04-22-2016, 11:16 PM | #26 |
Re: 1958 fleetside air ride build
making some progress on rear floor panel
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 Last edited by Spblack; 04-22-2016 at 11:24 PM. |
04-22-2016, 11:30 PM | #27 |
1959 Chevy Apache (sold) 1958 Fleetside Current My builds: http://67-72chevytrucks.com/vboard/s...d.php?t=606412 http://67-72chevytrucks.com/vboard/s...=1#post7560906 |
04-23-2016, 10:15 AM | #28 |
Looks like it's coming along nicely.
Kim |
04-23-2016, 02:41 PM | #29 |
A320 Pilot/USAF Retired
Solid!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
04-24-2016, 12:08 AM | #30 |
I didn't know that they make a rear floor panel. Can you please share where you found it at?
Thanks |
04-24-2016, 11:19 AM | #31 |
thanks guys.
Crash, it was from a complete lower floor pan. my buddy need the front half, I just needed the rear. worked out perfect. I will say that replacing just the rear half, your going to have issues with the stamping. I had to modify that back section where the cab mounts are to make everything line up. I do have a used section from a parts cab already cut if your interested. let me know.
04-28-2016, 09:52 PM | #32 |
my scotts hotrods superslam ifs and 4 link came in today
04-28-2016, 09:54 PM | #33 |
power steering and control arms
04-29-2016, 08:14 AM | #34 |
Real nice looking stuff.
Kim |
04-29-2016, 05:34 PM | #35 |
Nice stuff. You did an amazing job on the box side!!
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
05-31-2016, 04:46 PM | #36 |
update: put cab on frame, jacked it up and tacked in cross brace. squared up frame and cut out crossmember.
05-31-2016, 04:55 PM | #37 |
marked original center line.
05-31-2016, 04:58 PM | #38 |
started boxing in frame with 1/8s plate. had to get rid of the old steering box cut out.
05-31-2016, 05:05 PM | #39 |
dropped in scotts hotrod crossmember. I used TCI's ifs measurements for aligning the centerline. it moved the wheels 1 inch forward to better fit the fenders. I measured 20 7/8s from the original front leaf spring mounting hole to get the new center line.
05-31-2016, 05:09 PM | #40 |
zero'ed out the crossmember and tacked it in. installed control arms
05-31-2016, 05:14 PM | #41 |
Great progress...dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
05-31-2016, 05:15 PM | #42 |
flipped the lower control arms upside down and placed a rear center mark in the rear of the frame to take some cross measurements. I was within 1/16ths between the two control arms. Should have some more updates tomorrow. I think I got it close enough to weld it in.
05-31-2016, 05:31 PM | #43 |
Very nice.
Kim |
05-31-2016, 09:20 PM | #44 |
thanks guys. got the crossmember welded in. atleast the tops and sides. I will weld in the bottom when I flip the frame over. I also picked up a 5.3 LT direct injection motor out of 2014 Silverado. it was a complete pull out with 6l80e trans and computer. I haven't seen but a few run this setup so I hope the oil pan and trans clears. I haven't seen an aftermarket oil pan for these yet.
05-31-2016, 10:05 PM | #45 |
Looks nice!!
05-31-2016, 10:14 PM | #46 |
when are we going to get an update on yours? lol. ive been waiting to see that porterbuilt on those new frame rails
06-01-2016, 01:53 AM | #47 |
Nice progress. good luck on the motor fitting.
06-01-2016, 03:47 AM | #48 |
Yep, its been awhile since I've had an update! Waiting on some new parts from Nate!!
06-01-2016, 08:22 AM | #49 |
Looking real nice.
Kim |
06-04-2016, 07:43 AM | #50 |
Looks great!!!
I think you'll manage to get that motor in
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
