Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 12-09-2016, 08:33 PM   #26
04ls1gto
Re: My new project the White Whale.
Looks like a great foundation. You could try a heat gun and putty knife
04ls1gto is offline   Reply With Quote
Old 12-11-2016, 02:59 PM   #27
nastety92
I'm going to give that a try one of these nights when it's a little warmer out. I don't have any heat in the garage right now.
nastety92 is offline   Reply With Quote
Old 12-12-2016, 01:31 PM   #28
3drburb
Sweet ride!!
The white with the red is an all time classic and a favorite of mine.
Btw if you use a heat gun to take out the insulation, use a fan to blow the fumes away from you if there is any, but if I was doing it I would leave that in there and just add more over it, if its clean and does not smell bad.
3drburb is offline   Reply With Quote
Old 12-12-2016, 01:33 PM   #29
nastety92
Originally Posted by 3drburb View Post
Sweet ride!!
Thanks for the tip. I might just leave whatever is there for now. I know the white outside and red inside is classic. I think I'm going to completly change the outside and inside color to a pure white color like the Summit White on a new Yukon. I don't like red interiors at all.
Old 12-12-2016, 01:55 PM   #30
3drburb
Well you have to always build what you like and it should be way safer and comfortable. I pulled my interior and did similar to your plans.
You have a lot a seats for that burb, I will stick around and enjoy the ride.
Your seat looks very nice after the cleaning.
Old 12-12-2016, 02:10 PM   #31
Hart_Rod
Hart_Rod's Avatar
Originally Posted by AnotherWs6 View Post
I don't know if it is correct, but my firewall is white and the rest is black. LOOKS right. Here is a pic of my engine bay and a shot of the old burbon.
I like the stock ride height, but that's just me. Makes it very "usable" if that makes sense.
Good luck!!!
Beautiful Burb!
Hart_Rod is offline   Reply With Quote
Old 12-12-2016, 02:49 PM   #32
nastety92
Thank you. The seats will do for now. They really need all new covers but cleaning them up will be all that my wallet will allow for a while. I just don't have the extra funds to do Everything that I want right now. So getting it up and running correctly is where my money will go to start.
Old 12-12-2016, 06:31 PM   #33
notchbackgta
That's what I was going to suggest.
Also, it is not sound deadening, it is vibration dampening, as is Dynamat and similar products. You can read everything you ever need to know Here at Sound Deadener Showdown. If you want to quiet sound you have to put down something with mass. A lot of people use MLV (Mass loaded vinyl), so putting Dynamat over top of that is just a waste of time and money. I had to get a lot of that off the floor in my suburban, it didn't take too long though. A lot of it came off easily with the knife, the rest I only had to use the knife to get most of it off, then use a little heat to get the rest, then wiped the floors with some lacquer thinner and all the residue came off.
notchbackgta is offline   Reply With Quote
Old 12-19-2016, 08:53 AM   #34
nastety92
Spend a little time working on the truck yesterday. Put the hood on top of the truck for right now so I can have more room to work on the seats.
Here is the first test fitment of the front and rear seats along with the center console. It's pretty tight in there, I thought there was going to be a little more room really.
Old 01-02-2017, 06:38 PM   #35
goldenburb
goldenburb's Avatar
Nice.... I've been looking for a while for a white & red burd. Funny you have one and want to change. Lol keep up the good work.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 01-02-2017, 09:05 PM   #36
nastety92
Thanks man. I'm keeping the white just changing the interior color and to also white. I also don't like any off white colors so pure white it is for me.
What do you have for a Suburban?
Old 01-04-2017, 12:52 AM   #37
goldenburb
goldenburb's Avatar
A rusty 70 gold burd....just collecting parts. 20" modsteel
67 c10 2wd sb truck
67 c10 4wd lb truck
Old 01-04-2017, 07:37 AM   #38
nastety92
Nice those are the wheels I would like to get eventually as well and I really like those hubcaps with GMC center caps.
Old 02-06-2017, 03:39 PM   #39
nastety92
Made some progress over the weekend. We got the motor removed from the 2004 Suburban along with the transmission and t-case.
Also, the one 17" wheel that I ordered from Summit is due to arrive tomorrow. Going to test fit the wheel then look for one used tire to also test fit before I order anything else.
Going to be ordering motor mounts this week. We planned out the fuel system for the truck and looking into wiring harnesses.
Also, tonight I'm going to take the seats back out of the truck and try to use the old bench seat frame to mount the new 04 Seats for the rear seats since they sit so far back right now with the 04 Seat mounts. Hopefully we can get that to work as well.
Anyway, making some progress, I'm happy about that.
Nick
Old 02-07-2017, 09:23 PM   #40
nastety92
Got my new US Wheel Rat Rod 17x8 6-lug wheel in and test fit today. I only ordered one to start to check fitment. I'm also going to try a used tire in the size I think I want before I buy nicer tires as well. I'm looking at 245-50-17's for tires. Not sure if I'm going to run the same size front and rear or two different size tires. They do make the wheel in a 17x9 as well.
I purchased the wheel from Summit. $95 shipped.
https://m.summitracing.com/parts/usw-68-8860
http://www.uswheel.com/products/ratrod
Old 02-13-2017, 03:39 PM   #41
nastety92
Just ordered motor mounts today.
CPP mounts
https://www.summitracing.com/parts/c...80NBoCo4Pw_wcB
Dirty Dingo Sliders
http://www.dirtydingo.com/shop/produ...oducts_id=1443
Looking forward to getting these so the engine can be placed in the engine bay and we can make plans for the rest of the parts that are needed. Next up to order is a new fuel tank, then onto a wiring harness for the engine.
Old 02-14-2017, 12:58 AM   #42
LockDoc
The Older Generation
LockDoc's Avatar
Progress is progress. I like the wheels. You probably don't know for sure if everything is going to work until you get a tire mounted but it looks like you won't have any clearance problems....
LockDoc
Leon
Old 02-14-2017, 08:54 AM   #43
nastety92
LockDoc
Thanks, yeah just trying to pick away at it one piece at a time. I really want the Detroit Steel 20-22's but these are what the budget allowed right now. I think I'm going to go 17x9's in the rear. I've been looking for used tires in my area to test fit but have yet to find one close enough.
Old 02-22-2017, 02:31 PM   #44
nastety92
Today I got the new wheels and used tires test fit on the truck. Wheels are 17x8 and tires are 245-45-17. They seem to fit well and still have plenty of room to lower the truck more.
Old 02-22-2017, 07:21 PM   #45
logansdad
logansdad's Avatar
After dealing with other wheel companies through the years I try to use detroit steel as much as possible. They are the best company who get that customer service comes first. I understand the budget thing too. But man do look good on our burbs.
1972 chevy sububan----frame off restoration now for sale😟
http://67-72chevytrucks.com/vboard/s...d.php?t=560803
1968 GMC Suburban- turned 67 air ride, streched and shaved everything, 22" detroit steelies, lt1 http://67-72chevytrucks.com/vboard/s...d.php?t=668574 suburban 4x4 1 ton zz454 daily kid hauler
1991 gmc syclone
1987 c10 silverado
"Hey lifted 4x4 guy does your truck know what mud is"
"Every inch you go up is an inch you don't have"
logansdad is offline   Reply With Quote
Old 02-22-2017, 07:46 PM   #46
nastety92
They definitely looks great on these trucks but this year I can't come up with the funds. I've purchased two wheels so far I'm planning on buying five. That will cost me roughly $430 for all five. It would of been more than twice that for wheels alone and tires are much more expensive in 20's or 22's. Hopefully next year or the year after I'll be able to grab a set.
In the mean time I like these wheels and they should look good with the theme I'm going for.
Old 02-25-2017, 01:15 AM   #47
nastety92
Got some more work done on the truck tonight and last night. I good friend of mine helped me build a frame to mount the 04 seat cushions on the brackets from the 67 rear seats and a custom frame that we made. Looking forward to test fit it in the truck tomorrow.
I'm going to paint the whole frame bracket black once I double check to make sure it all fits first.
Old 02-25-2017, 08:43 AM   #48
04ls1gto
Looks good, are you using front buckets as well?
Old 02-25-2017, 10:09 AM   #49
nastety92
Thank you. Yea front buckets from the 04 sub as well
Old 02-25-2017, 09:12 PM   #50
nastety92
Got the rear seat test fit today in the truck. The seat fits great and bolts right into the stock seat bracket mounting holes. Now there is plenty of room between the front bucket seats and the rear bench. Also test fit one of the wheels in the spare tire location and it fits pretty good. Picked up a few more tires and I'm going to order the rest of the wheels this week as well.
