Old 06-17-2016, 11:30 PM   #26
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: 3.73 vs 4.11 ?
Originally Posted by Bubba4spd View Post
thanks BlackedOut67shorty. Would you know if the case on the 4/6 is the same as the 4.3?
If you mean your 250 inline six then yes.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 06-18-2016, 02:36 PM   #27
Bubba4spd
Bubba4spd's Avatar
Re: 3.73 vs 4.11 ?
Originally Posted by Overdriven View Post
With Chevy T5 availability not being all that great and them being weak I was looking into alternatives other than the much more expensive Tremec. One I found was that QuickTime has a Chevy Bellbousing with a Ford trans bolt pattern. Ford T5's are practically a dime a dozen, then there's the 5spd that they used behind the 4.6 (tr3550?) as well. I'm not sure if you'd need a clutch with a Chevy pressure plate and a Ford splined clutch disc. But even if you do a quick call to your clutch supplier solves that easily enough and total cost would still be lower than going with a new Tremec. Assuming that's all that needs to be done, haven't looked too deep into the input shaft length and pilot bearing/bushing diameter yet. I'm sure QuickTime would be able to answer those questions but again, I have gotten that far yet.
Overdriven, you have brought up some good points. I'll look deeper into this Quicktime route. Yes and not only are the Ford T5 more plentiful, it's my understanding they are a bit stronger than the GM versions.
Bubba4spd is offline   Reply With Quote
Old 06-18-2016, 02:44 PM   #28
Bubba4spd
Bubba4spd's Avatar
Re: 3.73 vs 4.11 ?
Looks like they have performance bellhousings. Probably the same can be accomplished using a Lakewood set up for Ford trans and a Chevy SB bolt pattern. Bad thing with this route the bellhousings are 5-6 hundred dollars then I'm sure more added to make the conversion happen.
Seems I read some of the more recent Camaros have been using Ford T-5s. Wonder if this is true and if one of these bellhousings would do the trick.
