Old 02-06-2016, 12:52 AM   #26
mattcrp1
mattcrp1's Avatar
Re: Everyday stock 5.3 swap into 87 r10 swb
I ran my dorman lines in some of that summit heat sleeve. the nylon line is what the manufacturers use and there are a lot less issues with the fittings. If you have the plumbing there already you can just put the higher pressure fuel pump in and adapt the lines to your new set up.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-17-2016, 04:33 AM   #27
Fishjeepchevy
Do I have to use a shallower oil pan??? the truck is already lowered. And for a timeless question onthese swaps. What headers can I use that aren't outrageous but will work good and not completely dirt cheap
Fishjeepchevy is offline   Reply With Quote
Old 02-17-2016, 09:16 AM   #28
MalibuSSwagon
My C10 is dropped with 2.5 spindles in front and I'm running the truck pan, it hangs about an inch below the crossmember.
MalibuSSwagon is offline   Reply With Quote
Old 02-17-2016, 04:09 PM   #29
mattcrp1
mattcrp1's Avatar
My 76 is low as well and I just ordered the cts-v pan today. I cant even get out of my driveway with out hitting.
IG mattcrp1
Old 02-17-2016, 04:10 PM   #30
Fishjeepchevy
Is it like a 4/6 drop or a 2/4 or whatever
Old 02-19-2016, 03:32 AM   #31
Fishjeepchevy
Any suggestions on headers or manifolds that will clear
Old 02-20-2016, 10:05 PM   #32
wingnut78
I used a cts-v pan as well. My truck is lowered 4/6, the pan comes to the bottom ofor the crossmember. I believe the 4th Gen f-body pans are even more shallow than the cts-v, but not 100% certain.
I'm using Schoenfeld headers for a 1988-98 truck. They're about $300 from Summit. They fit well and I did need to trim about .25" on driver's upper frame rail for one tube. Also, using the dirty dingo mounts and sliding the engine back as far aft as I could made the passenger tube come close to the firewall, but no modification was needed there.
I've heard that tbss and 2010 camaro manifolds will work also, if you're not wanting headers.
Josh
wingnut78 is offline   Reply With Quote
Old 03-10-2016, 05:14 PM   #33
Fishjeepchevy
I forgot how to put up a picture but with the stock linkage on the 2004 4l60 what position is park
Old 03-10-2016, 05:17 PM   #34
Fishjeepchevy
Old 03-10-2016, 05:18 PM   #35
Fishjeepchevy
https://goo.gl/photos/yedbEV3CTk2rBUDF7
Old 03-11-2016, 02:07 AM   #36
Fishjeepchevy
I finally bought most of the swap items
schoenfield long tubes
Dirty dingo mounts
5qrt pan from summit
LS-Line-Kit
Intake gaskets
Spectra sending unit FG05m
Ep381 fuel pump
A lokar style shift linkage kit (cheaper than lokar on summit)
Evap plug
And I also ended up with an auto rod control: model 4000 that I have no idea what to do with
Old 03-11-2016, 06:19 PM   #37
BCKRedBaron
Let us know how those Schoenfeld headers fit. I had considered a set of those before buying shorties.
Two '87s and a '98 S-10
BCKRedBaron is offline   Reply With Quote
Old 03-11-2016, 06:32 PM   #38
Fishjeepchevy
Test fit the driver side not in the truck and it's nice but we'll see when I get it all in the truck how it clears the frame
Old 03-14-2016, 04:16 AM   #39
Fishjeepchevy
. Got the engine in sadly one of the long bolts that came with my dingo mounts stripped half way and ill probably start on fuel delivery next. The 5 qrt muscle car series oil pan fits nice btw
Old 03-15-2016, 03:05 AM   #40
Fishjeepchevy
Old 03-15-2016, 03:05 AM   #41
Fishjeepchevy
https://goo.gl/photos/iM2VnJ9KKdTfHBmv8
Old 03-25-2016, 09:16 PM   #42
Fishjeepchevy
https://goo.gl/photos/HTVhMi2oeGFMzyMh7
Is this the senors 2 bank1 plug
Old 04-28-2016, 11:09 PM   #43
Fishjeepchevy
After a while battling some wiring and common little things it fired right up used a surge tank from a late model truck and filled the system from there. scanned it and it had a knock sensor bank 2 circuit low signal. What would be the deal on that it also threw both o2 sensor heater codes and both o2 sensor inactive codes. When i started it an ran it for a while it had kind of a high idle with minor fluctuation but I cleared it out and it idled down to 600-700rpm
