07-27-2016, 02:18 PM | #26 |
Check The Champ, Demonstrator
Re: 1962 C40 milk truck suspension upgrades ?
I agree Ice Cream Truck sounds much more appealing.
Do you know who built the body on the truck?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
07-27-2016, 02:50 PM | #27 | |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Well i guess it depends on if it has a 383 stroker with a cross ram...Not sure what i want to put it in just yet. The stroker either goes in here or a 70 SWB with porter gear all the way around.....one of the two . It dyno'd at over 500 HP
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
07-27-2016, 02:54 PM | #28 |
Yes it till has the body tag on it...SNYDER Seattle WA
07-27-2016, 02:56 PM | #29 | |
measures 28" outside to outside thae same as the 66 Camper special cross member i have does
07-27-2016, 03:14 PM | #30 |
Okay so these are the A arms off the 66 camper special....bottom arms note the flat control arm shafts . Now if that 66 camper special infact has a 1 ton crossmember in it in theory i could use that with the a arms and swap out the upper and lower ball joints to run what ever year of spindles i want to use .....right ?
So looking under the C40 right now the lower a arms sure do look alot like the camper special ones...granted i haven't held them up or measured them but they look to mount the same . I know i want to loose the torsion bars...I know i want discs ....i know i want power steering.....i know i want alcoa wheels .....So..your all smarter then me where does this out us ?... I want to use it for a shop truck to haul parts around with leave it patina ish...load stuff back and forth to the car shows we do . Thinking coils when i put it together then bag down next year .I want the boys to have fun building something for the shop....Budget mostly free using stuff we have lol ...ya i have that stroker motor in my office it makes me smile when i look at it everyday.
07-27-2016, 03:51 PM | #31 |
Take Two!
07-27-2016, 04:00 PM | #32 |
The magic words "In Theory"
If it was ME I would hunt an old one ton & snatch the whole cross member suspension spindles & all at one time, if you can find one. Note- Not seen a cross ram on an engine since high school! |
07-27-2016, 05:36 PM | #33 |
07-27-2016, 05:38 PM | #34 |
We called down to edelbrock and tried to match a cam for the crossram and there was only one guy left that had a clue what to do.....and he was retiring in a month. Thats how old school that is now
07-28-2016, 01:07 AM | #35 |
60-66 Nut
I would be interested in those cam specs. I also have a crossram that needs to be put to use.
All you need to do for your front suspension and brakes, is find a '71-'86 C20/30 or '87-'91 R2500/3500 front suspension and swap the crossmember and all. It's as simple as that since your frame is 28" wide.
07-28-2016, 11:10 AM | #36 |
I want more pictures!!!!
Awesome truck |
07-29-2016, 12:29 PM | #37 | |
07-29-2016, 12:30 PM | #38 |
it's so ugly is almost cool.....lol
07-30-2016, 12:50 AM | #39 |
60-66 Nut
I have the Edelbrock CX8 also. I've had it for probably 30 years and have yet to run it. I had never thought about a custom ground cam being beneficial for a crossram.
