06-06-2016, 03:23 PM | #26 |
Re: GM Pulse Generator for electroc speedo
But an NV3500 already has a GM 40 pulse speed sender....
06-06-2016, 04:03 PM | #27 |
Will that work with the newer electric gauges?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-06-2016, 04:42 PM | #28 |
I haven't made the effort yet to get my two wire (yellow/purple) vss wires to the NVU speedo yet... was under the impression that i need the signal converter box SN74Z...
06-07-2016, 09:18 AM | #29 |
Are you trying to use the factory cable speedometer?
06-07-2016, 09:30 AM | #30 |
Nope, got a new NVU electric speedometer gauge
06-07-2016, 09:58 AM | #31 |
Then my signal generator will work for you.
06-07-2016, 12:13 PM | #32 |
NV3500 VSS has the 128000 pulse per revolution output same as this signal generator. No option for cable drive on NV3500.
06-07-2016, 08:05 PM | #33 |
so smart. thank you. I couldn't find the signal pulse that it had.
06-07-2016, 08:19 PM | #34 |
It's 40 pulse per driveshaft revolution and 128000 pulses per mile.
06-08-2016, 08:40 AM | #35 |
Good info! He should be able to just attach the wires to his speedo and Rock and Roll, .
06-08-2016, 09:19 AM | #36 |
Hart_rod, yes, I hope so, but little wire tracing for the pcm speed output to speedo i should be good. Thanks guys, and sorry to steal the thread man!
07-07-2016, 09:53 AM | #37 |
bump
02-06-2018, 04:29 PM | #38 |
DBW engines from 03 up use the 128K A/C VSS signal input. TAC module becomes cruise control from PCM via UART serial data. Two wire input to PCM on C1, cavity 21, VSS Low Circuit #821 (PPL/WHT). C1, Cavity 20 VSS High, Circuit #822 (LT GRN/BKL). Twist 9 time per foot to help reduce mutual induction. PCM VSS signal can be programmed to fit your speedo as VSS signal leaves PCM C2, cavity 10 (WHT) to speedo. Check your schematic and speedo requirements. TAC module uses B+ signal inputs for Cruise operation w/Drive-By-Wire (RPO Code-JK4) Just trying to be helpful.
02-09-2018, 02:03 PM | #39 |
The LS engine swap I have planned, is using an 2003 Gen3 5.3L truck engine. According to DD, SEN-01-128 produces an A/C type VSS signal required to allow my PCM to operated correctly. As an ASE Master Tech, if fixed stuff, not building from mixed parts. The PCM has two circuits VSS input with 822 (LT GRN/BLK) connector C2 (GRN) cavity 20 is VSS Low. Circuit 821 (PPL/WHT) connector C2 (GRN) cavity 21 is VSS High. With DD HF Sensor, would signal out go to PCM high? Would ground go to PCM low? Is this the correct method used to produce a 128K VSS input?
The PCM can be programmed to produce an output to match anyone's speedo, which is circuit 817 connector C2 (GRN) cavity 50 (DK GRN/WHT) is PCM buffered output to IPC, Radio and optional equipment like Rear Wheel Steering and Rear Object Sensor Control Module, via Splice Pack. On my 03" donor, the PCM uses C2 (GRN) circuit 821 cavity 49 (YEL/BLK) is used to provide VSS input to the ABS module, that I will not be using. I am just trying to follow along to make sure I get this straight in my head first...before the wallet opens. |
02-09-2018, 04:40 PM | #40 | |||
Also, I don't know if you realize it, but you're posting your questions in the LS classified section. You'd probably get quicker response in the LS engine swap forum. |
02-09-2018, 06:06 PM | #41 |
Thank you dayj1.... Yes, there are various forum locations that this exact question could have been posted. I am learning on line as I did every day when I opened my tool box to make a pay check. However, with this exact part is offered, I had research it and found the PDF lacking information...and so did the phone call I made to them. As with all things, if you are not learning something new, it's a boring day. If you're not researching (or asking), you bound to make mistakes. my wallet can't afford mistakes anymore. Thanks for pointing that out. I am new to forums, don't own a cell, and this build will be my last...for me, a simple daily driver 67 C10 longbed / w/wood!
