Old 02-20-2016, 01:15 AM   #26
sharkskinman
Re: 283 & 327 for one low price!
http://www.jegs.com/i/JEGS-Performan...rentProductId=
120$
sharkskinman is offline   Reply With Quote
Old 02-20-2016, 01:16 AM   #27
sharkskinman
For truck 120$
Old 02-20-2016, 02:08 AM   #28
Captainfab
60-66 Nut
Those may or may not work if you are running a manual trans.
Old 02-20-2016, 03:31 AM   #29
sharkskinman
283 came out of a 64 chevelle sat in barn most of its previous life last tag said 79
Motor is "stuck" and I know 1 valve didn't return when smacked with hammer
Hoping its going to be a ring and not a crank bearing
Most bolts so far are coming off easy(2 carb studs.towards front. are all by gone but threads in nuts)
And only 2 on intake that are rusted 1 of which I can hopefully get and Not have to cut n deal with
I'm hoping it will be a simple take apart, mild checking(replacing if needed) but wishing for a simple honing and rings ..probably machine the seats/guides for unleaded
Definitely need another carb
Powerpack heads?
Turbo-fire?
Old 02-20-2016, 06:45 AM   #30
WOLFMANmike
WOLFMANmike's Avatar
Powerpack heads?
Turbo-fire?
if that motor has been out in the elements and sitting the long ? trust me on this . take your time pull it apart take the block down to the machine shop get her hot tanked clean all oil ports put in new freeze plugs get the crank cleaned up . buy new bearings rod and crank buy a new oil pump .. and yes get the heads done for unleaded gas also a nice re surface .... since that 327 is such a rare breed you want to do it right and make it last
WOLFMANmike is offline   Reply With Quote
Old 02-20-2016, 10:13 PM   #31
Monte's62
X2 on Wolfmans comments. Tank it and get everything clean in those water jackets.
Monte's62 is offline   Reply With Quote
Old 03-02-2016, 11:28 PM   #32
sharkskinman
283
All bolt so far have came off without struggle
Heads n intake already off
Will take pics of piston heads n such tomorrow
Had water in oil pan but still had prob 4qts oil On Top of that
Got it to move via screwdriver n hammer to the flywheel
Will motor turn by starter if bolted on?? (probably make small portable start stand)
Old 03-03-2016, 01:38 AM   #33
Captainfab
60-66 Nut
That engine needs to be torn down and rebuilt.
Old 03-03-2016, 02:35 AM   #34
WOLFMANmike
Xs 2 on Captains post .... that poor engine she needs some love rip it down bare and get it hot tanked ... get a parts washer and some Chem Dip and start cleaning while block is in the shop . that engine should not be run again till all of that has been done
Old 03-05-2016, 01:10 AM   #35
60chevyjim
60chevyjim's Avatar
I would open up the 327 too .
if your going to spend the money to build a engine in that condition
I would put the money in the 327 before putting that much money in the 283.
60chevyjim is offline   Reply With Quote
Old 03-05-2016, 04:09 AM   #36
WOLFMANmike
agreed
Old 03-06-2016, 01:10 AM   #37
Captainfab
60-66 Nut
X3 on building the 327.
Old 03-06-2016, 03:41 AM   #38
sharkskinman
Tomorrow I'm going to put things back on 283 and swap it out on the stand for the 327
Try to start to tear it apart or at least soak bolts in ATF for a day
While taking it apart I'm Going to get a 250 piston and swap out my #1 on my I6
Question?? I can take mounts, clutch bar to block, and trans mounts loose (or off) and tilt the engine up enough to get oil pan off and get to #1 rod bolts,yes??
Still has power , psi is always around 20 warm and she doesn't get hot but damn she smokes like a freight train
Should be ordering piston in this next couple days to swap out next sun n Mon hopefully
