Old 10-19-2016, 08:19 AM   #26
realvc
realvc's Avatar
Re: 1962 stepside project by realvc
I've been dealing with a leaking wheel cylinder thinking I had cross threaded the steel brake line and would have to replace the line and may be the wheel cylinder.
After getting the truck back up on the lift to where I could check it out I removed the line and it looked O.K. so I put it back on bled the brakes. I cleaned up everything and left it up on the lift so I could keep an eye on it during the day.
It turned out to be the wheel cylinder leaking inside the drum, running down the backing plate and the brake fluid dripping onto the rim and runs down the sidewall of the tire. The outside of the backing plate stays dry around the bleeder and brake line connection.
Ordered a new wheel cylinder under warranty. I'm getting a lot more drum brake experience than I really wanted.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 10-27-2016, 10:16 PM   #27
realvc
realvc's Avatar
Got the new wheel cylinder on and still had a leak.
My shade tree mechanicin' is not what it should be.
After taking the steel line off again checking everything I decided that I just did have the line tight enough so I cranked it down really tight. It still seeped a little over night so I tightened it so more thinking it is getting close to twisting off.
The drivers side went back together with no problems and did not require near the tightening of the brake line.
No leak now and it has been a few days. I did fess up to the NAPA guys that the wheel cylinder I returned was not defective.
The truck is still on the lift for now as I've been doing other little pittleing things like cutting a half inch thick piece of iron off the back bumper some previous owner thought was a good idea for an extention for mounting the hitch ball.
Also been gathering the parts to reinstall the drivers side window and regulator other needed repairs.
Vince
Galatians 6:14
Old 10-28-2016, 06:21 AM   #28
Ta2Don
Ta2Don's Avatar
Before you begin questioning your mechanicin' skillz, keep in mind new parts and 54 year old mating parts may not always work together so well... New parts can be defective and those 54 year old brake lines may be a bit worn...
Hang in there Brother, you will came out victorious...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 11-07-2016, 09:13 AM   #29
realvc
realvc's Avatar
[IMG]20161005_173414_resized by Vince Crawford, on Flickr[/IMG]
Close up of the big old iron plate I cut off.
Truck is off the lift for now and I can start it up and move it in and out of the shop and around the yard.
Baby steps of progress.
Vince
Galatians 6:14
Old 11-07-2016, 10:59 AM   #30
shp4man
shp4man's Avatar
Your truck is a lot like mine, in that it needs a few parts replaced. But yours has a horn button, didn't get one when I bought mine.
Good luck on your project, I'll be watching this thread.
shp4man is offline   Reply With Quote
Old 11-07-2016, 11:09 AM   #31
Ta2Don
Ta2Don's Avatar
Thumbs up on moving around on it's own power...
DON
Proverbs 27:17
Old 11-07-2016, 08:51 PM   #32
rusty76
rusty76's Avatar
Cool truck and I'm in for the ride on this one.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 11-08-2016, 11:02 AM   #33
realvc
realvc's Avatar
This truck is pretty much complete but the needs are many. I keep trying to decide if I should replace stuff or repair it or just let it alone.
Thanks for your reply.
Vince
Galatians 6:14
Old 11-08-2016, 11:05 AM   #34
realvc
realvc's Avatar
Hey Don,
I got an old floor shift I'll be trying to install at some point in the future.
Vince
Galatians 6:14
Old 11-08-2016, 11:24 AM   #35
realvc
realvc's Avatar
Thanks and welcome. We will be working at a very slow pace.
Vince
Galatians 6:14
Old 11-25-2016, 06:38 PM   #36
realvc
realvc's Avatar
Drove the truck up the drive way and down the street. The six is weak and has a bit of a knock when winding out the gears. Not sure but sounds like a rod.
I was kind of warming up to the idea of leaving the six in it but now I'm not so sure.
I've got a small block sitting on an engine stand that needs a home.
The more I work on this truck the more I find that needs to be done.
Vince
Galatians 6:14
Old 11-25-2016, 06:48 PM   #37
rusty76
rusty76's Avatar
Talking Re: 1962 stepside project by realvc
Well don't worry you'll never beat the pace of my 76.
My build thread
Crossmembers CC
Old 11-26-2016, 02:18 PM   #38
Grizz1963
Grizz1963's Avatar
Always more to be done Vince.
Looks like you are still having fun though.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-03-2016, 07:59 PM   #39
realvc
realvc's Avatar
Smile Re: 1962 stepside project by realvc
Guess I'll jump in the deep end and go for disc. brakes, five lug, power brakes and V8, change out the rear to a five lug as well.
Spent yesterday(Friday) purchasing and picking up a 1982 donor truck.
Long story short the new 82 is home but what a deal to get it here.
It has a later 350 with Edelbrock carb and intake, hedders, and a turbo 350.
My plans have gone way away from I had intended to do.
It has been raining here all day so I'll just post the Craig's list pictures. These pictures are at the previous owners home.
Some more detailed pics. to follow at another time.
Vince
Galatians 6:14
Old 12-03-2016, 09:57 PM   #40
Ta2Don
Ta2Don's Avatar
Congrats on the squarebody donor! I'm glad you pulled the trigger on that one. Let the games begin...
DON
Proverbs 27:17
Old 12-04-2016, 01:22 AM   #41
Grizz1963
Grizz1963's Avatar
Morning Vince. Just fed the cat and made a cuppa tea, now surfing the web, and see you are not doing a big build
Congrats.
You know this is the beginning of the beginning of the end on truck building??
Actually looks a good truck too.
Old 12-04-2016, 08:13 AM   #42
realvc
realvc's Avatar
Got the 82 from the grandson of another Air Force retiree up 107 past the back gate of the air base out in Macon.
Made two round trips up there and back. He loaned his trailer to bring home so had to make the second trip to return the trailer. It was an all day deal.
I'll be posting pics. of the motor when it quits raining. It cranks from the seat, moves forward and backward and stops under it's own power these all good things for old trucks.
Vince
Galatians 6:14
Old 12-04-2016, 08:19 AM   #43
realvc
realvc's Avatar
Congrats.
It is like an old "Highman's" song, "The Road Goes On Forever and The Party Never Ends"
Once you start on an old truck you are never really finished, there will always be one more thing or another update or even another rebuild.
I'm still not sure about posting pictures of p\the progres or the lack of it. I get started doing something and then I'm done for the day and realize I've not taken a single pic.
Vince
Galatians 6:14
Old 12-04-2016, 04:42 PM   #44
realvc
realvc's Avatar
O.K. this may be more than anyone wants to know, but I need picture posting practice.
This first picture is the before where I cut the hitch plate off and then the after the plate was removed from the 62.
Then we have my new 82's tailgate with iron plate
Then there is the engine in the 82 that will be donated in part to the 62.
The slider back glass that takes the place of the Easy Rider Rifle Rack in latter days of trucking.
Vince
Galatians 6:14
Old 12-04-2016, 08:18 PM   #45
flashed
The donor truck looks pretty good .Lots of good parts you can sell off to have more truck play money.
flashed is offline   Reply With Quote
Old 12-12-2016, 09:49 PM   #46
realvc
realvc's Avatar
In the glove compartment I found the owners manual and original paper work from when the 82 was sold new on Nov. 11, 1981 to "WELSCO" a wielding supply company.
That explains the iron plate on tailgate.
Also my brother still works for WELSCO and was working there when this truck was bought new. It is a small world for sure, but I would not want to paint it.
The only constructive truck time I've had involved moving the trucks, the jeep and vette around so I could get them all in the shop at the same time and still have room to work.
Also had a nice visit by phone yesterday with bro. TA2DON that was mostly truck related.
Vince
Galatians 6:14
Old 12-20-2016, 11:07 AM   #47
realvc
realvc's Avatar
Not much happening truck wise but the shop projects that are in front of it are being worked out. Should start tearing into the donor truck soon.
Vince
Galatians 6:14
Old 12-20-2016, 06:19 PM   #48
Ta2Don
Ta2Don's Avatar
dang cell phone
DON
Proverbs 27:17
Old 12-20-2016, 06:46 PM   #49
Ta2Don
Ta2Don's Avatar
Attempted to post this pic prior to the last post, but the pic came out sideways...
Had a good, albeit short, visit with Brother Vince earlier today... Thanks again for your hospitality!!!
Untitled by Donald Olivo, on Flickr
Very fun driveway, that he navigates in a vette!!!
Here's a quick shot of the donor truck...
...and the '62 stepper and other toys...
Cool double blower setup, hiding in the backroom...
Small block Chevy Bell-housing ready for two wheel duty...
Gotta plan a trip that'll last a bit longer so I can pilfer around...Hehe!
DON
Proverbs 27:17
Old 12-20-2016, 08:11 PM   #50
realvc
realvc's Avatar
Great having you and your wife come by for a while. Thanks for the transmission.
I got the welding table turned back upright and ready for the casters and called it a day.
Thanks too for the pics. Nothing like two grey beards and a shop full of projects.
Vince
Galatians 6:14
