#26 | |
Re: Steering issues on lowered straigh axle
First look at centering the box as a starting point. The drag link angle, that's a toughie, shortening the pitman arm, bending the steering arm down on the spindle (not a good idea) raising the steering box is another fix. Or of course getting a dropped axle (sold one a while ago, sorry) and putting the springs where they belong. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#27 | |
They would have one on each spring. The degree would be determined by the shim "wedge". They are available in many different degrees. I can't imagine putting one on one side and not the other, that makes no sense to me. I have to assume the spring would just bend and equal it out both sides being the same. Brian
#28 |
fix the kingpin issue. fix the drag link issue, fix the steering box issue. get an alignment. THEN drive it. remember there are others on the road who would like to see tomorrow so get it right before it goes wrong.
#29 |
Try contacting sids dropped axles he knows everything there is to know on the dropped axle and steering on these trucks. I bought his arm for my truck to prevent bumpster. It mounts the ball joint under the steering arm instead of on top leveling it out preventing the bump steer. I have to give credit to Dubie for helping g me out a long time ago. Like he said he's done exactly what you need it sounds like. He's very helpful and explains everything. There's a bunch on here that knows what your dealing with they will get it figured out.
