Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-12-2016, 03:11 PM   #26
nobolt
nobolt's Avatar
Re: My 1971 k5 engine bay build
nice pair!
did the '72 come from the same rancher? loaded with a 4 speed, i love it.
that was when you ordered a vehicle optioned YOUR way.
i miss back when.......
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 05-12-2016, 05:06 PM   #27
A1971Blazer
A1971Blazer's Avatar
Very nice job......attention to detail is beyond reproach!
Also, if you have access to a good welding shop, that manifold can be tig welded with Ni99 filler rod.....
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is online now   Reply With Quote
Old 05-13-2016, 11:34 AM   #28
mdlucas1
Originally Posted by nobolt View Post
nice pair!
Thanks Dave
The olive one was not from the same rancher, but that would have been cool. Ill try and post some more pictures of it. I really lucked out on the condition of both my blazers!
mdlucas1 is offline   Reply With Quote
Old 05-13-2016, 11:37 AM   #29
mdlucas1
Thank you for the nice compliment!
I was thinking about the welding/brazing thing... I actually have a tig welder. What I'm not sure about though is how to get the metal back clean enough to weld because of the ceramic coating on there. Maybe I'll try a test on the backside, somewhere not noticeable
Old 05-13-2016, 12:56 PM   #30
hemi43
hemi43's Avatar
High nickel rod does work on cast iron, but seeing as those manifolds are 45 years old you may not have too much luck because they will be full of carbon. If you're going to attempt it, make sure you preheat it in an oven first. IMHO, you'll be farther ahead by finding one in good shape and get it recoated.
hemi43 is offline   Reply With Quote
Old 05-20-2016, 06:34 PM   #31
mdlucas1
Finally got the engine back in! Had a couple of hiccups along the way as per usual, but nothing too bad.
Getting the bell crank back in was a but of a chore, also the aftermarket fan shroud and radiator didn't fit exactly right, but in the end it is all good.
And it started right up!
I got to doing some timing, turned it off... went to start it again and it was acting like either the battery was dead or the timing was way too advanced.
After some head scratching, it turns out the new(reman) started was toast!!
Pathetic... so I went and got a new Powermaster mini high torque unit and it worked perfect.
Drives a whole lot better down the road now! Tons of Torque, NO leaks so far!!
Old 05-20-2016, 06:38 PM   #32
mdlucas1
A couple more
One interior shot... I put on a new glove box door sticker
Old 05-20-2016, 09:29 PM   #33
jaros44sr
jaros44sr's Avatar
Sweet, well done.... tower clamps and all, good ref. Picks for the stock crowd
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-21-2016, 02:23 AM   #34
gringoloco
A guy with a truck
gringoloco's Avatar
Very nice and stealthy. Good work
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-21-2016, 12:11 PM   #35
mdlucas1
Thank You!
Old 05-21-2016, 12:12 PM   #36
mdlucas1
I appreciate it!
Old 05-21-2016, 03:55 PM   #37
IronCanine
I'm trying....
IronCanine's Avatar
Nice.
IronCanine is offline   Reply With Quote
