#26 |
Re: ENGINE - to Scrap or not to scrap
Shame we didn't meet at the NSRA meet, no problems drop me a pm any time. Andy
my rides 59 GMC Apache fleetside http://67-72chevytrucks.com/vboard/s...d.php?t=684337 68 VW Westy camper |
#27 |
Ubercool - PM sent!!
#28 |
Cleaned up and checked the heads for cracks it looks like I've a crack free head - just a crack in the block...
which is good news, and not a complete junker!! ![]() Last edited by Hansome; 04-05-2016 at 04:13 PM. Reason: add pic |
#29 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
That is good news
#30 |
indeed... i initially brought it for the Head so i could port and open up the head for breathing/bigger valves. but thought it would be easier to build a whole new engine out of the truck so no down time and swap it over.
its cleaned up good, no visible cracks i should say - need to get it magna fluxed still to be sure. Its had 2 of the exhaust valve guides replaced but thats all. just need to deal with the block issue ..... ![]() |
#31 |
What about first getting a piece of scrap cast iron to practice on for amperage, type of rod etc.
#32 |
did you check the top side of the head? specifically by the left front head bolt hole and where the t/stat adapter bolts.
#33 |
It would appear that there is something of a strong UK presence in the 60-66 forum
![]() I've not long pulled a good strong 230 (pretty sure it is not a 250 and didn't bother to check) out of my '63 as I picked up a 292. It's on RnS. I saw that engine on eBay if it's the one I was thinking of as it's got the correct pulleys for power steering? Was in Bristol I think?
'63 C10 Longbox fleetside '94 C1500 Sierra ex-USAF beater |
#34 | |
Hows it going! Ha ha ha I've already checked it out on RnS. I know the 292 your talking about (blue one) i turned it down earlier that morning (as i just wanted a swap out swap in) with no messing........... and.... yep - one on Ebay is the one thats now in parts I'm my lock up. had the double grooved pulley for P/S thats right. Ah you win some you loose some, was a good price and maybe we can save the block. yeah theres a few UK guys on here - you'll probably recognise the user names from other forums - Grizz, Martin, Paul, Andy, Ian, JP and Danny and other i may have forgotten/not met( on line) If you here of a 6 block going drop me a line please - take is easy Dan |
#35 | |
![]() HI!! |
#36 | |
Thanks for the heads up currently it seem ( to the naked eye) no problems in that area. now you've highlighted it i will make sure that it gets the once over from the Machine/engineering shop. thanks D |
#37 |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
