#26 |
Re: Help reading SPID
This is as far as I can go at this point. Totally killed my morning too. As you can see there were a few changes but for the most part everything is supported and documentable (to a point).
The body side molding listed must the upper since a CST included lower body side molding. Your pictures of the truck helped confirm the blanks I was having trouble sorting out. Like a puzzle, one little bit can make a big difference. The 951xxx fleet option had me wondering, but I feel that D60 rear axle was ordered in that truck under the fleet number shown. It was standard with a 396/manual trans. but not a public RPO on automatic trucks. Sorry but I can't supply the missing letter with any certainity. Jeff might be able to when he makes you SPID but its still a longshot.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#27 | ||
The ratio is not really important but the easiest would be to do a spin the tire check. Be sure to count the teeth for future reference when you service the diff. though. Gary, You kow this, big blocks came stock with the remote reservoir. It helps things fit and is a cheap fluid cooler too.
#28 |
Thanks SS Tim. I'll be on the hunt for some of those mirrors for sure.
Who is Jeff and how do I reach him? I'll just send him my glove box for better deciphering.... This place is AWESOME!!!!!!!!!!!!
IT IS WHAT IT IS |
#29 | |||
"I ain't nobody, dork."
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#30 |
Better deciphering? I really don't think your going to get better deciphering than SS Tim did for you. He got every single option including the fleet code. There's a couple of suffix codes missing but so what. Suffix codes aren't even used after production and very few people know what they are. You can just make up any letter you want. No one will ever know.
That's a VERY nice truck you have there. Good straight panels and very little rust. Your going to be able to make that truck a real head turner in no time. It's very well optioned and it's the upper trim level. The big block and tachometer are a huge bonus. I hope you keep that truck forever and drive the wheels off it everyday! I reprinted what Tim had to show how little is missing. You can add the wheelbase at 127, get the unique serial number from your vin plate and make up 3 letters for the suffix codes and you have a complete SPID that no one will be able to question.
CHEVY/GMC VIN DECODERS |
#31 |
This may help a little. http://outintheshop.com/options.html
#32 | |
![]() I will need everyone's help to bring it back to life. It seems like a good truck and worth putting the money into. . I'm currently working on getting parts together ....
IT IS WHAT IT IS |
#33 | |
http://outintheshop.com/index.html
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#34 | |
IT IS WHAT IT IS |
#35 |
I have a label from 68 that has 9516QA listed and a 69 label with the tach code as 4U16FM. No need to mail anything, I would roll with those. That's a tough one to decipher for sure, Good work Tim and everybody else that helped!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#36 |
PM Sent
IT IS WHAT IT IS |
#37 |
the lower side moldings on my truck. Should they be black or wood grain???? Would I also have the upper moldings???
IT IS WHAT IT IS |
#38 | ||
Unfortunately I must also address the elephant in the room. The rear axle and the SPID descriptions lead me to believe they are from the same truck. However the fact the SPID has been scratched away rendering the serial portion of the VIN unreadable in the pictures has me wondering. Is the VIN you are reading from the SPID/glovebox door or the door post VIN plate? If it is from the door plate (with correct rivets) then I suggest you also check the frame's partial VIN. It is located (on most trucks) in the top flange of the left frame rail near the steering box. Stamped as an eight digit partial starting with the year code, then plant code, followed by the six serial digits. So it should look like 9B _ _ _ _ _ _. The reason I am seeming to torture you is the SPID clearly lists factory Air Conditioning yet just as clearly the cab is not. This suggests a not uncommon cab swap and possible VIN swap. Sorry I wasn't clearer earlier on the moldings. As a CST it included the woodgrained lower body side and tailgate molding/applique. The SPID also lists the truck as being optioned with the upper belt molding as well so your truck had the full treatment.
#39 |
[QUOTE=bruceman1968;7604832]Better deciphering? I really don't think your going to get better deciphering than SS Tim did for you.
Amen to that. SsTim is like the truck wisperer. Countless times I've seen him do the same thing for many on here including myself....Bruceman you are up there too I've learned alot from your posts. I noticed the ac was gone back when I posted but forgot to say it. This can be one sweet truck
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#40 | |
Here is the label from 68 with that diff option, I knew I had one of those just had to track it down. Jeff
#41 | |
IT IS WHAT IT IS |
#42 |
I will grab the vin off the frame Sunday now that I know where to look.
Anything else I need to do to confirm????
IT IS WHAT IT IS |
#43 |
All I have in my phone, I'll take a better one Sunday. I can read all but one #
I think maybe painted over?? I'm afraid to touch it and make it worse. I want to just remove the glovebox for safe keeping and preserve it somehow so it doesn't get worse and buy another box and install a new label. I also have the compressor mounts. Missing evaporator and compressor. SSTim I'm very grateful for your help.
IT IS WHAT IT IS |
#44 |
Yes! It most certainly was. Please keep us updated with progress pics as you and your son work on it. It really is a nice truck.
#45 | |
Yeah, were gonna tear the interior down Sunday and really look it over good. I guess we will start a build thread. My son is beside himself with excitement. He's a good kid and not the typical 17yr old.(Thank Momma for that one). Were going to see if the build sheet is in the seat somewhere. Dash is going off to TBONE64 on Monday for the proper restoration work.....lots to do!!!!! Going to get a tilt column in the works too.....
IT IS WHAT IT IS |
#46 |
Sounds like everything was up front on the cab swap. Knowing about these things going in makes it easier. All too often dream buys end up being frankentrucks glued together with fresh paint and BS.
There is a lot more to the VIN in the last picture than the others so I'm sure you are seeing even more than I am. Keeping the door and installing a new SPID on a replacement is a practice I stand firmly behind, especially on "upgraded" trucks. To that end here is probably my final draft on it. You and Jeff can work out the details from there on how you want it printed. Numbers can go as far as you want. Be sure to confirm the ratio is actually 3.54 if you decide to print that as Jeff is showing. The axle has a date and BOM (bill of materials) code applied by Dana/Spicer that describes the axle as built if you want to hunt for that. Download a pdf copy of "X510-8DSD" to add to your collection http://www2.dana.com/pdf/X510-8DSD.pdf as well as the serice and overhaul manuals linked in my signature (at least until you get paper copies!). Engine numbers will help and can confirm it is the correct block for a 69 C10. These include the engine assembly number, specifically the suffix codes in conjunction with the block casting number and date. We can even verify the trans code and date from the tag as being correct. Please be sure to put a link to the build thread here so I see it!
#47 |
Thanks!!!!!!!!!!!!!!. Were is a good place to buy the manuals???
IT IS WHAT IT IS |
#48 |
IT IS WHAT IT IS |
#49 |
Its great seeing this going forward.
#50 |
![]() Join Date: Jun 2005
One other thing I noticed. The truck has a "70" inner grille, or at least it's painted like a 70.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
