06-23-2016, 05:47 AM | #26 | |
Re: New parts, now won't start
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 06-23-2016 at 06:50 AM. |
06-23-2016, 01:47 PM | #27 |
So when I take the cap off, the rotor is pointing at #6, and the balancer is at TDC, so how can it be one or two teeth off?
06-23-2016, 01:53 PM | #28 | ||
"I ain't nobody, dork."
Agreed... moving the wires around with the distributor not set right is not the way to go about it.
Get the engine up on #1 TDC. Drop in the distributor in with the rotor pointing at the #1 cylinder like you want it. It doesn't matter that the oil pump drive doesn't line up yet. Now bump the starter a couple times and when the distributor gear lines up with the oil pump, the distributor will drop in the rest of the way. Now time your engine where it needs to be. Off chance you might have to change the weights again depending on what your engine will like. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-23-2016, 01:54 PM | #29 |
I'm with everyone else.
Get the motor back on tdc on the compression stroke and re stab the distributor. You probably will have too turn the oil pump drive with a long screw driver. Or rotate the motor till it drops in correctly. Then go from there. It's really the only way too go now.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
06-23-2016, 02:01 PM | #30 |
Using a remote starter or your wife tapping the key ( that's what I call my girl , my remote starter !) , remove the #1 plug and using your finger over the plug hole tap the engine around until you feel the compression stroke coming up on that cylinder ,it will take you a time or two to get it , now you know your at tdc on #1 ,drop the distributor in with the rotor pointing at the #1 plug wire on the cap now your at least close .I wish you lived closer ,but you would go broke buying Heinekin
The reason you don't change anything on the distributor before starting the engine is YOU CANT RETURN IT , and it will run right out of the box ,possibly better than you may have thought . Always try the easy way first .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 06-23-2016 at 02:08 PM. |
06-23-2016, 02:59 PM | #31 |
Ok I did all that, and it's trying to start but backfiring out of the carb
EDIT I turned the distributor a little bit counter clockwise and it fired right up. I'm warming it up now I'll report back soon |
06-23-2016, 03:08 PM | #32 |
Well I didn't have a chance to let it warm up, the wire that goes down to the starter is getting real hot and a little bit of smoke came from it along that wire holder plastic thing in the top part of the firewall. I don't see anything weird though, it's not melting on anything or grounding out from what I can see
06-23-2016, 03:15 PM | #33 |
Do yourself a favor and make these two cheap and easy too make tools, they help when working by yourself.
Using old spark plugs here. Piston stop. It helps you find true tdc and verifies your damper didn't slip. Read up on how too use it. The other with the hose helps me when working alone. Let's you feel the air for compression stroke on tdc while your in the cab bumping the key. One of these days I will make a bump button.
06-23-2016, 04:02 PM | #34 |
I actually have a pretty decent piston stop I made, and by this time I've gotten really good at finding TDC and knowing when it's on compression or not. The issue I'm having now is with this wire smoking a little and getting hot
06-23-2016, 04:27 PM | #35 |
Check your grounds real good.
Be positive the block is grounded good.
06-23-2016, 05:08 PM | #36 |
As far as I can tell everything is grounded fine.
Could it be the starter is going bad? Would that cause that one wire to get hot and smoke a little? Last edited by Mrturner1; 06-23-2016 at 05:18 PM. |
06-23-2016, 05:50 PM | #37 |
What wire ?
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
06-23-2016, 06:01 PM | #38 |
06-23-2016, 06:10 PM | #39 |
I'm not aware of a wire from the starter going to the block ?
06-23-2016, 06:24 PM | #40 |
So I started going over some wiring diagrams that I saw member VetVette post a while back, and I was comparing it to my engine harness and noticed that I still have a bunch of wires from the old points ignition system. There was a yellow wire going from the firewall block on drivers side, to the distributor pigtail, and also over to the starter. With the old points system the yellow wire powered the start of the starter, or something like that. Point is, it's old wiring. The big purple wire going to the starter is the only one I need, and that goes to the ignition. SO, the red wire coming from the pigtail in the distributor that USED to go to the yellow wire (toast) now needs to go to a 12v keyed ignition source, which I have yet to find.
Another fire hazard avoided on the farm c10!! Any suggestions on where to put the red wire going to the distributor would be great |
06-23-2016, 06:55 PM | #41 |
Ok fuse block not engine block , whew ! Looks like you taped into the ignition resistance wire ,needs to be reg 12 volt in the on and start position . Best you do the Google search for a HEI wiring diagram rather than try to explain in detail .
06-23-2016, 07:07 PM | #42 |
That's how it's been wired since I got the truck believe it or not! I guess the yellow wire started getting resistance with the power from the new alternator? All I can think of. My engine bay is a lot cleaner I can say that
06-23-2016, 07:07 PM | #43 |
Maybe it's because it sat for a week but I am noticing some smoke coming from the breather.
06-23-2016, 07:32 PM | #44 |
no big deal , when I sit on the couch for a week I get a little smoke out of my breather too !
You know working on these old trucks with old wiring it won't hurt anything to check your wiring connections with a multi meter to see if your getting the correct voltage to the component it's feeding .
06-23-2016, 07:47 PM | #45 |
Now thats funny GOM!
06-23-2016, 08:46 PM | #46 | |
06-23-2016, 09:24 PM | #47 |
Multi meter from harbor freight are cheap like $5
