS3 style heads, CAI, and fairly hot tune is roughly a 500hp setup, not really too aggressive and drives easy until you punch it...then all h311 brakes loose. That said, IMHO thats way too much power for many drivers. especially with less experienced drivers.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
01-17-2016, 11:09 AM | #42 |
450 HP to the rear tires is whole lot more HP than most folks realize.
01-17-2016, 06:55 PM | #43 |
And in a pick up especially !
01-18-2016, 09:42 AM | #44 |
Boosted Member
I wish i was as easily impressed by 450 hp as you guys. Life would be a lot simpler. Lol
01-18-2016, 11:57 AM | #45 |
Happy to be here
Good input guys. As mentioned previously, the 450hp was just a benchmark. I was just using that as a point for theory, not a mandatory requirement. I also understand the difference between RWHP and at the crank.
I know the old formula that there is no replacement for displacement still applies. I feel that what I have learned here is the 6.0 may not be as glamorous as the 6.2, but its much more economical to purchase. So a good answer to the original query is buy a 6.0, build your own harness, get a good tune, and enjoy.
01-18-2016, 12:01 PM | #46 |
Happy to be here
Lets look at another angle, stock vs modded cost. Lets say a 6.2 cost 4000.00 and a 6.0 cost 2000.00 (again just theory) If you add headers and a tune ONLY to the 6.2, how much HP would you net? What mods, and how much would you spend to get the 6.0 at to same HP?
01-18-2016, 04:51 PM | #47 |
You guys need to come up here. You have 30 cents over us on your dollar and one of the biggest wreckers anywhere around here scraps almost all of the 4.8 and 5.3's. No market. I can get them complete, computer, wiring, everything for 400 Canadian. i should fill up a trailer and had south. LOL.
Saskatoon, Saskatchewan Canada |
01-18-2016, 05:14 PM | #48 |
yea thats a pretty good deal. Just sold a 4.8 to a friend for $300 US, that was the friend price.
01-18-2016, 06:13 PM | #49 |
Local yard did the same thing couple years ago. They only by clean low mile wrecks. They threw away dumpers and dumpsters of LS engines. Pissed a lot of people off. Rather than selling them to locals for a couple hundred, lets just throw them away and not get **** for them from the recycler. They charge top dollar for everything they sell no deals for anybody but family
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-18-2016, 06:26 PM | #50 | |
1973 C20, 350/350 |
