#26 |
Old member
No problem.
A lot of people have left it in the later model stock position and it seems to work fine. Myself though didn't want the hassell of trying to work on it on the side of the road are having to get under the truck in the garage just to change the belt. Plus it takes a way from the old school theme of the engine bay! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#27 |
Re: High Mount A/C options
i do like the old school look, so much where i wanted to stay with an R4, buttt im still doing research on it all. the ls swap has so much stuff gping on here, correct mounts, flywheel, bushings, headers alll the good stuff. thanks everyone
#28 |
I kept mine stock. I am kinda cheap I guess, plus I did my swap over 10 years ago and the bracket selection was not what it is now.
Yes it is tight, I install mine after I put the engine in. It must slip in from the front. I also built my own motor mounts and everything is low and slid back as far as possible. I have not had any issues with it, the hoses fit but again it is all tight. I am embarking on a swap in a 1971 Camaro and I will need the high mount for it as there is no room to put the compressor in the factory stock location. Anything is possible sometimes it just takes some creativity. good luck Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#29 |
dave, thanks for the words of wisdom!
#30 |
Old member
It really just boils down to where you want it.
#31 | |
![]() ![]() Join Date: Oct 2011
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#32 |
66chevymax, what mount is that? !
#33 |
Corvette Accessories, unfortunately the vette compressor will not work with vintage air.
#34 |
Old member
![]() How close are the 2 frames you reckon? I'm assuming this is the truck in your avater. I would think they are pretty close to the same measurements. ![]()
#35 |
just wanted to apologize to 72 Mario for stealing his thread.
66chevymax - thank you for that big bit of info, another thing I'm looking into |
