Old 04-18-2016, 11:57 AM   #26
truckdude239
truckdude239's Avatar
Re: Can I replace the oil pressure sender on an LS motor?
My oil pressure is not wired to the computer i have no issuses
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-18-2016, 02:29 PM   #27
davepl
davepl's Avatar
Weird, then there must be a separate oil pressure light in most cars. I presumed low oil pressure would trigger a Check Engine, being a fairly serious condition and all...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-20-2016, 03:13 PM   #28
Hart_Rod
Hart_Rod's Avatar
Depends on the year of the motor. A lot of the newer engines (Gen IVs) use the oil pressure in some calculations in the ECM, so it is required.
Hart_Rod is offline   Reply With Quote
Old 04-20-2016, 04:02 PM   #29
davepl
davepl's Avatar
That's the opposite of most of the previous responses - I'm good because I'll have both, separate senders. The ECM will still get its oil pressure reading.
Do you know what kind of thing it uses it for? Mine's an E67 LS3 eRod.
Old 04-21-2016, 09:39 AM   #30
Hart_Rod
Hart_Rod's Avatar
I stand corrected, at least partially, . If you are running the DOD/AFM or VVT, the computer will need the oil pressure signal. IF not, you will be fine, although I believe there will be some engine parameters that that you won't be able to datalog without this signal.
http://ls1tech.com/forums/conversion...or-needed.html
