Old 08-23-2016, 10:52 AM   #26
TJ's Chevy
TJ's Chevy's Avatar
Re: Most rotted '62 K20?
Originally Posted by 5Tractorguy View Post
Update here folks.....
Apparently someone changed their mind. My friend got a hold of me today and said I'm going to end up with the truck. So it looks like I'll have to get operation rot box in motion. Going to see if I can get it to the house by the end of the week. More to follow.....
That truck will be way to nice for you, I'll take it right off yours hands and save you the burden of doing all that waxing and polishing.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-23-2016, 11:12 AM   #27
Mathew21
Mathew21's Avatar
Awesome another one saved from the crusher.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 08-23-2016, 02:36 PM   #28
5Tractorguy
5Tractorguy's Avatar
Suuuure thing TJ! But buy the time you finish trailering it back to Oregon I think most of it will have blown away!
It'll be here tomorrow before noon folks! Might be an overview video on YT to follow....
Jake
5Tractorguy on Youtube
5Tractorguy is offline   Reply With Quote
Old 08-23-2016, 08:43 PM   #29
RANDY COX
RANDY COX's Avatar
we'll be waiting and watching....
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-24-2016, 09:23 PM   #30
5Tractorguy
Aaaand we made it home in one piece! This thing is really bad now that I had a good chance to look at it. Engine is stuck far as I can tell, need to see if I can give it a good yank with something, probably going to put some oil in the cylinders tomorrow. Rolls good and steers so that's a plus. The guy had 4 layers of that original style rubber mat on the floors to cover the rot holes.
AND I found out it is actually a C20 dropped onto a K20 frame! the VIN tag on the cab starts with 2C25********* and the hump in the floor was not spot welded by the firewall. It was a low hump floor, 3 on the tree, and someone flame cut a high hump cover and dropped it over.
Here's a bunch of pictures for now, working on a video for today and tomorrows events...
Size:  80.3 KB Name:  DSCN2859.jpg
Size:  74.9 KB Name:  DSCN2891.jpg
Jake
Old 08-24-2016, 09:24 PM   #31
5Tractorguy
Size:  41.6 KB Name:  DSCN2902.jpg
Size:  60.7 KB Name:  DSCN2917.jpg
Jake
Old 08-24-2016, 09:25 PM   #32
5Tractorguy
Last for today...
Size:  64.3 KB Name:  DSCN2912.jpg
Size:  64.2 KB Name:  DSCN2905.jpg
Jake
Old 08-24-2016, 09:36 PM   #33
Praxiss454
Praxiss454's Avatar
Wow, not much left of that cab. Interested to see what you end up doing.
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 08-25-2016, 08:51 PM   #34
jdl71
jdl71's Avatar
That is the worst roof I have ever seen, yet I'm still jealous. Love your tow rig also.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-26-2016, 07:01 AM   #35
Ken B
Nice haul, that body is hurtin for certain!
Ken B is offline   Reply With Quote
Old 08-26-2016, 10:44 AM   #36
5Tractorguy
Yesterday I as able to get everything stripped down to frame, drive train, and engine. Spent a lot of time with the smoke wrench and saws-all. I didn't get much for parts off of it, but there are some miscellaneous things I can sell. Pulled the plugs from the engine and all but one cylinder have rust. Nothing too heavy, mostly from moisture. Poured some ATF down them so we'll see what happens in a couple days.
Here's the disassembly video- https://www.youtube.com/watch?v=u9EJt-ONKBU
Anyone know how to ID this engine since the ID tag in the truck isn't correct? Block numbers below...
Size:  72.2 KB Name:  DSCN2983.jpg
Size:  93.1 KB Name:  DSCN2956.jpg
Jake
Old 08-26-2016, 11:20 AM   #37
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Plenty of Wall and Yard art to work with. Man am I jealous.
Old 08-26-2016, 11:21 AM   #38
aerotruk63
aerotruk63's Avatar
Googled the part number of the casting
3769925
Manufacturer Chevrolet
Category Engine Blocks
Type Inline-6
Date 1958-1962
Notes 261 CID, Chevrolet
Old 08-26-2016, 09:01 PM   #39
RANDY COX
RANDY COX's Avatar
Man oh man that thing was ruff, but I see you didn't waist any time tearing that thing down..prolly wouldn't have been that bad inside if the glass was still in it...she came from the earth and let her return to the earth...well atleast you'll have a good frame and hopefully running gear...are you going to use this frame for your truck or have you gotten your other frame back...
1964 BBC 402 4x4
Old 08-26-2016, 09:48 PM   #40
5Tractorguy
Other frame is back, that situation sorted itself out earlier this year. Everything's back to normal again thankfully.
I'll probably do what I can to the engine on this one and then sell it.
Any ideas what the whole thing is worth as is?
Jake
Old 08-26-2016, 10:50 PM   #41
Brad54
Brad54's Avatar
What rear axle is under it?
Any chance the front axle is a posi? That'd help resale.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 08-28-2016, 06:38 PM   #42
5Tractorguy
Not sure of the rear axle Brad. Still have to delve into that.
Made some headway over the past 2 days. Got the engine unstuck, transmission shifter freed up and the head pulled off the engine. There was 3 stuck exhaust valves that lead to that. Turns out it was a good idea though since the buildup of crust in the ports and valve seats wasn't good. Still have to power wash the head and lap the seats.
Unfortunately I did break an exhaust valve removing it from the head. I was tapping it out by the stem and the head snapped off. You can see that is has been broken about 3/4 of the way through for some time.
Anyone have a spare used exhaust valve hanging around for a 261 straight 6?? Would rather not have to buy a new one in if possible....
Size:  65.8 KB Name:  DSCN3028.jpg
Size:  54.6 KB Name:  DSCN3030.jpg
Jake
Old 08-28-2016, 09:25 PM   #43
j.kirn
Rear axle is a Eaton H052
j.kirn is offline   Reply With Quote
Old 09-09-2016, 08:21 AM   #44
5Tractorguy
Thought some of you guys would appreciate this, some may have already seen it..... got 'er going again! Enjoy!
https://www.youtube.com/watch?v=0eanZ80tU5A
Jake
Old 09-09-2016, 11:15 AM   #45
62stepside longbox
62stepside longbox's Avatar
Sweet! Glad you got that 261 up and running, they are fun little engines. The truck is now almost like a full sized go kart, throw a rollbar, seat, gas tank and proper clutch and you're ready to go muddin!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 09-09-2016, 11:57 AM   #46
Softpatch
Softpatch's Avatar
"Most rotted" for sure thanks for sharing
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 09-09-2016, 07:46 PM   #47
jdl71
jdl71's Avatar
Did you have the t-case in neutral? Just wondering why the driveshaft was turning.
Psalm 23
64 C10
66 K20
Old 09-09-2016, 08:55 PM   #48
RANDY COX
RANDY COX's Avatar
Pretty Kool that you got that ole engine running again I enjoyed the video looks like something I would do...
1964 BBC 402 4x4
Old 09-10-2016, 06:44 AM   #49
5Tractorguy
It was in 2HI, the locking hubs are stuck in so it was still spinning.
Jake
Old 09-12-2016, 10:13 PM   #50
jdl71
jdl71's Avatar
Around 7:30 in your video when you first get it running and it's sitting still the driveshaft out of the trans is spinning. I'm assuming it's the divorced shaft between the trans and tcase, just wondering how it was turning when you weren't moving unless the tcase was in neutral.
Right around here
Psalm 23
64 C10
66 K20
