Old 08-08-2016, 01:35 PM   #26
656mx
Re: 1991 electric suburban gauges into a square ls swap
The motor is now in my buddy's truck but its at my house to get wired. I will look at it tonight and see what the size is.
656mx is offline   Reply With Quote
Old 08-08-2016, 01:43 PM   #27
chuychevy82lwb
Quick question guys how would i wire it? Would i jist run my oem oil pressure wire from my gaiges to the oil pressure sensor /canister ?
82 lwb lsx 5.3/4l60e 12 bolt rear lambo electric blue/ hummer black with house of color flake same colors on the inside with all new upholstery n 22s. " Who said longbeds cant look good "
chuychevy82lwb is offline   Reply With Quote
Old 08-08-2016, 01:55 PM   #28
foamypirate
foamypirate's Avatar
Yep, it would plug in just like stock. It's just a basic spade terminal.
foamypirate is offline   Reply With Quote
Old 08-08-2016, 03:08 PM   #29
chuychevy82lwb
Sweet if i have time when i get out of work ill definitely try and do that . Have yall guys heard about using a 95-98 trans am /camaro temp. Sending sensor (3wire sender) to use the temp. Gauge with out adapter
Old 08-08-2016, 03:21 PM   #30
foamypirate
Yessir, that's what I have on my swap. I bought an adapter on ebay so I didn't have to modify my harness (it had a 2 wire CTS plug). The adapter plugs into the 3-wire plug, has a small lead to tie into your gauge wire, and then you plug the 2 wire harness plug into the adapter.
Old 08-08-2016, 05:09 PM   #31
chuychevy82lwb
Would you have a pic of it or part number or how to look for it?
Old 08-08-2016, 06:18 PM   #32
NorCalAnthony
Looks good from the little info that i have ita just the 89-91 burban gauges.
Just to clarify, only the 90-91 K-5's, Suburbans, and R/V trucks got the electronic speedo. My 89 K-5 was an oddball year because they came with the newer NP241C but still ran a cable speedo so I wound up having to pull the gauge cluster from a 90 Suburban for my swap.
NorCalAnthony is offline   Reply With Quote
Old 08-08-2016, 08:50 PM   #33
foamypirate
I can't seem to find any on the sellers store right now.
Here was the description for the auction:
LS1 LS2 LS6 Swap Retrofit Coolant Gauge Wiring Harness
and the seller was tpi_parts
They may add it again later, not sure. It's possible they don't offer it anymore.
Old 08-08-2016, 11:04 PM   #34
656mx
I have heard of doing it that way. I went the way I did because it was free. I double checked my sender was 1/8 so I tapped it 1/4 and used a bushing. You can get the sender in 1/4 and eliminate the bushing too.
