Old 10-08-2003, 08:22 AM   #26
Iron-Butt
454 club
Iron-Butt's Avatar
Great Job. They always look better when all the work is done.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-08-2003, 09:45 AM   #27
CPNE
Resident Curmudgeon
CPNE's Avatar
Wow, that's a lot of progress. I think you should do this for a living. If you can do 2 trucks a day and charge a flat rate for labor, I can see 6 figure income in your future. Just stay away from our rust-belt trucks. It takes the "heat and beat" method just to turn a nut which really eats into the time required.
2 hours to save $20? ...and I thought I was cheap
Looks like you'll have a nice cruiser when done.
FYI, those little 2wd pickups don't look like 4x4's even at stock height. Everybody knows a real working 4x4 has a plow on it with cab clearance lights
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-08-2003, 09:51 AM   #28
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
CPNE.....
I have been an ASE Master mechanic for 12 years and an Airframe and Powerplant mechanic for 9 years. I earned my fair share of money turning wrenches.
I changed careers 2 years ago. Now I work 24 hrs on and get 48 hrs off. It works out to either 2 or 3 days a week. Best schedule in the world. I get lots of free time to work on the side.
Old 10-08-2003, 10:01 AM   #29
N2TRUX
Happy to be here
N2TRUX's Avatar
Awesome job buddy. The green stepper is going to look good when it's done.
It sounds to me like you need to find another tire shop. I buy enough from my local shop that they never charge me for anything extra. They mount, balance, rotate, and repair flats for free....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-08-2003, 12:39 PM   #30
Tx Firefighter
IT'S DONE
Well, it's sitting back in the street again.
All done except for 2 items-
1) I still need to swap Mas cyl and prop valve
2) I need to run over to the dealer and get a sway bar clamp. One was bent. That's gonna cost 2.66.
Only problem I ran into was I forgot to buy 1/2 inch lugnuts. I scrounged through the garage and found 20 mismatched ones.
If the front springs don't settle any more, I'm going to have to put in a 3 inch drop spring to take it a total of 5 1/2 front 6 back.
Pictures tonight after the wifey gets home with the camera.
Kevin
Old 10-08-2003, 01:30 PM   #31
lock
Insert funny comment.
lock's Avatar
Make sure you get good pics of the rear end seutp. Looking forward to seeing that. Did you install one that needed new saddles or find a good direct replacement?
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 10-08-2003, 01:35 PM   #32
matt67350
matt67350's Avatar
Do you need that valve. ASAP?
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 10-08-2003, 02:12 PM   #33
oldsub86
hey TX Firefighter
get yourself one of the old style manual tire changing machines. I have one bolted to the floor in my garage and it works fine. Cost was about $50. It is a made in the far east replica of what the local garages had back in the 50's. Might want to be careful with aluminum wheels but it sure works good on the steel wheels.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 10-08-2003, 07:22 PM   #34
Tx Firefighter
THE FINISHED PRODUCT
Here it sits. If the front doesn't settle in a week or two, I'm going to lower it another inch.
Lock- tell me what pictures you want to see and I'll go take them.
Old 10-08-2003, 07:28 PM   #35
lock
lock's Avatar
That ride hight looks pretty sweet. Id jsut like to see you rear end suspension setup that you put in. Mainly the panhard bar.
- Mark
-My Build Thread...
-70 Camaro
Old 10-08-2003, 07:32 PM   #36
my new 72
faster, faster, faster
my new 72's Avatar
It should drop another inch or two when it all settles down. You'll hear a little pop when the springs seat all the way. It'll scare the hell out of ya if your not expecting it.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
Old 10-08-2003, 08:06 PM   #37
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Look's pretty damn good...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 10-08-2003, 08:11 PM   #38
Slammed67
Progress = 0%
Slammed67's Avatar
Looks great! Much better.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 10-08-2003, 09:30 PM   #39
theo70
COMING SOON...
theo70's Avatar
TX Firefighter--if I read correctly, you're temporarily still using the stock drum master cylinder/prop valve? This might be a dumb question, but does it stop well enough to drive?
theo70 is offline   Reply With Quote
Old 10-08-2003, 09:37 PM   #40
matt67350
matt67350's Avatar
You need a 454 in there to pull down the front. That 6 is way to light. LOL
Old 10-08-2003, 10:04 PM   #41
Tx Firefighter
I didn't even bother to bleed the brakes, so I don't know. It's going to take me a couple of weeks to get the scratch together to buy a booster and master cylinder and prop valve.
Pic of left side of super track bar. Notice it mount to stock bracket
Old 10-08-2003, 10:07 PM   #42
Tx Firefighter
Right side of super track bar. It mounts to a bracket between the axle saddle and trailing arm. The bolt is still loose because I haven't adjusted the rearend to center yet.
Old 10-08-2003, 10:10 PM   #43
Tx Firefighter
Comparison between the stock upper shock mount and the ECE mount kit. Notice it moves the hole rearward which places the shock more straight up and down. The ride improves the more vertical the shock is.
Old 10-08-2003, 10:14 PM   #44
Tx Firefighter
A close up of installed upper shock mount. Removing the rivets on the stock mounts was the hardest part of this job.
Old 10-09-2003, 12:45 AM   #45
Bowtie468
Bowtie468's Avatar
Looking sweet ! How much clearance do you have between the axle tubes and the frame? How about clearance between the bed floor and top of the differential housing? I'd like to squeeze a 7" drop out of the back if i could . Looking at yours, does it look like you could get another inch out of it even if you had to c-notch the frame? And for the final question, how much did your pinion angle change ?
Chris
Bowtie468
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 10-09-2003, 06:24 AM   #46
Tx Firefighter
I think you could get another inch drop if you wanted to. If you c-notch the frame, I know you could.
I'll measure the clearance tomorrow exactly. I have to work 24hrs today. I didn't measure the pinion angle before or after the job. I've dropped them 6 inches before with no pinion angle issues, so I didn't even worry about it.
Kevin
Old 10-09-2003, 09:13 AM   #47
lock
lock's Avatar
Nice pics Tx. Thanks!
- Mark
-My Build Thread...
-70 Camaro
Old 10-09-2003, 10:42 AM   #48
Adam12
I hate trannys
Adam12's Avatar
If you dont mind me asking how much was your total on parts for the job?
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do.
Adam12 is offline   Reply With Quote
Old 10-09-2003, 11:02 AM   #49
landon4421
Life is Good !
landon4421's Avatar
Dam that did make a big differance ! Your truck looks sweet now !
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 10-09-2003, 11:15 AM   #50
crazy4chevs
crazy4chevs's Avatar
looks great; It should settle down more with the small block in it.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
