Old 02-11-2016, 09:14 AM   #26
aboesec10
aboesec10's Avatar
Re: Not enough heat out of a vintage air gen IV system
having this issue on mine as well, I've switched the hoses around on the water pump as they both attach there on my engine. no change. Ive programmed a couple of times but maybe its still not opening up? Ive also got issues with the vents changing to the dash setting. Works great on defrost and floor minus being warm at all.
aboesec10 is offline   Reply With Quote
Old 02-11-2016, 09:17 AM   #27
aboesec10
aboesec10's Avatar
if I've got the hoses backwards on the heater core would that kill the flow of water? I've felt the lines several times at with temp gauge at 200, their both warm for about a foot then cool off greatly, It acts as if theres no flow whatsoever.
Old 02-11-2016, 10:08 AM   #28
Longhornss
It does not matter what port on the heater core the valve is plumbed into.
The valve depends on the high/low side. In VA case they say the valve should be in the hose going to the intake.
In the case of an LS Swap which is not called out they say the valve should be in the water pump in the line closest to the engine block.
Longhornss is offline   Reply With Quote
Old 02-11-2016, 10:13 AM   #29
aboesec10
aboesec10's Avatar
cool, I'm pretty darn sure thats the one I've got it plumbed into. Ill double check this evening. Maybe ill try to jump the control valve with 12 volts and see if that opens it up
Old 02-11-2016, 10:20 AM   #30
Longhornss
Which control panel are you using? is it a factory panel that was retrofitted with VA Cable converters? If this is the case it sounds like you may have a wire crossed on the converter.
The Temperature Cable converter should be connected with the White/Red Wire
The Dash, Floor, Defrost should be White/Yellow
Old 02-11-2016, 10:33 AM   #31
Longhornss
IF you have a 2 wire control solonoid you can trigger it with 12V and ground you will hear the valve clicking.
the new plastic style 3 Wire may be a little more difficult.
honestly the best way to check if the valve is working is to feel the hoses going into and out of the valve when set to heat mode. Is there a Temperature differential? If there is then there may be an issue with the valve being stuck closed. In which case I MAY try manually over riding the valve to see if that helps.
If you do all this and are still having issues call Vintage Air. Their tech guys are great and know their products.
Old 02-11-2016, 02:19 PM   #32
67ChevyRedneck
67ChevyRedneck's Avatar
Isn't that because the LS engines use a "reverse" waterpump?
Originally Posted by Ken J Martin View Post
Well turned out to be a defective thermostat.
Thanks again for all the suggestions.
That's great! So how's the temp now? I have GEN I VA system with cables I installed in 2006 It gets hot as crap.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-11-2016, 11:23 PM   #33
aboesec10
aboesec10's Avatar
well i checked all wires and their correct. I am running the cable converters and their in the right location. Im gonna call v/a in the morning and get some advice.
Old 02-14-2016, 10:28 AM   #34
aboesec10
aboesec10's Avatar
i got it figured out, the plug where the red/green wires plug into the harness to the solenoid, black, blue, red and a white ground. I didn't have the plug locked into place...... plugged it all the way in and bam..... stupid boo boo
