Old 06-20-2016, 02:02 PM   #26
chrismoore701
chrismoore701's Avatar
Re: Truck died last night
Originally Posted by jjzepplin View Post
If you have a turbo 350 it does not have vacuum at the carb. It is supposed to be manifold vacuum at the rear of the carb there is a fitting that screws into the manifold and goes to the vacuum modulator on a th350. The modulator is sometimes adjustable to fine tune your shifting. You may have the trans connected to ported vacuum and this would be not so good.
I have a port on my intake on the back side of the carb. Right now I have the brake booster and my heater vent vacuum connected there with a tee. I can easily pull my heater vacuum off and connect my trans there and see what difference that makes. will let you know.
Chris
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 06-20-2016, 09:07 PM   #27
jjzepplin
jjzepplin's Avatar
That is right. Your heater vac should go to constant vacuum. Should be a small port somewhere on the base of your carb. Only good way to tell what is what is to hook up a vacuum gauge to each port or read instructions. Heater vacuum usually goes to a canister of some kind to store the volume of air as a reserve. Not a real fan of vacuum advance elimination on street vehicles. Streetability suffers a bit in my opinion.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-20-2016, 11:14 PM   #28
chrismoore701
Ok so I added some Trans fluid. Took the Trans vacuum line off the carb and added it to the spitter on the back of the intake. Opened the fuel filter and cleaned it. Ran worse than before. Hobbled back home and bypassed the fuel filter. No better. Not sure if it is starting to miss or if it is loosing fuel. Pressure before the carb shows about 10 psi. I have the pcv valve going to the back base of the carb. The brake booster coming off the intake. With a tee and the Trans now connected there. I have a couple caps on the front vacuum ports. Have not checked the brakes. Will try that tomorrow.
Chris
Old 06-20-2016, 11:32 PM   #29
Gregski
Post Whore
Gregski's Avatar
Dang it, that sucks, only advice I can share is please try to only change one thing at a time, I know it takes more time, but trust me it pays off in the end.
Gregski is online now   Reply With Quote
Old 06-21-2016, 09:27 AM   #30
nonstop
After checking brakes, check the float level of the carb and confirm the fuel pressure. 10 psi sounds pretty high, and could be causing the needle to be overpowered, causing it to flood out. But as said above, do one thing at a time to make the elimination easier.
nonstop is offline   Reply With Quote
Old 06-21-2016, 09:39 AM   #31
RodsGreen10
RodsGreen10's Avatar
10 psi is to high. Holley spec fuel presuure 6-8 psi.
With 10 psi you will probably blow the needle of the seat.
RodsGreen10 is offline   Reply With Quote
Old 06-21-2016, 11:06 AM   #32
chrismoore701
you can see from my pic on the previous page I have a cheap inline pressure gauge. And that thing wags all over the place, my best guess is it was 10 but it bounces from between 8 and 12 or so. I will check the floats tonight. I have a typical on engine fuel pump, think it is a holley. Do I need to get a pressure regulator and install inline?
Chris
Old 06-21-2016, 11:07 AM   #33
chrismoore701
Blow it, like tear it up? or just blow by it?
Chris
Old 06-21-2016, 11:44 AM   #34
jjzepplin
jjzepplin's Avatar
Shouldn't destroy it. But would cause the fuel to flow past it creating a constant flooding issue.
Old 06-21-2016, 12:19 PM   #35
hatzie
Moderator
hatzie's Avatar
10PSI will intermittently force the needle valve open regardless of float position. Not a flood with gasoline fountaining out the bowl vent but the float setting will not be reliable along with the associated intermittently over-rich fuel mixture issues from the intermittently overfilled float bowl. Just like a bad needle and seat but without the bad parts.
Holley and most other carbs don't like much more than 6-7PSI...
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-21-2016, 12:38 PM   #36
RodsGreen10
I was being sarcastic. But the fuel pressure you are guessing you are running is overkill.
You seem to have more than 1 problem start with one thing and move on. A ton of good and bad info on Holley carb tuning.
Old 06-21-2016, 02:06 PM   #37
chrismoore701
What about the venting of my gas tanks? Anybody running the charcoal canisters? I think I have vented gas caps and I am not running the canisters. Could this cause a problem?
Chris
Old 06-21-2016, 02:22 PM   #38
hatzie
Moderator
hatzie's Avatar
The only issue that makes is the missus may not like the smell of raw gasoline in the garage.
Not much to a basic charcoal vapor can, zero performance hit, and the garage doesn't stink.
Ported vacuum to the purge valve vacuum actuator port.
Canister vapor purge "OUT" teed into the PCV line or run to manifold vacuum.
Raw vapor line "In" from tank vent(s) to the canister vent line connection.
The later model vapor cans resemble a Rube Goldberg device from hell. Probably to make the EPA Oberführers happy. There's absolutely no reason to have more than three hoses on each can. GM didn't make a larger can for dual tank trucks so you may need two cans.
Old 06-21-2016, 03:22 PM   #39
Gregski
Post Whore
Gregski's Avatar
I deleted my charcoal canister on my '74 and went to a single line sending unit and truck runs fine, great really, and no gasoline smell in garage at all
Old 06-21-2016, 09:05 PM   #40
chrismoore701
I am going to pull the carb off and clean it
Chris
Old 06-21-2016, 09:08 PM   #41
Gregski
Post Whore
Gregski's Avatar
Good call, clean the float needle areas real good and check for cracked floats
Old 06-22-2016, 07:10 AM   #42
chrismoore701
OK so I pulled the carb off last night, looked clean, but cleaned all the ports, open the needle and cleaned that, threw it back on and it ran but would fall on its face off the line. Talked to a buddy of mine and he told me to drop it in first and light it up a couple times. Running pretty good now. I guess it just got a little dirty and loaded up with carbon. Still not perfect, but I will take it to my engine guy and let him have a look at it. At least I can drive it now.
Chris
Old 07-03-2016, 08:05 PM   #43
Pontiac1976
Pontiac1976's Avatar
I prefer Fram G3 fuel filter install it right @ the out tube of the fuel pump near frame, it's cooler and works better there and you can see it, and check it change regular.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
