02-17-2016, 07:48 AM | #26 |
Re: New Entropy Radiator that DOESN'T FIT
I installed an Entropy radiator in my truck and had some fitment issues with the height also. I learned just like the upper mounts are different for larger radiators, so are the bottom mounts. These radiators require the larger mounts on the bottom also. So if your radiator support has the smaller mounts they need to be changed. I replaced mine and it made it much better but was still tight, but worked. Hope this helps.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
02-17-2016, 02:17 PM | #27 |
I was thinking the same thing! I paid about half of that for my BeCool direct fit radiator and felt worked over after forking over that cash. But now I don't feel so bad. It too required a little massaging of the mounts to fit properly. But it cools like a monster.
02-17-2016, 02:54 PM | #28 | |
Yeah not sure on that price, I paid around $600 for mine with the fans & controller. It does look like he's using it for a diesel set up so maybe it was custom ?
02-17-2016, 08:45 PM | #29 |
http://67-72chevytrucks.com/vboard/s...=693824&page=2
Looks like your not the only one with problems. Post 32 mentions how his is too short.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-17-2016, 09:32 PM | #30 | |
The tri flow part adds some to the price and the fancy controller module to turn on the fans at a certain temp
1968 GMC 1 ton 4*4 with Detroit Diesel 6v53t 9ft stepside 1978 Chevrolet C50 350sb 8ft fleetside |
02-25-2016, 03:08 AM | #31 |
Moderator
Update. I received and mocked up the Champion CC369. It is a 3 core replacement, 1/2" shorter than my OEM Harrison radiator, other than that identical in measurements. I cut some strips of rubber from an old radiator hose and placed them in the saddle mounts underneath the regular rubber inserts to "snug it up". It fits perfectly and the OEM shroud and fan line right up. All aluminum Tig welded. $227 shipped to my door. Just waiting on some other parts before I button everything up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-25-2016, 08:07 AM | #32 | |
Posted via Mobile Device |
02-25-2016, 08:20 AM | #33 | |
Scott |
02-25-2016, 08:48 AM | #34 | |
Still Learning
I hope you get this resolved. It looks like to me you could trim the upper blocks that the rubber sits on top of. Maybe the bottom too? |
02-25-2016, 11:59 AM | #35 |
I once bought a radiator for 2700 bucks. but it came with a the rest of the truck too.
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
02-28-2016, 01:25 AM | #36 |
Yall can call me crazy but this was in theory the one for my truck. If this motor gets over 220 degrees it doesn't go so well so i went with a quality product. I did just find out that the sent my money back but i still have this radiator.
