Old 05-06-2017, 07:09 PM   #26
Bears63
...just another truck junkie..
Bears63's Avatar
Re: Grandpa's C10 Silverado Restoration Project
It is a nice looking truck and would look better with white letters out on the tires. Just my opinion, of course. Enjoy that rig! The family history makes it priceless.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 08-02-2018, 07:37 PM   #27
ninety6
Finally got my hands back on this and knocked a couple things off the list.
Swapped the tires to white letters out. Looks much better!
And revived the AC last weekend! New compressor (man it was hard to fine the right one -- there are so many different R4 compressors!), new accumulator. Was going to install a new orifice tube -- but had a bit of an issue. The line was actually bent where the tube was, so i had trouble getting the new one in. I pinched it a tad trying to straighten it out, making the problem worse. I ended up breaking the new orifice tube, so i cleaned and reused the old one. It was in good shape, just a little gunked up. Cleaned it up, dremeled it down a tad to fit into the tube (the seal is unaffected), popped it in and sealed her back up.
Vacuum tested and recharged with R134a and PAG oil, and blows about 50 degrees (it was 80 or 85 outside). A little cooler when driving and getting some air to the condenser.
I did have to adjust the low-pressure switch. I adjusted 1/8 of a turn for a couple less PSI. It was kicking off on a cooler day when hitting the throttle. Seems to be holding a charge.
Oh, one other hiccup -- the new brand new compressor (4-seasons) had the clutch spring on too tight -- ZERO air gap. So had to borrow the tool from Advance Auto to put a little air gap in it. It was making a bunch of noise -- now running perfect.
ninety6 is offline   Reply With Quote
Old 08-02-2018, 11:33 PM   #28
MTCK
MTCK's Avatar
Truck looks great. Nothing better than cold AC on a hot day.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-03-2018, 01:37 PM   #29
Whamo
Whamo's Avatar
Good stuff!
Just a Hillbilly in the Hood
http://67-72chevytrucks.com/vboard/s...d.php?t=622194
Whamo is offline   Reply With Quote
