Old 05-05-2016, 01:39 PM   #26
_Ogre
_Ogre's Avatar
Re: Need Pictures to Determine Tire Size
Originally Posted by Dan in Pasadena View Post
I would add reinforcement above the C notch butI didn't know how much I could add without hitting the underside of the bed wood.
I won't need tubs for my tires - I don't intend to run real wide tires
lay 2 cross sills on the frame and you'll know exactly how much reinforcing to add
everything is made from 10 ga steel, i boxed both sides of the added material with 10 gauge flat plate
if you don't think you need tubs for 255 wide tires, think again
i tubbed to the springs, approx 3''
shop air compressor timer
Old 05-10-2016, 11:26 AM   #27
CATMdude45
CATMdude45's Avatar
Originally Posted by xaircav View Post
Heres mine with 255/70-15 rear and 225/70-15 front on 15X7 wheels
Can you tell me what your backspace and offset are I like the look, my 52 is very stock in height and the PO had crap wheels that were pieced together so I am painstackenly looking for replacements.
52 Chevy 3100 AD
68 Ford Bronco
06 Dodge 2500 Ram Cummins Diesel
CATMdude45 is offline   Reply With Quote
Old 05-16-2016, 07:09 PM   #28
tsmith8
Originally Posted by Jemezcrusher View Post
tsmith8
I am wanting to go with bigger Cokers in back, bt looks like the whites are 3/4" wider on the tires above 235. I figured 255 on the back and 225 or 235 on the front but am concerned about the differences in white wall width. Looking forward to seeing your pics
Here is the truck. I will get some better pictures after I get it back from the shop, it is in for safety. Those are Coker Classic Radials with 3 1/8" white walls, 235/75R15 on Crager Delux 69 7x15 rims.
tsmith8 is offline   Reply With Quote
Old 06-16-2016, 06:13 AM   #29
spectral
spectral's Avatar
Originally Posted by Fiftee3 View Post
255/70/15's on 8" wheel vintiques rear, 215/70/15's on 6" front.
255's on the front might be a bit big,not look to good, imo.
Attachment 1527968
May I ask what backspacing is on those 8" wheel vintiques with the 255's on them?
(Howdy by the way, first time poster!)
spectral is offline   Reply With Quote
Old 06-16-2016, 11:39 AM   #30
Fiftee3
Fiftee3's Avatar
Fiftee3 is offline   Reply With Quote
Old 06-16-2016, 11:42 AM   #31
Fiftee3
Fiftee3's Avatar
They are series 12 by wheel vin tiques.
4" back spacing.
Tires are brand new onback and for sale if your interested.
Going to a different sizing.
Old 06-16-2016, 08:40 PM   #32
spectral
spectral's Avatar
4" back spacing.
Thanks for the info.. i'm just having some fitment issues with 15x8" Cragar Delux's with the 3.75" and 255/50R15 rubber. Mild rubbing on the fender edge. 4" backspacing would have been perfect I might need to drop to 235 width.
Old 06-17-2016, 05:51 AM   #33
Fiftee3
Fiftee3's Avatar
Mine rubbed slightly also. Used a bat. Never rubbed again and came out great. Something like this...but I did not use the heat gun...
https://www.youtube.com/watch?v=zG0Aehc3yXo
"All the best, Phil"
My 53 IFS air bagged Upgrade Here
One of my threads for this build...
http://67-72chevytrucks.com/vboard/s...12#post7662512
Old 06-22-2016, 09:53 AM   #34
solidaxel
solidaxel's Avatar
255/70-15 on the rear smaller on the front with 15"wheels
I tried a 275 on the rear of one of the trucks I had, but it rubbed the bed side and blistered the paint
No C notch an any of the trucks but I do have 2" blocks and they do not bottom out
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-22-2016, 11:01 AM   #35
b00sted
b00sted's Avatar
I know they are not 15's... mine are 17"s but they are 275/45/17 all around and fit nicely. My truck is a 49.
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
