02-23-2016, 07:08 PM | #26 |
Re: 4l80 and headers?
Thy-323y-c are the headers I have with the interference I mentioned above
I actually wanted the floor shift originally but decided to try to save some money with column shift. |
02-24-2016, 02:18 AM | #27 |
I did some searching and another member posted a exit photo of his 323's on a 6l80e. Not sure if the 4l80E is as wide as the 6l80E
Tony, do your headers exit at the same angle? |
02-24-2016, 02:20 AM | #28 |
Another but of the 324's doug thorley header exit angle
02-24-2016, 03:48 AM | #29 |
Old member
The transmission is a 4l80e in my truck. Here is the link for the headers.
http://www.hawksthirdgenparts.com/ha...w-3-collector/
02-24-2016, 09:57 AM | #30 |
I'll see if I can get a good shot of where they exit in the next day or two.
02-24-2016, 10:10 AM | #31 | |
Even the cable style will have to be attached to the trans before header is in place, there just is no room with the exit location of the header.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
02-24-2016, 10:17 AM | #32 |
02-24-2016, 10:25 AM | #33 |
Boosted Member
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
02-24-2016, 01:25 PM | #34 |
Ha Ha that would do it. I don't see any clearance issues now?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-24-2016, 01:31 PM | #35 |
Boosted Member
Exactly.
02-24-2016, 11:12 PM | #36 | |
02-24-2016, 11:31 PM | #37 |
I had pacesetter TBSS headers on mine and they fit fine with the ear trimmed and a Lokar linkage kit.
Wasted's solution is the better idea though.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's. 68 Charger R/T - #'s matching 440/auto car, 499/727/3.91. 68 GTX - 440/4-speed, Dana 60. 44,000 miles. 71 SWB C10 - LQ4+S476r 06 Duramax - LBZ - Exhaust, EFI Live, etc... |
02-25-2016, 03:00 AM | #38 |
meowMEOWmeowMEOW
Wasted; man, I don't think that power steering res location is going to work
02-25-2016, 03:45 AM | #39 |
Old member
Yes that's the ones I used. Hawks recommended them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 02-25-2016 at 03:55 AM. |
02-25-2016, 03:32 PM | #40 |
Does anybody have any experience running the new Camaro exhaust manifold with a 4L80e
Seems like the cheaper route at the moment |
02-26-2016, 03:34 PM | #41 |
I'm not sure how much performance is lost when going with exhaust manifolds over headers? Is it is noticeable difference?
I have found some camaro exhaust manifold take offs for $125 shipped. For anyone wondering they are GM part number: RH side 12611639 LH side 12611638 Here are some pictures I found of them mounted to someone else LS style motor. Do they look like they will work? |
02-26-2016, 04:52 PM | #42 |
if there was nothing to be gained the manufactures would not be making them.
02-29-2016, 03:04 PM | #43 | ||
Boosted Member
Does that remain true for these gems?? lol
02-29-2016, 04:01 PM | #44 |
02-29-2016, 10:29 PM | #45 |
Hey andydo you have any clearance issueses with the one piece driveshaft. Trying to decide which way to go one piece or the orginal.
