#26 |
Re: Anyone else have this happen
#27 |
All about them K’s
![]() Join Date: Jun 2014
I have to admit I'm guilty of forgetting my face shield from time to time but I always wear my safety glasses. Stuff like this thread makes you think about things more carefully. Hope that gash gets better soon(and the semi severed finger)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#28 | |
#29 |
man, just want to say......thank you for sharing this. i always wear eye protection and gloves while on the cut off wheel.............thats NOT enough. I will wear shield from here out.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579 |
#30 |
I don't trust those wheels. spend 20 bucks on a metal diamond wheel and you'll feel a lot safer and you save on replacements!
#31 |
I refuse to use those thin cutoff wheels,too scary. Remember if any wheel is dropped throw it away! I bought a plasma cutter instead.
I had to go to the eye surgeon because of grinding for one second without my safety glasses and got 3 lil metal shards in my eye. All worked out, but Doc was ticked about my ignorance, never again. |
#32 |
I will add this. Had a impact socket shatter from harbor freight. No injuries luckly. But damn what a sound it made. Mostly junk there at HF
#33 |
I've never had any issue with the thin cutoff wheels from name-brands like DeWalt. The cheap ones are worthless, even if not from harbor freight. They get out of round, and ragged on the edges, and hack up the material, even when they don't fly apart.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
#34 |
Safety squints definitely aren't enough with grinders and especially death wheels. At home there's a face shield and gloves in the drawer on top of the grinder, same thing on the work van.
Funny story. Was using grinder with cutoff wheel on a 3/8" thick bolt inside of a restaurant hood (think sheetmetal box) when the wheel let go. Had faceshield on and gloves on. Pieces of the damn wheel bounced around in the hood to hit on the side of the head. Got a scratch and little puncture wound from it but all minor. Can't protect against everything but without the faceshield my eyes and face would've been blasted too. |
#35 | |
![]() Join Date: Nov 2004
I've had plenty of the smaller dremmel discs explode, I'm guessing they're made similar to the larger HF wheels everyone is having issues with. I did get hit next to the eye with a dremmel disc one time, it went between my safety glasses and face. Freaked me out. Wear my face shield most of the time now.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#36 | |
#37 |
I've used those disk to cut a ton of steel for many years.
The root cause is plunge cutting! So either don't plunge cut or if you do be sure to hold the grinder square to the cut. If it goes wonky toss the disk and get a new one. |
#38 |
Hmmm... I may have just learned something. I always wear goggles but only wear a face shield for grinding (where there are sparks and stuff), not for cutting. I've never had a cutoff wheel fail but it's clearly a bad day when they do. I'll start wearing the shield!
#39 |
![]() Join Date: Jan 2015
Its only a flesh wound!!
1969 C20 Suburban "Rez Dog" Rebuild America one testicle at a time. US Army 1977-1979 12B Combat Engineer US Navy 1979-1983 Gunners Mate Guns (GMG) NRA Life Member Unrestrained Children in back seats cause Accidents. Unrestrained Accidents in back seats cause Children. |
#40 | |
#41 |
Was they harbor freight safety glasses. Lol
#42 |
![]() Join Date: Apr 2016
This is a good thread. Perhaps you more experienced folks could elaborate for us about cutting in direction of the rotation, plunge cutting, square to the cut, chipping away, etc. Pictures showing the correct ways would be especially nice.
#43 |
Just curious, but how many of you are using cut off wheels with a die grinder with no shield?
I use an older version of this: ![]() It's a lot nicer to use than most. It's quiet, powerful, and doesn't get freezing cold after a couple of minutes. I also use higher quality discs, and have never had one explode. |
#44 |
This is the reason an angle grinder be it a 4-5-6-8" or one for the 3" wheels have a guard.. that covers 1/2 of the wheel..
use it.. better 3" grinders have see through shields.. even my el cheapo C/p had this.. |
#45 |
I use these 3'' cut off wheels every single day of my life cutting stainless pipe up to 52 inch in diameter somtimes , I can go through a box of a 100 wheels in a week , the machine you use must not have a rpm value higher them the cutting wheel rpm value ,that is the most common way the cut off wheel wil explode. wear safty glasess and safty shield over glasses , and a good set of gloves (PSE) personal safty equipment is a must .
Think of it as putting 100 MPH rated tires on a Nascar that going to drive 200 MPH in a race. what do you think will happen to that tire Last edited by Jrainman; 02-03-2017 at 08:16 AM. Reason: addirtion |
#46 |
Active Member
![]() Join Date: Oct 2009
That's all I have ever use is Harbor Freight grinding wheel I've had a few of them blow apart seems to me they do it when they're about half worn out . U must put safety first.
#47 |
Ill admit I have never had one come apart. even the cheap ones. But there several factors that affect the integrity of these little wheels.
Age and how they are stored. Are they just thrown in the tool box randomly. Dropped at all. throw away!!!!!!! Are they stored next to any Hydrocarbon fuels or any other chemicals. This will break down the wheel. |
