Old 04-05-2016, 09:40 AM   #26
Rod Run
Rod Run's Avatar
Re: Vintage Air & smooth firewall question
Originally Posted by Zeroman View Post
Thanks, Rod Run.
I PM'd you.
Hope you have a good Autorama.
I mailed out your template. hope it helps
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 04-05-2016, 01:08 PM   #27
Rod Run
Rod Run's Avatar
Originally Posted by Raleighswb View Post
Truck is apart lines run out bottom of cowl lay on top of inner fender,they are hidden behind the area where the inner fender bolts to the fender here is the area at the bottom of the cowl where the bulkhead is located lines go from the unit through the fresh air vent---then you fab up something to close up that area around the lines hope this helps I ordered all my hose ends from summit
One quick question. I was about to drill out the holes like you did, but I was wondering......
How hard was it to tighten the fittings in that cramped space? I had already blocked off most of that area, by welding it shut, so I will have to open it back up again. not a huge deal, but just want to see if you think it will be worth it
Also, what type of fittings did you use near the inner fender (straight, 45*, 90*) etc?
thanks for the help
Old 04-05-2016, 03:54 PM   #28
1moretoy
inside
I'm currently doing the same thing but without a bulkhead. I'm just drilling a hole and using a rubber grommet. I didn't want to deal with trying to tighten the fittings inside the fresh air vent(small spot). And that way there are less connections for possible leaks.
1moretoy is offline   Reply With Quote
Old 04-05-2016, 04:07 PM   #29
Rod Run
Rod Run's Avatar
Kind of what I'm thinking too. Just have to make sure to put the grommet on before getting the ends crimped on the hose.
Old 04-05-2016, 04:14 PM   #30
1moretoy
Vintage air has their EZ A/C lines that are smaller diameter that allows for tighter bends and smaller holes to drill plus you can fabricate them on your own. No hose shop necessary.
Old 04-05-2016, 04:43 PM   #31
trkfrk
trkfrk's Avatar
Subscribed. Good thread, I am ordering my unit next week. My firewall is shaved/painted.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-05-2016, 04:48 PM   #32
1moretoy
Here is a picture of my firewall. I'll take a picture later of how I mounted my evaporator. I'm using a unit from classic auto air but it's the same concept.
Old 04-05-2016, 07:19 PM   #33
aboesec10
aboesec10's Avatar
I did the same thing running everything through the kick vent, my firewall was already shaved and painted so i had to add the one bolt that holds the main unit in. I hung the unit in the cab then marked and drilled the hole from the inside. Once installed i painted the bolt....
c10clubtexas
aboesec10 is offline   Reply With Quote
Old 04-05-2016, 11:16 PM   #34
1moretoy
Here is how I installed the evaporator. I used thru bolts in the cowl into a couple of strut angle brackets and welded nuts to them. Kind of hard to see but it's the best picture I could get.
Old 04-05-2016, 11:56 PM   #35
Rod Run
Rod Run's Avatar
That was a great idea too.
Old 04-06-2016, 12:55 AM   #36
Ta12sec
Sorry to hijack this but im playing with some ideas on my 72 anybody have a vintage air unit they could measure the Evap unit? Or if someone could even just measure the distance from the bottom of the dash to the firewall that would be great too, my trucks 30 miles away and that makes it all so hard to get done
Ta12sec is offline   Reply With Quote
Old 04-06-2016, 08:33 AM   #37
Willie Makeit
Willie Makeit's Avatar
vintage air provides dimensions on all of their evaporator units on their website.
Willie Makeit is offline   Reply With Quote
Old 04-06-2016, 08:40 PM   #38
Raleighswb
The bulkhead comes apart so you can connect the inside hoses one at a time starting at the lower one first,will get you some more pictures this weekend. I used the search option on the center top of the forum and typed in hidden ac lines gave me the idea,lot of good information.I found that the time it took to go through the information slowed me down so I could make a clear choice,so my advice to anyone out there is don't be in a hurry.These trucks take patience,money and time but are well worth it,I'll check on the fittings for you.
Raleighswb is offline   Reply With Quote
Old 04-06-2016, 08:43 PM   #39
Raleighswb
Thought about this but I wanted my inside unit to be as far to the right and as much out of sight as I could.
Old 05-06-2016, 11:25 AM   #40
Scott2
I'm also close to ordering a VA unit and plan to eliminate the holes and bolts on my firewall. I'm thinking about using these:
http://www.mcmaster.com/#carriage-bolts/=12akqzc
I can weld these inside wherever needed and they have a couple different types. I saw this somewhere, maybe a magazine install ?, and thought it was a good idea.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 05-06-2016, 12:43 PM   #41
Rod Run
Rod Run's Avatar
Where its in a hidden area, you can just weld the regular bolts in and you don't have to worry about ordering anything, plus the bolt heads gave me plenty of meat to weld onto
Old 06-06-2018, 12:31 PM   #42
crakarjax
crakarjax's Avatar
inside
Sorry to resurrect this old thread, but does anyone have more details/pics on how they plumbed the lines through the fresh air vent? Also helpful would be a rundown of the parts required to do so. Thanks in advance!
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 06-06-2018, 01:29 PM   #43
trkfrk
trkfrk's Avatar
Here’s a couple of pics how I routed my lines. I avoided the fresh air door. It’s more work but I’m really pleased with the results.
Old 06-07-2018, 11:47 AM   #44
crakarjax
crakarjax's Avatar
Ah, interesting approach! The thing I mainly can't wrap my head around is getting the plumbing into the fresh air vent without creating interference in the passenger footwell but your approach seems to bypass that concern.
Old 11-21-2018, 10:24 PM   #45
57larry
does anybody have a template of the AC firewall hole. my firewall is bare & I'd like to cover the hole with a plate.
thanks, Larry
57larry is offline   Reply With Quote
