Old 08-20-2016, 12:20 PM   #26
dads1967dream
Re: AMP vs Volts Hookup on 67
I am going through everything again. Jumped wires, still will not come on in full out position. Going to mount all the lights and see if something changes. Has anyone had to modify the ignition hole to fit new switch. I believe my dad got this from Brothers, the back mount and bezel are at least twice the size hole that was in the dash.
dads1967dream is offline   Reply With Quote
Old 08-20-2016, 12:29 PM   #27
Grumpy old man
Grumpy old man's Avatar
You need a 67 one year only ignition ,the one you have is 68-72
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 08-25-2016, 08:42 PM   #28
dads1967dream
Does anyone know what size oil pressure hole is on the back of a 350 Edlebrock RPM intake, I have the copper install kit but do not have that fitting. Thanks
Old 08-27-2016, 03:15 PM   #29
dads1967dream
Need to know where this bracket goes. Image is in attachments if I did it right.
Old 08-27-2016, 05:14 PM   #30
dads1967dream
Do you by chance know what this bracket goes to. Thanks for all your help, going slow but at least it is finally being put back together.
Old 08-27-2016, 09:53 PM   #31
dads1967dream
Found it in the LMC catalog. Center grill support for the 67.
Old 08-27-2016, 10:06 PM   #32
dads1967dream
Old 08-29-2016, 12:45 AM   #33
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I/8th NPT but it isn''t on the intake, it's on the block.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 08-29-2016, 05:15 AM   #34
dads1967dream
Thanks. I am assuming I use one of the fittings in the SunPro kit for that hole and another for the gauge.
Old 08-29-2016, 12:14 PM   #35
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes and you can also use a short nipple with a connector to raise it up a little off the block. I used a tee on mine so I could have the mechanical gauge in the aftermarket kit and also the light in my dash cluster.
VetteVet
Old 08-29-2016, 04:55 PM   #36
dads1967dream
Thsnks. Have you run into a problem with the lower radiator hose resting on the passenger side frame where it is turned up. I just received new hoses from classic industries and it looks like the same rubbing problem will occur.
Old 08-29-2016, 07:54 PM   #37
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Yes I have the same problem, as do most of the other members. It is due to the curve of the right frame member and the low location of the lower radiator outlet. The stock radiator outlets are curved upward, but they still come close to the frame. I cut a larger hose and tie-wrapped it around the radiator hose at the interference location. Until I come up with a better fix I guess that will have to do. I have one of the stainless hoses that are smaller in diameter that I plan to use, mainly for the bling value, but also to clear the rail.
If you start anew thread on just this problem we might get some better answers. VV
VetteVet
