Old 07-10-2016, 09:37 AM   #26
Re: Rocker that fits
I am using Key Parts/Tri-Plus (same thing) rockers instead of my highly valuable N.O.S. because they fit just fine for me in the past and are as heavy gauge as factory. Looks like you got a defective one.
Old 07-10-2016, 11:07 AM   #27
tommys72
tommys72's Avatar
i sold my NOS rockers and cab corners one time when i got in a pinch...wish i wouldnt have now
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 07-10-2016, 12:20 PM   #28
GR8-68
GR8-68's Avatar
Then sell me those nos rockers
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 07-10-2016, 08:50 PM   #29
Nsanehotrodz
Nsanehotrodz's Avatar
Originally Posted by 718jwh View Post
Putting on new rockers on my 72 I have a Key parts rocker but it does not fit that well (see picture) anyone know a brand that fits better
John
You have what should have been a reject outer rocker. Does that rocker have more than one sticker on it?
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 07-10-2016, 09:16 PM   #30
swamp rat
swamp rat's Avatar
I can tell you mine did and i won't name the vender here
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-18-2016, 10:20 AM   #31
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Originally Posted by swamp rat View Post
I was also told that Tri-Plus and Key parts are the same, i often wondered if its possible the die press sometimes does not stamp all the way and as such does not form the bends properly? Factory reject passed on to someone? One dealer gets the crap at a discounted price?
I also had to clearance the Tri Plus inner rocker around the A pillar area. And both my Tabco and Tri Plus A pillars needed a lot of persuasion to get aligned.
I have seen and subscribed to a thread showing all the cab corners stacked on top of each other and it looked like the Tabco was the best, i'm still undecided on the outer rockers tho.
Same here. I know these are overseas stampings and we're all fixing 40+ year old rusted tweaked out cabs. I also know I expect to have to a little 'massaging" of the patch panels in some areas. I didn't expect them to be a direct weld in, but I've had to do more work than I thought I was going to have to for these panels to fit correctly.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 07-18-2016, 10:52 AM   #32
718jwh
only one sticker on the rocker got it from LMC, I ordered the Tabco and it should be here today, I will let you know how it fits.
John
718jwh is offline   Reply With Quote
Old 07-18-2016, 05:30 PM   #33
718jwh
Got the Tabco rocker, although it fits a little better in the problem area it fits badly in all other areas in fact it is a 1/2" shorter when measured from the top of the weatherstrip lip to bottom of rocker which makes the inner rocker not fit in the lip so I guess I will use the Key parts rocker. Thanks everyone for the input.
John
Old 03-28-2017, 02:08 PM   #34
GASoline71
GASoline71's Avatar
Bringing this one back up as I'm in the same boat still. Too bad about the Tabco not fitting well. I am going to buy another rocker soon, and was going to try the Tabco. Oh well. Eventually I will get one that fits well enough to make work.
Gary
