Old 10-06-2016, 06:26 PM   #26
VWNate1
VWNate1's Avatar
Post Re: 1969 250 help
Carby is always the _last_ thing you should touch when chasing running issues, tune ups etc.
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 10-06-2016, 06:39 PM   #27
sberman431
Re: 1969 250 help
I was going to rebuild the carb after it is running good . I noticed the other day that one of the gaskets looked like it had gas on it .
I did the initial tuning like you said ran better but still not running good . I now I have to do the one mark at a time thing like you suggested
sberman431 is offline   Reply With Quote
Old 10-06-2016, 08:06 PM   #28
VWNate1
VWNate1's Avatar
Thumbs up Tune Up
It's the little things that make the most difference .
Don't sweat fuel stains around the bowl gasket, that's normal .
First :
Remove and check the spark plugs , you personally have to gap them properly using a WIRE GAUGE to .035" .
Use a test light on each and every plug wire to see if they're continuous ~ if the test light doesn't light, replace that wire .
Points to no more than .016" or 33° dwell if you can find/borrow (Pawn shops, $10) a Dwell/Tach meter ~ setting the dwell with the plugs removed and rotor off whilst cranking the engine guarantees best dwell and hottest spark .
Look across the ends of the plugs ~ the center electrode _MUST_ be squared off ! if it's even slightly rounded the engine will never run properly .
This stuff is easy to do and teaches you as you do it .
-Nate
Geezer
Old 10-06-2016, 09:04 PM   #29
sberman431
Re: Tune Up
thanks for that i will do all thr this sat or sun . nice and slow ill get it done
Old 10-06-2016, 10:05 PM   #30
VWNate1
VWNate1's Avatar
Thumbs up Re: 1969 250 help
Keep us posted .
-Nate
Geezer
Old 10-06-2016, 10:57 PM   #31
sberman431
Re: 1969 250 help
will do and thank you for all your help
Old 10-09-2016, 03:35 PM   #32
sberman431
Re: 1969 250 help
Ok plugs done dwell good wires good set at 12 btdc . Runs better getting a misfire once in a while .would it be worth at this point to go hei ?
Old 10-09-2016, 05:52 PM   #33
geezer#99
geezer#99's Avatar
Re: 1969 250 help
It would. Best bang for the buck.
Old 10-10-2016, 09:16 AM   #34
vince1
Re: 1969 250 help
I have a 66 with oil bath air cleaner and the truck had been sitting for probably 20 years. It would quite frequently spit just when starting under load and take a while to clear itself. With carb kit there was no difference but with HEI from a 78 Nova the problem went away completely. It must have had a weak coil or bad plug wire.
vince1 is offline   Reply With Quote
Old 10-10-2016, 09:55 AM   #35
VWNate1
VWNate1's Avatar
RE : Electronic Ignitions ~
Yes, a thousand times yes .
My '69 C/10's 250 i6 engine is in bad shape ~ it runs fine but fouls the spark plugs every 250 miles or so, adding the HEI setup from a '76/'77 Chevy Nova makes it run perfectly all the time .
With HEI you open the spark plug gaps up to .060 and they'll fire no matter how much oil is getting past the rings or valve guides .
Even the basic Pertronix " Ignitor" points replacement system will give you a noticeable boost in power , smoother idle , easier starting and improved fuel economy .
-Nate
Geezer
