Old 03-11-2016, 11:35 AM   #26
Bomp
Bomp's Avatar
Re: The Disco Chicken
Have my attention.
Can you post (lots of pics) of wiring and what goes where?
Bomp is offline   Reply With Quote
Old 03-11-2016, 05:53 PM   #27
mikentosh
mikentosh's Avatar
Nice looking dually! I like the MAST Motorsports front plate 😊
mikentosh is offline   Reply With Quote
Old 03-12-2016, 02:34 PM   #28
918733
I see I have some people watching I hope I don't disapoint anyone, The Mast Motor Sport plate was on there because My buddy that I got the truck from works for Mast, From what I understand the wiring is supposed to be simple it has to have an external regulator for the alternator because the original was controlled by the computer, but of corse after buying a regulator I found a conversion kit for the alternator, and I'm using the Dodge A518 overdrive trans which was also controlled by the computer so I bought a contraption that is supposed to make it work, and for motor mounts there appears to be 3 kinds 1. 4x4 mounts 2. mounts that bolt to the block then to the chevy frame mounts 3. and the ones I bought which bolt to the Chevy frame and to the Dodge isolators and engine motor mounts and they are supposed to keep the oil pan flush with the cross member, Gonna use the Dodge radiator, intercooler, and a/c condenseor and only minor beating of the fire wall and reshaping of the pinch weld on the trans tunnel but that is using an adapter plate with Chevy trans so I don't know if it will be better or worse but it's nothing that hasn't been done just maybe not all at one time
http://67-72chevytrucks.com/vboard/s...d.php?t=616455My 55 first series build
918733 is offline   Reply With Quote
Old 03-13-2016, 01:35 PM   #29
Zane M
Awesome truck! Looking forward to future updates.
Zane M is offline   Reply With Quote
Old 03-23-2016, 07:41 PM   #30
918733
Well made a tiny little bit of progress yesterday hopefully things will start picking up steam I think we are going to take 2 inches out of the oil pan for a little extra ground clearance so stay tuned
Old 03-23-2016, 10:39 PM   #31
daddyjeep
daddyjeep's Avatar
Cool. We like progress.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-23-2016, 11:15 PM   #32
RDrancher
RDrancher's Avatar
Hey, progress is progress and that's what it's all about.
Romans 10:9 - The Truth
RDrancher is offline   Reply With Quote
Old 03-25-2016, 12:04 AM   #33
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Your further along then I am on my truck and I've owned it for 3 years.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-03-2016, 10:08 PM   #34
918733
Well change of plans gonna sell the 5.9 and find a 6.0 and 4l80 I can pretty much do that on my own I'm ready to get this truck back on the road
Old 04-04-2016, 09:34 AM   #35
aggie91
I'm just glad to be here!
aggie91's Avatar
Darn...was hoping to see a 2wd Cummins swap...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-14-2016, 11:17 AM   #36
918733
The motor is just sorta sitting there right now should be there permanently by the end of the day
Old 05-16-2016, 10:05 AM   #37
aggie91
aggie91's Avatar
back to the cummins? Did you get any progress pictures? I would like to see a pic of the mounts you used.
Karl
The LST Challenge:
Old 05-18-2016, 10:20 PM   #38
918733
I found another problem and I'm wondering if anyone could help identify what this mess used to be
Old 05-20-2016, 05:33 PM   #39
aggie91
aggie91's Avatar
That looks like the idle solenoid and relay for when the AC comes on. The rod in the solenoid would push on the throttle lever on the carb when the AC was turned on.
Karl
The LST Challenge:
Old 05-21-2016, 09:55 AM   #40
918733
This is weird the a/c worked great I don't know if I should do away with it or what.
Old 07-29-2016, 08:49 AM   #41
aggie91
aggie91's Avatar
I saw a truck this same color combo with a cummins swap pop up on facebook for sale...Is it yours?
Karl
The LST Challenge:
