Old 04-08-2016, 02:10 PM   #26
jocko
jocko's Avatar
Re: Parting 71 Custom Camper 20
How much would you like for the raised oil fill tube/screws, etc and cap shipped to 76028?
Also - am interested in the brake distro block/prop valve AND its electrical connection (you can just cut the wire as long as you can, but no need to get fancy). Was the brake light on all the time prior to stripdown? If not, how much shipped to same addr? (you can just snip the lines and leave them attached - i.e. please leave fittings intact if you don't mind). Or did this go with the front disk brakes you already sold?
Thanks!
Old 04-08-2016, 02:34 PM   #27
cheyenne shortstep
cheyenne shortstep's Avatar
bluek5, here is what you get. If you need the big bracket that sandwiches the pedal I will throw one in.
B.W., I will gather up what I've got and get back to you.
cheyenne shortstep is offline   Reply With Quote
Old 04-08-2016, 09:54 PM   #28
cheyenne shortstep
jocko, I'll do $45 shipped for the oil fill w/ screws & cap. This brake set up is going with the brakes but I probably have what your looking for, 71/72 dist. block, fittings and wire end?
B.W., still working on A.C. stuff, so far I have most of what you need.
Old 04-08-2016, 10:33 PM   #29
jocko
jocko's Avatar
Ok, thanks for checking shortstep - I believe I'll just take the oil fill setup. Will pm you for details. Thanks!
Old 04-08-2016, 10:36 PM   #30
bluek5
bluek5's Avatar
Send me your payment information again. It's been a little while.
Thanks, Paul
bluek5 is offline   Reply With Quote
Old 04-08-2016, 11:02 PM   #31
johnscab
Did this have power steering? If so how much for the pump, brackets, pulleys and box. Any pix also appreciated.
johnscab is offline   Reply With Quote
Old 04-09-2016, 10:28 AM   #32
B. W.
B. W.'s Avatar
Thanks, I'm in no hurry, truck's in a million pieces (am i restoring it or parting it? Sometimes I forget!)
B. W. is offline   Reply With Quote
Old 04-09-2016, 05:05 PM   #33
tj_1970_k20
What type of rear axle does it have?
tj_1970_k20 is offline   Reply With Quote
Old 04-10-2016, 12:56 AM   #34
cheyenne shortstep
tj 1970 k20, it is a 4:10 Dana 60 for leaf spring suspension [non posi].
Old 04-10-2016, 03:05 AM   #35
Dimebagdavesc30
Dimebagdavesc30's Avatar
Is the heater switch still available.....thanks
Dimebagdavesc30 is offline   Reply With Quote
Old 04-10-2016, 05:40 AM   #36
SIXTY9
Looking for the steering column bracket and clamp that is on firewall under master cylinder with the bolts,and shipping to 29418
SIXTY9 is offline   Reply With Quote
Old 04-10-2016, 09:47 AM   #37
rcm1958
What does the tailgate look like?? My current gate is really crusty, bent, etc.. The truck deserves something better!
Let me know-
rcm1958 is offline   Reply With Quote
Old 04-10-2016, 10:53 AM   #38
tj_1970_k20
Can you measure the center to center distance between the rear springs for me?
Old 04-10-2016, 11:43 AM   #39
cheyenne shortstep
Johnscab, P.S. setup sold locally.
tj 1970 k20, axle measures 42&1/2" center perch to center perch. It will not fit 4x4 if that's what you're after.
Dimebagdavesc30, Do you need a fan switch or complete A.C./heater control?
Sixty9, $20 shipped for column clamp, bracket & screws.
rcm1958, As stated ALL sheetmetal is rusted, the gate is being made into a bench.
Old 04-10-2016, 12:02 PM   #40
johnscab
Thank you, sir!
Old 04-10-2016, 01:01 PM   #41
SIXTY9
Will you please pm your information on how you would like payment. Thanks
Old 04-10-2016, 02:43 PM   #42
Dimebagdavesc30
I need a complete switch. Thanks
Old 04-10-2016, 02:49 PM   #43
cheyenne shortstep
Dimebagdavesc30, I'm a little confused. Do you need a fan blower switch or complete A.C. control unit?
Old 04-10-2016, 05:08 PM   #44
Dimebagdavesc30
I need heat control assembly with heat only, my whole dash switch is missing levers, just have face plate. I don't need the ac one but the whole switch assembly.
Old 04-10-2016, 05:59 PM   #45
cheyenne shortstep
Dimebagdavesc30, OK so you need this complete heater control unit. It is in good solid condition with a little weathering on the face. $90 shipped
Old 04-10-2016, 07:10 PM   #46
Dimebagdavesc30
and it's sold wipe me your stuff and I'll zip the money off.... thanks
Old 04-13-2016, 08:30 PM   #47
72lady
Hi I'm interested in the Ac/heat vacuum actuators and brackets if they are good. Cowl one and the one on the passenger kick panel. Shipped to 29360. Thanks
72lady is offline   Reply With Quote
Old 04-13-2016, 09:50 PM   #48
cheyenne shortstep
68350, I found the other Custom Camper/20 emblem if you are still interested, not really pitted just need cleaning, all studs intact. $30 shipped
B.W. I am getting another truck that I believe the A.C. boxes are intact. otherwise I have everything. I'll know in a day or 2.
72lady, are these what you are after? If so $25
Old 04-13-2016, 10:00 PM   #49
72lady
Old 04-13-2016, 10:01 PM   #50
72lady
Originally Posted by 72lady View Post
Yes those are the ones. Do you know if they will hold a vacuum? If so I'll take them.
