Old 09-29-2003, 10:31 AM   #26
landon4421
Life is Good !
landon4421's Avatar
Adam12, as far as the install goes I just got done this weekend installing mine ! I used the brake line also, It was really easy ! You needs a tube bender and the flaring kit, that is if you dont all ready have one. I did mine in like 4 hours, I took my time ! take your time !!!! It is much easyer when you take your time. I did a set about 4 years a go, and they looked like crap ! I slamed it togeather to go 4 wheeling the next day.
I went and found some 9 gauge wire, and cut it into like 36" peices. Then I stated in the front with the radiatior and started bending the 9 gauge wire in the spots that I needed. I used the 9 gauge wire as a templet for where and how the bends needed to be bent. I chose the 9 gauge because it holds its shape good. The I mesured everything to make sure I was close, and started bending. It took me a while to get it done. I watched the race at TALLADEGA and did mine while I waited for the big crash to happen. It was a good race to!
GO MICHAEL GO
Anyway adam12, sit down in front of your truck drink a beer with it, think about what you are going to do, take your time it is easy! I have learned a lot from this board, and about how to work on these truck, so don't get discuraged (sp) just take your time. You will have fun, Learning......
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 09-29-2003, 07:26 PM   #27
Adam12
I hate trannys
Adam12's Avatar
I may not post a lot but I read these forums for 1-2 hours a day I have been a board member since before I even had a truck, just when I knew I had to have one I think i have like 65 post in a lil over two years heh. I learn soo much from everyone here.
Thanks again,
Adam
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
