Old 04-20-2016, 12:51 AM   #26
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: 1979 K20 "War Wagon"
That's sweet. Are you buying pre-bent tubes and piecing it together?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-20-2016, 01:06 AM   #27
Fw190d9
Paul, Exactly, I get the pre-bent sections from Summit, cut and weld them together. Summit sells them individually or a kit with just about all the bends and pieces you need for a full system. I did the vette exhaust all out of stainless but the 2 C10s, the Warwagon and the 69 blazer were regular aluminized steel pieces.
E.
Fw190d9 is offline   Reply With Quote
Old 05-06-2016, 09:34 PM   #28
Fw190d9
Well, I think the ol War Wagon is just about done. The LS swap went off without a hitch. Runs like a swiss watch. I decided to spread the love a bit and update the brakes and axles as they havent been serviced in about 15 years. Went ahead and changed all the bearings in the 14 bolt FF rear, put new bearings in the hubs along with new seals and a disc brake kit. It even got one of those Eaton no slip posi units that replaces the spider gears in the original carrier. Gotta have some traction for those muddy ranch times. New rotors and calipers in the front along with new seals and bearings. I went to check the oil level in the original 10 bolt front and discovered it only had about a pint left in it! Evidently the pinion seal was toast and its been leaking for quite a while. The bearings still look ok(probably have at least 2 years left) so I just put a new seal on it. If it goes south, Ill have to take the axle off and rebuild it. While replacing the pinion seal I discovered the original slip yoke had been broken and brazed back together by the P.O. Must have been a pretty good brazing job as its still holding. I went ahead and replaced the U joint as one of the caps had some rust. Ranch life is hard on these trucks! Additional improvements include new LED lights for the rear(gotta see to load dead critters at night), a flaming river remote battery cut off so I can kill the power when its going to sit for awhile, some gussets for the middle bar as it was starting to crack from passengers yanking on it and lastly a new basket for the upper cage with drink holders and ammo storage. Hope to have it back in "God's Country" next week.
Evan Q.
Old 05-06-2016, 09:36 PM   #29
Fw190d9
Still cant figure out why all my pics come out rotated?
Old 05-06-2016, 09:38 PM   #30
Fw190d9
Here's the brazed up slip yoke!
Old 05-06-2016, 09:39 PM   #31
Fw190d9
So here she is in all her glory, ready for action!
Evan Q.
Old 05-07-2016, 07:55 AM   #32
Katrina/10
Katrina/10's Avatar
Wow, never would have thought a brazed driveshaft would hold up at all!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 05-07-2016, 12:25 PM   #33
Fw190d9
Gary, Me either! Its was done before I rescued it from the weeds so its been holding for at least 28-30 years!
Evan Q.
