Old 09-28-2016, 03:37 PM   #26
Dave0
Re: Beer belly / steering wheel room needed in 59
Im in the process of putting a tilt mid 70's Camaro column in my 55, I notched the firewall "up" towards the cowl, slid it as far down towards the frame as I could. It gives it a better angle for more foot room and you dont have to tilt it as much... I will try and get some pics soon!
Dave0 is offline   Reply With Quote
Old 09-28-2016, 10:32 PM   #27
Foot Stomper
Foot Stomper's Avatar
Originally Posted by _Ogre View Post
if you have a stock column now, you can't install a tilt column with out some serious work
Yuk... Thanks... What about putting a 55 wheel on instead? Any mods required? Will it give more room?
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 09-28-2016, 11:48 PM   #28
BIGglaSS
BIGglaSS's Avatar
What about a reproduction 15" wheel? Column length can vary depending on what you are using for a steering box/wheel.
I did the 15" wheel, and moved the column up as high as I could. These cabs are definitely cramped. Next truck I do is going to be a stretch cab.
BIGglaSS is offline   Reply With Quote
Old 09-29-2016, 01:34 PM   #29
_Ogre
_Ogre's Avatar
try a cheap aftermarket 15'' steering wheel to see if it will give you the needed belly room
and non dished wheel will reduce the room by the depth of the dish, but it will still be 17'' if it is a 55 1st series
check this out
http://www.hotrod.com/articles/1208c...teering-wheel/
figure on a min of $1500 to pay someone to do what is in the article
http://qualityrestorations.com/
shop air compressor timer
