03-15-2017, 10:53 PM | #26 |
Re: Scored an engine for my Camaro
It cleaned up nice, I put a 6.0 in 90 iroc. It is one bad street car. I would lots rather be working on my 67 c10 though. The camaro got to tight to work on and drive. You will enjoy that ls power.
03-15-2017, 11:13 PM | #27 |
03-16-2017, 07:43 AM | #28 |
Wow , 444 ft lb torque before 3000rpm . Some of that is a little spike at throttle stab but is still holding on pretty good even at 4000rpm . That is impressive and will get it moving nicely . Still holding on pretty good up top also . That low end torque will out perform a bigger cam/HP car of the same caliber any day at the track . Big cams will give you that upper hp number and pull at the far end but its hard to catch up 2 car lengths .
Good job . |
03-16-2017, 10:59 PM | #29 |
That's a low dyno for a 6.2 with a cam, at least from what I've seen.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
03-16-2017, 11:34 PM | #30 | |
I took a cheap Escalade engine that's rated at 405hp at the crank & made that at the rear wheels with a mild cam, I'm happy with the results. |
03-17-2017, 09:29 AM | #31 |
Post Whore
Those are some good numbers...now need to start buying extra rear tires
03-17-2017, 09:42 AM | #32 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
