Old 02-27-2016, 07:26 PM   #26
WOLFMANmike
WOLFMANmike's Avatar
Re: L.E.D. dash lights
Originally Posted by Slambone View Post
When I did my cluster I painted the inside of the housing white. Also I modified the harness to accept 4 more bulbs. So I have 8 for the back lights and the 3 for the turn signal and bright. I'll download a pic of mine in my truck at night. It's very bright! I like it that way too. They don't dim though
OK that would be great thanks .... yeah I all ready did a hi gloss white in my cluster. Do you have pics of your extra bulbs mod to ?
WOLFMANmike is offline   Reply With Quote
Old 02-27-2016, 07:48 PM   #27
WOLFMANmike
here is mine
Old 02-27-2016, 11:14 PM   #28
Mathew21
Mathew21's Avatar
Thanks for posting up the link for the bulbs. I ordered and found them in my mailbox two days later.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 02-29-2016, 07:37 AM   #29
WOLFMANmike
Heya Slambone were you able to get that pic up loaded yet for me ? And also did you have pics of your extra bulbs mod ?
Old 03-03-2016, 06:50 PM   #30
Chevy Fleetside
Chevy Fleetside's Avatar
I installed mine today. Picture doesn't do it justice on the reg bulbs.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 03-05-2016, 02:38 AM   #31
Ghernandez66
Ghernandez66's Avatar
Just installed my new dash with the LEDs looks great..
Now does anyone know the bulb size of the parklights?
My 1st build 1966 C10 Swb ..http://67-72chevytrucks.com/vboard/s...d.php?t=668147
Ghernandez66 is offline   Reply With Quote
Old 03-05-2016, 04:23 PM   #32
chevy2tom
chevy2tom's Avatar
Just ordered mine
chevy2tom is offline   Reply With Quote
Old 03-05-2016, 04:27 PM   #33
WOLFMANmike
Mine will be delivered today
Old 03-06-2016, 03:33 AM   #34
WOLFMANmike
Did mine today ... very happy with the results
Old 03-07-2016, 08:30 AM   #35
corvettejim1968
corvettejim1968's Avatar
i took mine apart and sadly there is no lighting from the factory on my column
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 03-07-2016, 12:26 PM   #36
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
http://67-72chevytrucks.com/vboard/s...highlight=auto
66 C20 Service Truck:
Old 03-07-2016, 08:56 PM   #37
T and S
T and S's Avatar
will these also work with a warning light dash (no gauges) ?
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 03-07-2016, 09:32 PM   #38
ray_mcavoy
Yes, the cluster back-lighting is basically the same for gauge & warning light clusters. The bulb count & location vary, but electrically they're the same.
However, you have to watch out for the polarity if you're using LEDs to replace the actual warning lights. The "oil", "hot", and "cold" lights all have ignition power fed to one side of the bulb. And the switches on the engine ground the other side to illuminate the bulbs. If the polarity of the LED is backward compared to how the socket is wired they won't work.
Also, an LED probably won't work correctly in the "gen" light because that one is wired in parallel with a 10Ω resistance wire.
ray_mcavoy is offline   Reply With Quote
Old 03-07-2016, 10:23 PM   #39
Backpayne
Just ordered a set! Thanks for the ebay item number.
Backpayne is offline   Reply With Quote
Old 03-08-2016, 05:18 AM   #40
Cooper197
Cooper197's Avatar
If you want dimmable LED's, usually the best way is to use strip lights. You just have to run them around the inside and stick the wires out one of the holes, then seal it all up. Hook up the power and ground and you'll have LED's that work on the dimmer switch.
Also strips will help eliminate any 'hot spots' or areas around the bulb that appear brighter than the rest of the cluster.
No pics as I haven't done mine yet...
Cooper197 is offline   Reply With Quote
Old 03-14-2016, 07:46 PM   #41
Chance66C10
Thanks for the Tip! I just finished installing the new LEDs.
1966 Chevy C10 SWB
Chance66C10 is offline   Reply With Quote
Old 08-08-2016, 10:31 PM   #42
awitate
I got a set of LED's from the suggested ebay vendor all the bulbs worked except the turn signal inicator light only works for "right" I switched it back to the original bulb and both sides work. I tested the wires they both work. Is it a matter of getting a specifically designed LED bulb? or is that just a bad bulb?
awitate is offline   Reply With Quote
Old 08-08-2016, 10:35 PM   #43
WOLFMANmike
Bad bulb but check it anyway put it in the other blinker side that is working and if it works then your issue is not the bulb ... but I'm betting a bad bulb
Old 08-08-2016, 10:45 PM   #44
awitate
I should have clarified, I have a '63 and it only has 1 indicator and it flashes for either side.
Old 08-08-2016, 10:56 PM   #45
WOLFMANmike
OK still easy just do it in a working socket any way and check the bulb that way like a socket that is for the cluster lights
Old 08-09-2016, 08:02 PM   #46
ray_mcavoy
That single turn signal indicator setup is going to present an issue when using an LED in that location.
The single indicator is wired across the left & right signal light wires so the active signaling side is positive and the inactive side provides the ground. As a result, the polarity at the indicator bulb changes with the direction. And as I mentioned earlier, LED's (being diodes) are polarity sensitive so that's why yours is only working when indicating a right turn.
Now, there is such a thing as a bi-polar LED that will light up with current flowing in either direction. It's basically two LED's connected anti-parallel inside the same package. Many of them are bi-color as well, lighting up red in one direction and green in the other for example. However, I'm not sure if anything like this is available in a package that will plug directly into your existing indicator socket. But you might want to check with the vendor where you bought your LED's to see if they do happen to offer one. Something like that would be perfect for that type of single indicator application.
Old 08-09-2016, 09:05 PM   #47
awitate
Thanks for the info! I had a feeling the LED bulb would be problematic.
Old 08-09-2016, 11:10 PM   #48
Tazimafied
I was taken to school about this in another thread here. The best suggestion was to hook the LED to a proper ground then attach a diode to each of the two wires for the indicator then to the positive of the LED. This makes the light work for both sides and the diodes keep power from backfeeding through the system due to the lack of resistance from not having the incandescent bulb.
Link to the thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=711842
Tazimafied is offline   Reply With Quote
Old 08-11-2016, 01:04 PM   #49
WOLFMANmike
what about just useing all the LEDs and then only the incandescent bulb just the the turn signals ??
Old 08-18-2016, 09:27 PM   #50
contagious102
contagious102's Avatar
Thanks for the tip, got mine installed tonight. Looks much better.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
