#26 |
Re: Dirty Dingo LS Low Mount A/C Bracket
I'd love to send you one to test fit, but I unfortunately don't have any authority to do so. The best I'll be able to do to help in that regard is to post dimensions on it as we get closer to its release.
#27 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#28 |
I've been looking at this mount. Was going to try to use it with my level 3 dropmember. Its kind of my last option. I can't put it up high because of my turbo. But down low is tight because of the pb motor mounts. Anyone used it with a dropmember yet?
Todd https://www.instagram.com/shores6/ Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419 |
#29 |
Since this thread is supposed to be about the Dirty Dingo mounts, here are some pics of that bracket installed into my 71 factory frame, factory cross member.
![]() ![]() ![]() I'm using 45* EZ Clip fittings for the lines, in case anyone is wondering.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) Last edited by knomadd; 01-03-2019 at 11:30 PM. |
#30 | |
#31 |
That DD mount seems to provide good fitment in your application...nice pics.
#32 |
what headers are you using brother?
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 C10 Club Texas -HMIC |
#33 |
Hey Ruben, I will be using Doug Thorley Tri-Ys, 324Y-C to be exact.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#34 |
thx for the info brother
#35 |
I'm considering the Alan grove low bracket. I have a high mount kwik bracket right now and it throws the belt if I get on it. Everything's lined up, I think the tensioner isn't keeping things tight enough and it's brand new. I have ECE motor mounts, so I believe my sanden compressor will fit down there okay.
#36 |
Senior Moment
![]() Join Date: Mar 2002
So bottom line, will this bracket clear the frame with the mounts described?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#37 |
I don't see why it wouldn't. I don't have any experience with the Holley mounts, but I don't suppose they will raise or lower the engine much. If they raise the engine, it should be fine. If it lowers it, you'll possibly have other issues to work with too, like the oil pan.
#38 | |
Senior Moment
#39 |
Anybody ever try the Dirty Dingo or Holley low mount on their 73-87 2wd C10 with the Holley mounts?
#40 |
Not to raise up an old thread, but I didn't see any resolution to this really. I need to keep my compressor in the stock location because I plan to have a passenger side log manifold style single turbo above. It seems the options appear to be:
1: keep the stock compressor with stock bracket and modify the frame to deal with refrigerant lines and compressor clearances. This will not allow the use of sliding engine mount brackets. 2: Dirty dingo bracket with small sanden compressor. This seems to be the best fitting option as the compressor is compact and very tight to the block. I have POL tubular perches and was going to buy a sliding "adjust2fit" bracket to go with the POL poly mounts I already have. 3: Alan grove bracket which will work, but uses a larger sanden compressor. Might be a tighter fit? May or may not work with adjustable engine mounts? With the LQ4 LS gen3 truck engine, is it necessary that I need adjustable "sliding" engine brackets? I won't know this (unless someone chimes in) until I actually fit the engine in place. It would be nice to get what I need so I don't have to mess around with dry fitting the cab just to see if the block will clear the firewall etc. It is so much nicer to mount all the brake lines, fuel lines, air ride lines, wiring, etc, without the cab in place. I'll take more time and it'll be a much prettier result without the cab set in place. |
#41 | |
Posted via Mobile Device |
#42 |
did you need or use adjustable engine mounts to slide the engine forward or backward for clearances to the cab/firewall?
#43 |
I did not buy the slider kind of adapters, but I did have the adjustable kind (3 different motor mount positions). The sliders would have potentially been easier to get the engine in the right spot, but I did move them and the engine perches about 4 times to get the cab and crossmember clearances just right. There is absolutely NO WAY I'd try to get the engine mounted and "set" without at least checking the firewall clearance. There isn't a lot of movement front to back to fit between the firewall, radiator and crossmember.
#44 |
Finally came in and got it installed. Looks like it may work. Fits nicely. I’ll know more when I get the engine installed on the frame.
#45 |
Digging up an old post yet again....
I am curious and concerned on how well a mini Sanden would preform on an otherwise stock AC system on a crew cab squarebody. Old Air suggested a Sanden 709 to replace the HR6 (A6 style) compressor. I too am going to run a turbo LS setup like the rest of my rides.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#46 |
Reviving this thread...anyone else used this recently? I'm looking at using this really soon. Hoping it will fit my 2006 5.3 L33 block and clear the 68 frame well in the space..
I was advised that using this kit and smaller SD7B10 compressor requires custom lines to be made, the lines that come with the vintage air kit can't be used. ? Anyone know why that might be? https://www.dirtydingo.com/shop/prod...oducts_id=1756
![]() ___________________________________________ '68 C10 true shortbed, LS swap restomod. '03 Z71 daily, '63 AMC Rambler V8 survivor |
