#26 | |
Re: New Project = New problems 1964 K-10 Ebrake
#27 |
So I took some pics today and they came out awful. My phone takes better pics but I can't figure out how to resize them. Next best thing is a sketch. Here's what I got before it started raining today. I can get more detail when it stops in a day or so.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
#28 | |
#29 |
Finally got around to building the E brake brackets on the weekend. Turned out pretty good and it works now. The only issue I ran into is that the rear brake cables could be about an inch longer I managed to hook them up but I had to use the hole I drilled for a return spring on the lever not the center hole so its a little off and pulls more on the right cable.
#30 |
TANDAMAN--can you post up a pic of how the cross member bolts to the frame? Is it the right with?
1961 chevy K10 my build is------------61K10 build |
#31 | |
#32 |
I will probably just make a longer bar that goes from the cables to the lever.[/QUOTE]
This is exactly what I have done to accommodate the previous Dana 60 and now the 14 bolt with the discs. It has worked pretty well. I think that my bar has close to a dozen holes from the different adjustments over the years.
#33 |
Thanks TANDAMAN,
Just spoke with Inline Tube and got the ebrake cable ordered, I was wondering if I was going to be able to find them. Thanks again.....
KippnIdaho Twin Lakes, Idaho 1966 K10 SWB Stepside 2003 Jeep Rubicon 2011 Camaro SS Rag Top |
