Old 06-19-2016, 03:45 AM   #26
BrandonGerringer
BrandonGerringer's Avatar
Re: 1960-1966 Chevy C10
Originally Posted by jtrichard View Post
Just looked up some dmv stuff and it looks like it is now 20 days
Bummer , not too worried about it though, I'll figure something out. Right now I'm just trying to figure out the cheapest way to get it home! Right now I'm looking at at least $150-200 bucks in fuel, plus trailer rental for a few days. I get paid every two weeks so I'm figuring at least one pay check out until I can go get it and bring it home which is quite a bummer. But hey, it could Always be worse.
1995 Chevy Crew Cab 3500 Dually 6.5 TD
1964 Chevy Single Cab Long Bed Fleetside Small Block 400
1966 C10
BrandonGerringer is offline   Reply With Quote
Old 06-19-2016, 12:35 PM   #27
Chknlyps2
Originally Posted by BrandonGerringer View Post
I more than likely will go ahead and replace the doors judging by how they look in the few pictures I've gotten. I'll see about getting some better detailed pictures tomorrow of the interior. I'll have to start looking around on Craigslist as well. Also, do you know if there are any junkyards with possible Chevy parts in my area? I've looked but haven't been able to find any leads.
Not sure on junk yards in your area but there are guys in Fontana, San Diego and Victorville that part out and always have adds on CL for 60 to 66 parts. The guy in Victorville does mostly 67-72 parts but when I talked to him about some things for a 72 I have, he told me about a truck he is getting back in shape and ended up picking up 8 or 10 60-66 parts trucks.
I got a cab from a body shop in San Marcos a while back and the guy there told me about an area in south San Diego that is all junk yards, he described it as a long street with yards on each side. He said when they have older cars and trucks to repair they go to the yard all the way at the end of the street and on the right, that they have more older stuff. I have never been there but with some googling you might be able to make some calls.
The parts section here has some great deals but if you want to post a want to buy add you need to be a supporting member.
Chknlyps2 is offline   Reply With Quote
Old 06-19-2016, 03:43 PM   #28
BrandonGerringer
Here's a few pictures I received today. My Uncle stuck a battery in it, turned the (what we thought was the ignition key) and the windshield wipers came on! Apparently there are two spots on the dash, one on each side of the column, for an ignition key. Tried turning the key and it didn't even crank. Maybe it needs a new ignition switch? Pushed on the brake pedal and it went all the way to the floor, going to check the master cylinder, thinking it probably needs a new one as well. It also needs new bulbs for the blinkers. Anyone have any ideas as to why there are two key holes on the dash instead of just one on the right side? I don't think that's stock but I am not completely sure.
1966 C10
Old 06-19-2016, 03:46 PM   #29
BrandonGerringer
Thanks for the info! I will definitely be checking it out soon and seeing what I can find for a reasonable price. I heard about a pick-a-part in Stanton but I'm not sure if they even would have what I need, or what they would charge, I'll have to give them a call as well.
1966 C10
Old 06-19-2016, 04:47 PM   #30
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
H in the VIN is Fremont Ca Plant. ( thanks factorystock for finding this info)
There were no 64's produced in Oakland as the plant had been shut down in 63.
http://www.ultra-high-compression.com/fremont-tour.html
Z62 is the Custom Comfort Option.
Old 06-20-2016, 04:29 AM   #31
BrandonGerringer
Did a bit more digging today, and with the help of my mom, found a classic car and truck restoration shop called "Second Chances Garage" which specializes in restoring and finding all the history linked to the cars and trucks that they work on and restore. Spent a little while reading on their page and found out that I can send a letter to the DMV asking them to release the information of who the previous owners were of the truck, they even have a sample letter to the DMV that I will be able to use. If any of you are interested, here's the link to the page, it's worth the look!
http://www.secondchancegarage.com
As for any updates on the 64', she's sitting on my Uncles gooseneck until we can find two tires for the front that will hold air. Anyone in the Washington County area of Utah with a set of two 10 inch wide's for sale?
1966 C10
Old 06-20-2016, 04:31 AM   #32
BrandonGerringer
Thanks for the info! I appreciate it! Looked around a little bit and was able to find that it has never been on the theft list, and I also found this as well.
1966 C10
Old 06-20-2016, 05:45 AM   #33
aerotruk63
aerotruk63's Avatar
See you learn something from me, and I learn something from you. Great site ( http://www.secondchancegarage.com ) to browse through. They have a article on build sheets. Very informative.
Old 06-21-2016, 02:43 AM   #34
BrandonGerringer
So today I've been searching around for tires and I need some advice, the truck has 10 inch wide rims with 12 inch wide tires all the way around that were off of the PO's old 4x4 Blazer. The truck needs two new front tires, since the back are in ok shape and hold air, I'm just worried about the front, but it seems to me like 12 inch wides up front as well is quite ridiculous, would the best thing to do be to find two 10 inch wide tires to put on the rims, or should I think about going to skinnier rims all together up front. 10 wides up front still seems a bit large but that would be better than 12's.
Old 06-21-2016, 01:18 PM   #35
jtrichard
Narrower wheel and little or no offset is best ....Those wide wheels have WAY to much outer offset and load the outer (small) wheel bearing beyond what it is designed for
jtrichard is offline   Reply With Quote
Old 06-21-2016, 11:38 PM   #36
BrandonGerringer
What offset would you suggest? I know very little about rims and tires, I've always ran the stock size on my daily (95' Chevy Crew cab dually). I was doing some reading and one guy suggested 275/60/15's, but I have absolutely no idea what that means so if someone could explain that to me it would be greatly appreciated. I'm heading down to the Chevy Parts Junk yard in Santa Ana tomorrow and I'm going to look for some cheap rims and tires just so I can get the truck rolling at least. Hoping to have the truck home in the driveway within 2-3 weeks as funds become more available.
Old 06-22-2016, 07:28 AM   #37
jtrichard
275/60/15 ..... 275 is the width 275MM......60 is 60% of the width in this case 275MM is the height ( 275x.6=165MM) from the wheel to the OD (ground) of the tire ....and 15 is the wheel diameter 15"
Old 06-22-2016, 11:47 PM   #38
jtrichard
OPPS 60 is 60% of the width in this case 275MM ..... (275x.6=165MM) So 165MM is the height from the wheel to the OD (ground) of the tire ....and 15 is the wheel diameter
Old 06-23-2016, 02:08 AM   #39
BrandonGerringer
I think I get what you're saying. This stuff is all kind of confusing to me. I've been thinking about switching the front rims to smaller width rims because I heard that the 10 wides up front can actually damage the front suspension. I'm not sure how true that is but I'd sooner not take the risk of possible.
Old 06-23-2016, 11:20 AM   #40
jtrichard
YES wide wheels with the wrong offset are hell on wheel bearings
