#26 | |
![]() Join Date: Apr 2016
Re: Engine temp sending unit
![]() http://www.clipsandfasteners.com/GM_..._p/r5665pt.htm http://www.classicindustries.com/pro...s/ca34620.html |
#27 |
Thank you very much. I've been looking all over the place and haven't been able to find what it looks like. I wasn't sure if I just wrapped a wire around it or what. Will this work for a 1969 c20?
#28 |
I suspect it would. I am thinking the wire goes into the terminal block at the firewall with one of these
http://www.classicindustries.com/pro.../wc500115.html |
#29 |
laying low
![]() Join Date: Mar 2001
You can probably pickup the connector at a parts store. Also in a pinch you can use a regular female blade connector. Just spread it open a tad and it will slip right over.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#30 |
#31 |
I appreciate all of the help. Going to order the parts soon. Just picked up a new radiator, heating core, thermostat, and temperature sending unit.
