01-18-2016, 08:22 PM | #26 |
Re: Amateur 1970 C20 Longhorn Build
Thanks!
01-18-2016, 08:23 PM | #27 | |
The Older Generation
LockDoc
01-18-2016, 08:37 PM | #28 |
Oops, my bad on the rearend. Had it wrote down HO52. Must have been thinking the other when I wrote it.
01-18-2016, 10:57 PM | #29 |
What is spring #17 called?
02-12-2016, 01:31 PM | #30 |
I got a few more parts that need names and locations. :/
02-12-2016, 01:34 PM | #31 |
Clutch rod?
02-12-2016, 01:37 PM | #32 |
02-12-2016, 01:41 PM | #33 |
I assume this mounts to the block some where. Where and what does it hold?
02-12-2016, 01:45 PM | #34 |
No really sure
02-12-2016, 01:47 PM | #35 |
Some sort of mounts?
02-12-2016, 01:51 PM | #36 |
First pic? Second pic?
02-12-2016, 01:53 PM | #37 |
I do appreciate any and all help and advice on this build. There isn't exactly many people anywhere around with these kind of trucks that I can just go look at for ideas and examples.
02-12-2016, 02:00 PM | #38 |
Restoring it $200 at a time...
Lay a tape measure alongside the parts to help us determine scale. For the first rod, I'll go with carb linkage if the diameter is ~1/4".
Red primer is the bracket for the washer fluid bottle Heavy bracket looks like the mount for the PS pump The last part screws to the underside of the dash to clamp a grommet around the steering column
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 Last edited by hounddogs!; 02-12-2016 at 02:05 PM. |
02-12-2016, 02:00 PM | #39 |
Red (maroon) bracket is for you window washer jug. I've always called the spring the clutch return spring.
Pic I've attached looks like the cover that goes underneath the steering column to the bottom of the dash.
The lid is stuck on my jar of anti seize |
02-12-2016, 02:46 PM | #40 |
02-12-2016, 09:52 PM | #41 |
6>8 Plugless........
1st pic is a retainer for the clutch arm spring. #16 in Post #29.
Pic in post #35 looks like the bushings under a bell housing when there is a cross member under the bell housing just below the fire wall. Pic in post #30 is the clutch rod that goes through the fire wall and hooks to the Z bar as some people call it. That is bolted to the frame and the engine or bell housing. The rod in post #31 could be the one going to the clutch arm, but I doubt it. That looks like a shifter rod to an automatic shift on the column rod. I have a 72 Longhorn I can take some pictures of for you. It is a complete still together 402 4 speed Longhorn.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 02-12-2016 at 09:59 PM. |
02-13-2016, 11:17 PM | #42 |
Any ideas on post #34 and the pic of the Oval piece (top pic) with two holes on post #36?
02-13-2016, 11:22 PM | #43 | |
If it isn't too much of a burden to take some pics. Or if you got some on your page you want me to check out. Just trying to get it right. Probably sweating the small details to much. |
02-14-2016, 01:15 AM | #44 |
Pic. no 31 looks more like a throttle rod. To thin to be a clutch rod. Notice the swivel end? Throttle rod.
1971 Cheyenne Super C-20 402 4 speed 1970 El Camino L-48 350 1999 Chevy Z-71 Extended Cab 4x4 2000 Tahoe Z-71 2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator 1970 Chevelle, Malibu Sport Coupe 2007 Harley-Davidson FLHX Street Glide |
02-15-2016, 09:50 PM | #45 |
Just let me know what areas you would like pictures of, and I'll go over and get some. I'll probably be taking it apart within the next month it looks like.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
02-15-2016, 10:19 PM | #46 |
Pic in 33 looks like a Power steering bracket, I think the bracket below may be part of it too. i think the mount is for the rear of the tranny.
I agree you really need to place a tape measure across these pic's.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-19-2016, 01:45 PM | #47 |
Some measurements on this bracket
02-21-2016, 11:15 PM | #48 |
Dieselwrencher, or anyone, I wouldn't mind seeing some pics all around the engine. Sounds kinda dumb I know but I'm just having trouble finding good pics and I haven't messed with too many caburated v8 engines. Some areas I'm having trouble seeing in pics would be where the ""stove?" Heat tube hooks into, where the vacuum lines go, just all around pics of the engine. My books don't show the details of that or I'm just looking to hard and not seeing what's in front of me. Due to lack of knowledge on the subject I suppose. I also posted that back I still don't know the name of above this post with a tape.
As always, any and all help is greatly appreciated. Thanks everyone for the support. |
03-21-2016, 10:28 PM | #49 |
Trying to figure out where the red wire goes.
