View Poll Results: What's on your 71-72 Chevy/GMC, for stock radio | |||
Stock AM radio, Fixed mast - Know it's original or correct replacement |
16 | 22.54% |
Stock AM radio, Fixed mast - Don't Know if original or correct replacement |
11 | 15.49% |
Stock AM radio, Telescoping mast - Know it's original or correct replacement |
17 | 23.94% |
Stock AM radio, Telescoping mast - Don't Know if original or correct replacement |
8 | 11.27% |
Stock AM/FM radio, Fixed mast - Know it's original or correct replacement |
4 | 5.63% |
Stock AM/FM radio, Fixed mast - Don't Know if original or correct replacement |
5 | 7.04% |
Stock AM/FM radio, Telescoping mast - Know it's original or correct replacement |
5 | 7.04% |
Stock AM/FM radio, Telescoping mast - Don't Know if original or correct replacement |
5 | 7.04% |
Voters: 71. You may not vote on this poll |
#26 | |
![]() Join Date: Nov 2013
Re: Poll - Your Radio Antenna for 1971-1972 Chevy
I just put a telescoping antenna on my K/5......it's advertised as "correct" factory reproduction.....I'm really not too concerned about the "correctness" as long as it works...it fit right and looks good....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#27 |
Can someone post pics of the routing of the antenna cable? Or explain?...thanks
1972 k10 396 8" suspension lift 3" body lift - build in progress ![]() |
#28 | |
![]() ![]() Join Date: Feb 2009
• Feed the cable into the cab hole from outside the cab. The hole is approx. 1" below the windshield. There was approximately 14" of cable outside the cab. The cab uses a grommet, inserted from the outside. • The cable is retained by two rubber coated clips. These clip onto the ridge immediately below the glove box hole in the dash panel. Placement is approx. 1" inside each corner of the hole. The retainer portion faces the firewall and holds the cable down. The clips also retain the wire for the RH door jam.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-17-2017 at 02:04 AM. |
#29 |
![]() Join Date: Jun 2018
I replaced my Retrosound Classic digital radio with a “Antique Automobile” AM-FM slide bar radio, new center speaker and also replaced the antenna with telescoping antenna as I did not like the non-factory look (digital and that it covered all the opening) and was getting tired of the mast “springing back and forth” every time I went into/out of the garage.
After searching “Antenna” I found this thread to be the closest to the subject matter / question I have. Is the antenna I removed factory? …… see pics and information below. Part #’s on the nut: 3943656 and 181 300 Part #’s on the base: PMG 3979307 Fixed antenna: 31” long from tip of ball to the base of nut
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
#30 |
#31 | |
Part #’s on the nut: 3943656 and 181 300 Correct for low crown nut Part #’s on the base: PMG 3979307 I'll have to check, but your base looks right Fixed antenna: 31” long from tip of ball to the base of nut Couldn’t tell you The chrome bezel should be stamped 3898672. The ground “bezel” on that body slips off right? It’s part number 3898673, might be stamped.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#32 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Bringing thread back up. Just got my original AM Radio back after having it converted to AM/FM Bluetooth etc. There is a note from the builder, see picture, saying if I have the original AM telescoping antenna on my truck, and I do, that it should be replaced with a fixed AM/FM Antenna. so its been a couple years since anyone posted in thisthis thread so wondering if anyone in that time has come across and ideally a fix mast antenna that would replave the telescoping one on my truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#33 |
![]() Join Date: Dec 2013
This replacement from Goodmark looks and fits exactly like the original , it also has the gromet seal and clips for the lower dash to install like an original , Best price I found was thru summit . Read the reviews on the Summit page
![]() https://www.summitracing.com/parts/g...SABEgLwLPD_BwE
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#34 | |
#35 |
![]() Join Date: Dec 2020
my 72 Fremont built Cheyenne Super was a low miles,1 owner truck til me.it has an AM radio as per the build sheet,U63 P/Button radio and a telescoping antenna.the truck was in storage for 25 years and everything appears to be untouched.the cable to the antenna from the radio and routing don't appear to be altered or changed in anyway but i have no proof that it's original but it sure looks it.
#36 | |
#37 | |
Why wouldn't a fixed mast replacement install with your existing parts? Cosmetic? Unfortunately I don't have access to my truck for a pic. Corvette replacement: https://www.ebay.com/itm/39247236878...Bk9SR9zRovzcYQ Truck replacement, it would seem. Perhaps it would look odd with the tall nut, hmm. https://raybuck.com/product/1967-197...ed-whip-style/
#38 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Posting these instructions for fun.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#39 |
![]() Join Date: Oct 2009
all 71-72s I've had were factory am only radio trucks and all have had telescoping antennas (except for the occasional obvious retrofits by a PO of a horrible rubber antenna or a completely missing antenna). Unfortunately, I can't confirm any of the telescoping antennas were original, but when it comes to useful data, quantity has a quality all its own...
#40 |
![]() Join Date: Dec 1999
My 72 truck had the original AM radio when purchased in 98. A fixed antenna with a stock looking mount on cowl and spring in the mast. While I have an in-box NOS telescoping antenna in hand. Will be installing the reproduction fixed mast with the factory AM/FM I obtained years ago.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
