Old 08-10-2016, 10:35 PM   #26
OneOffStroker
Re: Bagged woes
Originally Posted by joedoh View Post
ok, oneoffstroker, I need to see some pictures of this ride height setup. every bit of research into leveling systems I see shows it requires two leveling valves per wheel (or two per axle if you are teed), two solenoid valves per wheel (or axle) and a pressure switch added to each wheel (or axle). the only way I see it working with one leveling valve and two solenoids per wheel (I havent seen how it works with only one solenoid yet because when I do a truth table the tank will exhaust through the dump valve if you only have one solenoid). I even looked at kneeling bus system diagrams and they are even more complex.
please, can you show us a couple pictures of your setup for clarity? it sounds promising!
I don't have any pictures now, and I am horrible about posting them, but I'll see what I can do.
I am quite sure that you have been looking into electric leveling systems, hence the multiple valves per wheel and so on. It does not have to be that hard, trust me.
About thinking that the valve just dumps the air from the tank, it absolutely does not. When the dump portion actuates, it vents the bag, but closes the supply. Think of it as a SPDT electrical switch, but in a manual pneumatic setting.
I hope that makes some sense.
Originally Posted by 59chev View Post
Following..
Alot of us are intregued by this manual - automatic leveling option.
As I understand it, this would only work with the height control valves that have an integrated dump valve. When the dump valve is activated, it dumps the air in the bags and closes the intake valve at the same time. When the dump valve is closed, the height control valve returns to normal mode and re-inflates the bags until the truck comes back up to ride height.
YOU ARE EXACTLY CORRECT.
Originally Posted by e015475 View Post
I took a stab at drawing a schematic of what the OP described. Would appreciate any feedback from the OP as to its correctness-
When there's air pressure supplied from the tank to the pilot air port on the height control valve, the height control valve will function to regulate the height of the airbag (the red line on the schematic is the pilot/dump air controlled by the TW-1 valve)
If the pilot air is removed, the height control valve dumps the air out of the airbag.
Is this correct?
CORRECT.
The OPs description of the height control valve wouldn't have any solenoids either, and would be a 'set it and forget it' system, with the option to dump the airbags with the TW1.
But with the OPs system, the only way you can change ride height is to adjust the linkage to the height valves, which is ok with me. Once i get it set to a height I like, I'd likely just leave it there.
CORRECT
Originally Posted by 47 Fasttoys View Post
Sounds like a good system. I do adjust mine a little but I also load my truck on a regular basis as I pull a camper or boat and load all kinds of junk on the back so in my case I need the ability to adjust. My only question would be with the ride height dump valves do you end up with alot of compressor cycling because the valves are making regular adjustments? by this I mean what happens when you go into a long sweeping corner? The more I think about it with this system I would not have to adgust for load it would do it for me, correct?
You are correct in that the system could constantly use air when the suspension flexes, but minute changes aren't that big of a deal, so compressor cycling is about the same as it is with a fancy high-dollar Accuair system. I want to be frank here and mention that I am not dogging on Accuair. In fact, I have their Gen 1 setup in my '50 F1, and will be buying a new one for my '57. Some projects are worth spending the money on...
Also, yes, you set it and forget it. If you add load to your truck, it will automatically compensate and air back up.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 08-10-2016, 11:57 PM   #27
59chev
59chev's Avatar
Re: Bagged woes
This thread is great!!!
The only thing I am still struggling with is the whole Normally open vs Normally closed thing. Doesn't normally open mean that it requires pressure on the pilot side to dump the valve? I guess when it comes down to it it doesn't really matter as long as you provide the correct signal via the pilot circuit.
For example:
http://veritastechsoft.com/dealer_tr...mp-valve-mack/
Am I missing something?
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 08-11-2016, 09:08 AM   #28
joedoh
joedoh's Avatar
Re: Bagged woes
yeah this is a neat solution for sure.
it was my theory (and I havent used this system) that you need a NO valve only because when the truck is dumped using a NC valve means it would have to be energized the whole time its dumped. I could be wrong, which is why I asked for details. the only way I saw it working with a NC was with a second NC valve in line so that when you dumped the pilot air it stayed at zero.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-11-2016, 09:13 AM   #29
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Bagged woes
59 chev...A normally open valve is a valve that in its non operating mode is fully open and requires constant power input to close it.take power awayand it goes back to full open..a normally closed valve works just the opposite..its fully closed until you supply constant input power to open it..take power away and it goes back to a closed position..
Old 08-11-2016, 11:25 AM   #30
59chev
59chev's Avatar
Re: Bagged woes
I agree that the ideal situation is to remove the pilot air in order to signal the dump valve to dump the air. What I'm confused by is in researching these valves, the description of Normally Open says it needs air to dump.
This seems opposite to what everyone is saying based on the description of normally open
See attached image of the valve I linked to.
Old 08-11-2016, 11:32 AM   #31
joedoh
joedoh's Avatar
Re: Bagged woes
oh I see what you are asking. it was oneoffstroker that said flipping the switch REMOVES the pilot air, so that was the assumption I worked with. looks like the valve you found works the other way, requires pressure to dump.
this adds a wrinkle to finding leaks in the system, because if you lay it out and have a leak in the pilot system, you may come out in the morning and find your truck at ride height which to anyone who has had an airbag system, thats a good problem to have because usually you find it flat on the ground with no air in the system
Old 08-11-2016, 11:57 AM   #32
mongocanfly
Post Whore
Re: Bagged woes
Yeah that don't sound right..requiring pilot pressure to open a valve means the valve has to be normally closed ..take away the pilot pressure and the valve closes..
Old 08-11-2016, 09:42 PM   #33
OneOffStroker
Re: Bagged woes
Yeah, that's my bad. I misspoke. Sorry about that, it's just counterintuitive, so I guess I wrote what seems to make sense instead of the proper, albeit weird, operation.
I hope someone else adopts this system for their truck. It's pretty legit.
Old 08-11-2016, 11:19 PM   #34
Foot Stomper
Foot Stomper's Avatar
Re: Bagged woes
Originally Posted by IndyBowtie View Post
Alright need some bag advise. I fully understand every person that replies will have a diff answer but that's ok.
Have a full manual system on the '48. 8 valves and wired controller in cab.
My problem is getting the truck level, side to side at ride height. I fight it every time I drive the truck.
What is the best method for ride height leveling, outside of a AccuAir sys?
Seems that having the 2 on the rear for example, plumbed individually, raise and exhaust at diff rates. Thus I Am always out of level side to side. Thought I had it perfect the other day.based off of quick look and the gauge pressures..got home and went to the back to check...one side was quite a bit higher than the other. That's a good look!
Thinking about putting a tee inline and plumb the rear together , as well as the front. But then you depend on the bags sitting at the same height at a given pressure and they probably won't!
Am I doomed to spend another grand and get the ride height controlled sys?
Stock suspension never had these issues... perhaps you messed up a perfectly designed suspension?
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 08-11-2016, 11:56 PM   #35
59chev
59chev's Avatar
Re: Bagged woes
No worries man. It seemed backwards to me too. That's why I was confused. I just wanted to make sure I got the right valve when the time comes. I am really interested to try this system.
Thanks again for posting this idea!!
Old 08-29-2016, 07:47 PM   #36
ADchevys
Re: Bagged woes
Just ordered my valve, should have it tomorrow. Sence I'm only bagged in the rear I really liked this idea. I will let everyone know how this works out.
ADchevys is offline   Reply With Quote
Old 08-29-2016, 11:54 PM   #37
59chev
59chev's Avatar
Re: Bagged woes
Cool!! Really interested to hear how this works out.
Old 08-30-2016, 09:33 PM   #38
ADchevys
Re: Bagged woes
Just got done installing the vale. I'm think I'm going to like the simplicity of this setup. Thanks for the idea OneOffStroker. Here's a short video, the truck will drop faster when there's more weight on it. The valve I used takes air pressure to dump.
[IMG][/IMG]
Old 08-30-2016, 09:40 PM   #39
ADchevys
Re: Bagged woes
Here's another picture. The port on the front is the dump, the first port on top is to the bags, and second port on top is the air in.
[IMG][/IMG]
Old 08-31-2016, 12:50 AM   #40
joedoh
joedoh's Avatar
Re: Bagged woes
great video! thanks for posting!
Old 08-31-2016, 02:23 PM   #41
LS2 67GTO
Re: Bagged woes
[IMG][/IMG]
Thanks for posting pics. Do you have a part number for the valve you used?
LS2 67GTO is offline   Reply With Quote
Old 08-31-2016, 02:40 PM   #42
ADchevys
Re: Bagged woes
http://www.anythingtruck.com/product/270-E11870.html
I bought mine local, but this is the valve I used.
Old 09-01-2016, 04:02 PM   #43
OneOffStroker
Re: Bagged woes
ADchevys, great video and pic. I'm glad I was able to convince at least one person to try this setup! Maybe if it gains popularity, I can be the namesake for the mod. lol Like, 'Stroker's Manual Ride-Height System' or something like that.
LS267GTO, here is the valve I used when I did mine. http://www.ebay.com/itm/310636490872...%3AMEBIDX%3AIT
Old 12-16-2018, 06:16 PM   #44
f.flujan
Re: Bagged woes
Old thread but really like this. Any updates on functionality
f.flujan is offline   Reply With Quote
Old 12-16-2018, 06:37 PM   #45
dsraven
Re: Bagged woes
haldex valve with pilot port
this is usually "aired up" in order to dump the air springs. truckers use this to lower suspension so they can back under the trailer they are connecting to. less time and energy spent cranking the trailer dolly legs up.
https://www.haldex.com/globalassets/...ols/l31186.pdf
Old 12-17-2018, 08:49 AM   #46
f.flujan
Re: Bagged woes
dsraven, can you send me some pics of it installed in the front. really considering it. like the simplicity and really seems like a reliable system
thank you
Old 12-17-2018, 08:53 AM   #47
f.flujan
Re: Bagged woes
Also, if running these at each corner would making a manifold for the dump valve be functional (i just want one dump valve in the cab). How much psi is needed at the pilot dump is what I'm asking pretty much. thanks again
Old 12-17-2018, 02:04 PM   #48
dsraven
Re: Bagged woes
I don't have a pic, I have just worked on the big trucks that use this type of system. they are used for everything from air ride cabs to truck suspension or trailer air ride.
for a manifold, yes, you would simply need a dump valve on the dash or wherever that would supply system air (greater than 60 psi and up to 130 psi) out to a manifold that would run to each valve. an electric solenoid valve would also work so the air lines could stay outside the cab and just have wire run to the dump valve from an in cab switch. from there T off and run a line to the front, where it could T again to each side valve, and then the same for the rear. less air line equals less air required to fill the lines so running an air line from each valve to the manifold would take more air and also more room. less air line would mean a quicker response and less compressor run time. a larger line to the front and rear could be T'd at each end to smaller line for each valve if you think it warrants that. sometimes a slower dump is better. you could also do a dual system so you can dump just the front or the rear. this is what you see city busses do when they "kneel" for handicap access. but thats up to you and your wants/needs. these valves would be available online or at your local highway truck parts shop. even some truck stops may have them. pretty common valve because lots more big trucks are air ride these days, but, you could also ask at the truck parts place if there is a more common valve. just a bit of time on the phone. hope this helps.
here is a link to the haldex site which shows a bunch of control valves.
http://www.heightcontrolvalve.com/haldex-19.htm
here is a link explaining the normally open or normally closed dump valve options and how they work
http://www.plazafleetparts.com/air-s...ol-valves.html
Old 12-17-2018, 02:09 PM   #49
dsraven
Re: Bagged woes
another thing to watch for is where to mount the valves. a single valve mounted in the middle of the axle could do the whole rear end but not be specific to each side. less messing around with getting them syncronized so one doesn't fight the other. if you need room for rear dump exhaust pipes or whatever then that may also dictate the valve mounting and air line routing. always try to cover the plastic line with something to stop chaffing unless it is tied down well. some heat shielding may also be required if close enough to exhaust systems.
